Re: Customize XML serialization using ERefence Etype instead of name [message #1276802 is a reply to message #1276709] |
Tue, 25 March 2014 03:17 |
Ed Merks Messages: 33140 Registered: July 2009 |
Agustin,
Nested elements always use feature names, not type names. You might
want to look at
http://ed-merks.blogspot.ca/2007/12/winters-icy-grip.html if you are
hung up on the serialization format.
On 24/03/2014 7:58 PM, Agustin Vosou wrote:
> Hi everyone,
> After days and days of looking for a solution I decided to post my
> question in this forum.
> I have a very simple Ecore file for a Filesystem and I have created a
> diagram using GMF, but I am having a problem with the generated
> diagram's XML.
> The problem is that the XML nodes inside de diagram are being
> generated using the EReference "name" attribute instead of the "EType"
> attribute.
> E.G. I'd like to change <files> to <File>; and <folders> to <Folder>
> in the following example.
> Ecore:
> File
> Folder
> folders: EType Folder
> files: EType File
> Filesytem
> folders: EType Folder, containment: true
> files: EType File, containment: true
> Diagram:
> Filesystem:
> folders: Folder1,Folder2
> files: File1
> Folder:
> folders: Folder2
> files: File1
> Folder:
> folders: -
> files: -
> File:
> Diagram's XML
> <com.example.filesystem:Filesystem xmi:id="_VFkHMLCAEeOdou7_dXIPjg">
> <folders xmi:type="com.example.filesystem:Folder"
> xmi:id="_WWim4LCAEeOdou7_dXIPjg" name="Folder1"
> folders="_XGFNcLCAEeOdou7_dXIPjg" files="_Vt-LALCAEeOdou7_dXIPjg"/>
> xmi:id="_XGFNcLCAEeOdou7_dXIPjg" name="Folder2"/>
> <files xmi:type="com.example.filesystem:File"
> xmi:id="_Vt-LALCAEeOdou7_dXIPjg" name="File1"/>
> </com.example.filesystem:Filesystem>
> Expected diagram's XML
> <Folder xmi:type="com.example.filesystem:Folder"
> <File xmi:type="com.example.filesystem:File"
> Is there any way to do it but not having to change the references name
> attributes?
> Thank you,
> Agustin
Ed Merks
FUDForum. Page generated in 0.03603 seconds
