Ctrl + A in SourceViewer returns empty TextSelection [message #1277761] |
Wed, 26 March 2014 12:35 |
I have an 3.7 RCP application with a View and a SourceViewer. I also have a command which can be called from the View's context menu with a visibleWhen directive testing for a non-empty text selection (source below). It works fine when I select text in the SourceViewer per mouse or Shift+Arrow, i.e., the PropertyTester's test() method returns true.
However, when I press CTRL + A to select all text in the SourceViewer, TextSelection.getText().isEmpty() returns true. I.e., the popup menu doesn't show.
Why is this, and how can I solve the problem so that CTRL + A returns a TextSelection including all text from the viewer?
Below sources are also on github: https://github.com/newcodeontheblock/blog/tree/master/net.sdruskat.blog.foobar.textselection.popupmenu.
Source of PropertyTester's test() method below. Please let me know should I have to add other sources.
public class SelectionTester extends PropertyTester {
public boolean test(Object receiver, String property, Object[] args, Object expectedValue) {
if ("hasNonEmptyTextSelection".equals(property)) {
if (receiver instanceof Collection) {
@SuppressWarnings("unchecked")
Collection<Object> receiverCollection = (Collection<Object>) receiver;
TextSelection selection;
if (receiverCollection.toArray().length != 0 && receiverCollection.toArray()[0] instanceof TextSelection) {
selection = (TextSelection) receiverCollection.toArray()[0];
if (!selection.getText().equals("")) {
return true;
return false;
Re: Ctrl + A in SourceViewer returns empty TextSelection [message #1277771 is a reply to message #1277761] |
Wed, 26 March 2014 12:55 |
Interestingly enough, when the RCP loses and re-gains focus, the selection is registered...
So perhaps I'd need to redefine CTRL+A for the view, guessing that CTRL + A works over the complete workbench?
Update:
When I register a SelectionChangedListener on the View, it correctly identifies the selection with CTRL + A. Not sure what to do with this though. I could get the activePart in the SelectionTester, get its SelectionChangedListener and intercept the SelectionChangedEvent, but this is surely beyond clean coding...
[Updated on: Wed, 26 March 2014 13:02] Report message to a moderator
FUDForum. Page generated in 0.02784 seconds
