Home » Modeling » OCL » Problem using OCLType in stereotype invariant
Re: Problem using OCLType in stereotype invariant [message #1280563 is a reply to message #1279159] |
Sun, 30 March 2014 14:55 |
Ed Willink Messages: 7655 Registered: July 2009 |
Amongst other problems, not all of the
http://www.eclipse.org/uml2/4.0.0/UML registrations have been upgraded
to support http://www.eclipse.org/uml2/5.0.0/UML as well.
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=397508#c17.
You might get on a bit better by hand-editing the XML to
http://www.eclipse.org/uml2/4.0.0/UML.
Ed Willink
On 28/03/2014 10:08, Klaas Gadeyne wrote:
> The attachment to this post contains
> - a UML profile with a stereotype (Stereotype1) that generalizes a virtual stereotype that extends UML::NamedElement. A constraint ensures that Stereotype1 can only be applied to UML Properties instead of all NamedElements
> - a Simple UML model to which this profile is applied.
> When validating MySubPropertyModel.uml from within the UML2 model editor, the validation (unfortunately) reports that constraint1 is violated.
> However, when evaluating the following expression in the xtext console
> self.extension->asOrderedSet()->first().base.oclAsType(Property).oclIsInvalid()
> the expression returns false as expected.
> Did I overlook something very obvious here?
> Tooling info:
> Luna M6, OCL from nightly build update site:
> OCL Unified SDK: Parsers,Evaluator,Editors,Tools 3.4.0.v20140322-1654 org.eclipse.ocl.examples.unified.feature.group Eclipse Modeling Project
> org.eclipse.ocl.examples.pivot 3.4.0.v20140310-1427
Re: Problem using OCLType in stereotype invariant [message #1281143 is a reply to message #1279159] |
Mon, 31 March 2014 12:27 |
Your virtual stereotype has isRequired = false (ExtensionEnd.lower = 0)
and so the virtual stereotype is not automatically applied and so it
does not provide the required navigation.
See UML 2.5 p270 ProfileApplication para2, p285 /isRequired.
I will promote your example with and without fixes into a JUnit test.
While debugging I notice that UML2Pivot ignores ProfileApplication and
so even with isRequired=true, it probably won't work.
Thank you for your patience and interesting examples.
Ed Willink
> Tooling info:
Re: Problem using OCLType in stereotype invariant [message #1281202 is a reply to message #1281143] |
Mon, 31 March 2014 14:11 |
Watch
https://bugs.eclipse.org/bugs/show_bug.cgi?id=431638
for progress on this example.
Ed Willink
On 31/03/2014 13:27, Ed Willink wrote:
> Hi
> 0) and so the virtual stereotype is not automatically applied and so
> it does not provide the required navigation.
> Regards
> Ed Willink
>> Hi,
>> violated.
>> Tooling info:
>> Project
Re: Problem using OCLType in stereotype invariant [message #1281707 is a reply to message #1281143] |
Tue, 01 April 2014 08:36 |
Klaas Gadeyne Messages: 165 Registered: July 2009 |
Hi Ed,
Ed Willink wrote on Mon, 31 March 2014 08:27Hi
I was aware of this (and in this case, I declared isRequired to be false intentionally)
and so it does not provide the required navigation.
I don't understand this (consequence) though. Maybe I misunderstood what you mean with "navigation" in the above sentence. Rereading the UML spec, I also didn't find new insights regarding my understanding of isRequired.
If I look at the constraint in the profile (the one that, on the model level, does not evaluate as I expect)
self.base_NamedElement.oclAsType(Property).oclIsInvalid() = false
I would state that it navigates from the stereotype to the metaclass, and not the other way around, so the multiplicity of the extensionEnd doesn't even matter?
Of course, in the OCL expression in the OCL console (ie. evaluated on the model which has the profile applied)
I do navigate from the (instance of the) base class towards the stereotype, but this expression evaluates false as expected.
Klaas
Re: Problem using OCLType in stereotype invariant [message #1281735 is a reply to message #1281707] |
Tue, 01 April 2014 09:27 |
The Pivot OCL representation reifies the stereotype application in an
ElementExtension object.
Currently (Luna M6) UNML2Pivot creates one for each of the explicit
weird root XMI objects.
My reading of ExtensionEnd lowerBound > 0 is that this is an implicit
stereotype application and so an ElementExtension should be created for
these as well.
In your example this would ensure that vStereotype1 was applied to
NamedElement and would provide the Property and target for
I'm adding this missing functionality (and transitive
ProfileApplications) right now.
not oclIsKindOf(Property) is simpler, clearer and quicker than
perhaps even
self.extension->forAll(base.oclIsKindOf(Property))
Ed Willink
On 01/04/2014 09:36, Klaas Gadeyne wrote:
> Hi Ed,
>> Hi
> Quote:
> of isRequired.
> Regards,
> Klaas
Current Time: Tue Apr 23 15:31:04 GMT 2024
Powered by FUDForum. Page generated in 0.03514 seconds
