Re: Selection and drag connection tool [message #211823 is a reply to message #211783] |
Thu, 16 March 2006 00:09 |
So, you have no need to drag the "node" editparts? If so, It sounds like you
need to extend ConnectionDragCreationTool and modify it to include the
behavior found in SelectEditPartTracker.
"Scott Hathaway" <scott_hathaway@iwaysoftware.com> wrote in message
news:dva29m$6kg$1@utils.eclipse.org...
>I am needing a tool that will allow for not only the selection of an
> EditPart but also the creation of a connection by dragging from a source
> EditPart to a target EditPart. It needs to work so that single clicking
> on an EditPart only selects the part but does not start connection
> creation. Only when a drag occurs does the connection creation begin.
> After searching this newsgroup, I tried a few different approaches
> without success. First, I tried setting the drag tracker on the
> SelectionTool to the ConnectionDragCreationTool. Next, I tried
> implementing the getDragTracker method of my EditPart. Finally, I tried
> creating my own EditPolicy for the PRIMARY_DRAG_ROLE. None of these
> solutions worked very well.
> Do I need to create my own tool to accomplish this task or is there an
> easier way?
> TIA
FUDForum. Page generated in 0.01909 seconds
