Re: Best practices for a dynamic splash screen using E4? [message #1276511 is a reply to message #1276388] |
Mon, 24 March 2014 13:14   |
a) preloader
I doubt that our launching would support a preloader because this would
require our OSGi-Application to be a subclass Application so that the
native launcher picks it up (at least this is how i read LauncherImpl).
In 1.0.0 we could see if we flip the launching process so that we first
launch fx and then java but that might be a major effort including
duplication on what equinox.launcher.jar does for us (we can simply copy
their launching code) and I doubt a can do this as part of my OSS time
on e(fx)clipse.
b) native equinox
On native equinox launcher front i had a short chat with Tom Watson at
EclipseCon where I confirm that this is a problem but he does not have
knowledge to fix it and all people who could have left for other jobs in
and outside IBM.
c) fx native
What I don't understand is why on hell the Oracle packager does not
support this very feature they are create the executable why can they
not show a splash through this exe, should be a very trivial thing - at
least all other native apps do show such a guy so why can't we?
d) native java
Finally java itself can since the early days show a splash using
http://docs.oracle.com/javase/tutorial/uiswing/misc/splashscreen.html
but I never managed to get that working inconjunction with JavaFX but
maybe I was too dumb to get such a dumb thing working!
Tom
On 24.03.14 06:45, Uwe San wrote:
> problems involving the splash screen issue were discussed
> http://www.eclipse.org/forums/index.php/mv/msg/535635/1121381/#msg_1121381
> and
> http://www.eclipse.org/forums/index.php/mv/msg/541879/1128245/#msg_1128245
> already, but I'd like to address the issue again, since I'm looking for
> the best way for showing a dynamic splash screen (containing a login
> form) as early as possible in the lifecycle of our E4 application.
> We have the following requirements:
> A splash screen (static OR dynamic) should be shown as quickly as
> possible during the application startup. As a reference, we consider the
> startup time of the native splash screen which is very fast.
> The splash screen should show a login form. This does not need to happen
> immediately after the splash appeared on screen, but the form should be
> visible after a few seconds at the latest.
> The splash screen should show a progress indicator as long as the
> application is starting up. This indicator should appear next to and not
> later than the login form.
> The splash screen should disappear when (i) the E4 application has been
> loaded completely and (ii) the user has clicked the "login" button.
> Our options for implementing this include:
> Writing a custom splash screen using an E4 lifecycle hook (might be too
> slow)
> Using a combination of a static native splash and a dynamic E4 splash
> (may be hard to manage?)
> Using a javafx.application.Preloader class (if supported by efxclipse?)
> [put your idea here :)]
> Any recommendations?
> Uwe
Re: Best practices for a dynamic splash screen using E4? [message #1277107 is a reply to message #1277027] |
Tue, 25 March 2014 10:08  |
I'd say file a bug and provide a patch - as long as the default
bootstrapping is not broken I'm all for allowing you to access it in
whatever way you want!
Tom
On 25.03.14 12:29, Pawel Zalejko wrote:
> I also started looking into this problem and I have one more idea how we
> could try to resolve this problem.
> In general, my concept involves creating a separate bundle which will
> start a JavaFX application (javafx.application.Application.launch())
> that shows a login form. This bundle can be started on the 1st bundle
> start level. As a direct result, the UI would be displayed after
> starting the OSGi framework but before initializing the E4 platform. The
> second part of my concept assumes that starting of a JavaFX-RCP
> application will be:
> 1. Postponed until the login form is closed.
> 2. Instead of launching a new JavaFX application an existing one
> will be reused to show the JavaFX-RCP application (note: we cannot call
> javafx.application.Application.launch method more than once per VM).
> What do you think about it?
> I also manage to create a working proof-of-concept implementation. In
> order to create my implementation I had to introduce a bunch of changes
> to the org.eclipse.fx.ui.workbench.fx.E4Application, for instance:
> 1. Moving the Application.launch(JFXApp.class); to a separate method
> (which can be overridden).
> 2. Making the JFXApp a regular class (not a static nested class).
> Those two changes don't break the e(fx)clipse functionality but they
> allow to create a custom implementation that can be used for declaring
> the "org.eclipse.core.runtime.applications" extension point (a custom
> application class can extend the
> org.eclipse.fx.ui.workbench.fx.E4Application class and override the (1)
> method). On top of those changes I created my own E4Application class
> where I implemented showing JavaFX-RCP application using the
> javafx.application.Application which was launched by the bundle that
> started on the 1st bundle start level (I also added there checking
> whether the login form is closed or not).
FUDForum. Page generated in 0.04155 seconds
