Column Filter in TablePages when table is scrolled [message #1276356] |
Mon, 24 March 2014 12:57 |
Hi Scout Users,
Firstly and before starting with my questions and my problems I have to congratulate all Scout Team for this great job !
I use Scout 3.9 (with RAP only, neither SWT nor Swing) on Linux system.
It seems that when I want to filter values in a TablePage (right clic on header column and "Column filter..."), the form that appears does not give the good values if the table (with a lot of columns) is scrolled on the right.
Scout 3.9 with RAP (neither Swing nor SWT) / Linux
Re: Column Filter in TablePages when table is scrolled [message #1332545 is a reply to message #1278820] |
Sun, 04 May 2014 17:59 |
Hi Jeremie,
I tried with the latest luna branch 4.0.0.2140503 (but not with 3.10-M5) and the problem always exists. I even met other problems : when I right click on column header to open a filter:
- the first time, the "Column filter" menu item is not visible
- the second time and after, the values match the column one rank on the left
- and whatever the column you choose, the values are always the same
Did I make a mistake or do you meet the same problem ?
(Linux Fedora 20 + Eclipse Luna)
Didier
Re: Column Filter in TablePages when table is scrolled [message #1385741 is a reply to message #1385072] |
Tue, 10 June 2014 21:15 |
Hi Matthias,
I'm sorry for the delay : I've had few problems with update on my eclipse luna RC2. So, I installed RC3 and...all problems are now solved !
- "column filter" menu appears on every right clic and gives the good filter values,
- on large tables with right scroll, the "column filter" is now ok (good values ; no more shift problem)
Thanks Matthias, Jeremie (and all Scout Team!)
FUDForum. Page generated in 0.03696 seconds
