Serial Version InvalidClassException [message #211683] |
Wed, 15 March 2006 11:43  |
Originally posted by: joshuaga.usc.edu
I am writing an editor using gef for eclipse. I am updating code that
used an older version of gef and eclipse. However, there are some removed
classes like CompoundSnapToStrategy and ToggleGridVisibililityAction that
the current versions of gef do not use. I have simply commented out this
code and replaced the code with the closest syntax that would make my
editor run.
However, At the line where setSAIGraph() is called, an
InvalidClassException occurs regarding the serial versions:
InputStream is = file.getContents(false);
ObjectInputStream ois = new ObjectInputStream(is);
setSAIGraph((Graph)ois.readObject());
I don't quite understand this, so I don't know what to do. What can I do
to fix this serial version problem? I have provided a copy of the stack
trace if that can help. Thanks in advance.
Josh
java.io.InvalidClassException: org.sai.visual.model.CompoundLabels; local
class incompatible: stream classdesc serialVersionUID =
-278808807177420868, local class serialVersionUID = -7667399604280763487
at java.io.ObjectStreamClass.initNonProxy(ObjectStreamClass.jav a:519)
at java.io.ObjectInputStream.readNonProxyDesc(ObjectInputStream .java:1546)
at java.io.ObjectInputStream.readClassDesc(ObjectInputStream.ja va:1460)
at
java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStre am.java:1693)
at java.io.ObjectInputStream.readObject0(ObjectInputStream.java :1299)
at
java.io.ObjectInputStream.defaultReadFields(ObjectInputStrea m.java:1912)
at java.io.ObjectInputStream.readSerialData(ObjectInputStream.j ava:1836)
at
java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStre am.java:1713)
at
at
at java.io.ObjectInputStream.readArray(ObjectInputStream.java:1 628)
at java.io.ObjectInputStream.readObject0(ObjectInputStream.java :1293)
at
at
at
at
at
at
at
at
at
at
at java.io.ObjectInputStream.readObject(ObjectInputStream.java: 339)
at java.util.ArrayList.readObject(ArrayList.java:591)
at
at
at java.lang.reflect.Method.invoke(Method.java:585)
at java.io.ObjectStreamClass.invokeReadObject(ObjectStreamClass .java:919)
at java.io.ObjectInputStream.readSerialData(ObjectInputStream.j ava:1813)
at
at
at java.io.ObjectInputStream.defaultReadObject(ObjectInputStrea m.java:468)
at org.sai.visual.model.Graph.readObject(Graph.java:154)
at
at
at
at org.sai.visual.VisualEditor.setInput(VisualEditor.java:262)
at org.eclipse.gef.ui.parts.GraphicalEditor.init(GraphicalEdito r.java:292)
at
org.eclipse.ui.internal.EditorManager.createSite(EditorManag er.java:778)
at
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:596)
at
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:384)
at
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:552)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:28 3)
at
org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:126)
at
org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(PresentablePartFolder.java:269)
at
org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftToRightTabOrder.java:65)
at
org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(TabbedStackPresentation.java:391)
at
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1102)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:1051)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:12 56)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:442)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:109 )
at
org.eclipse.ui.internal.EditorSashContainer.addEditor(Editor SashContainer.java:60)
at
org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorA reaHelper.java:212)
at
org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAre aHelper.java:202)
at
org.eclipse.ui.internal.EditorManager.createEditorTab(Editor Manager.java:758)
at
org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager.java:665)
at
org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:628)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2360)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2295)
at org.eclipse.ui.internal.WorkbenchPage.access$9(WorkbenchPage .java:2287)
at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.ja va:2273)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2268)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2249)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:371)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:334)
at org.eclipse.ui.actions.OpenFileAction.openFile(OpenFileActio n.java:98)
at
org.eclipse.ui.actions.OpenSystemEditorAction.run(OpenSystem EditorAction.java:98)
at
org.eclipse.ui.views.navigator.OpenActionGroup.runDefaultAct ion(OpenActionGroup.java:120)
at
org.eclipse.ui.views.navigator.MainActionGroup.runDefaultAct ion(MainActionGroup.java:326)
at
org.eclipse.ui.views.navigator.ResourceNavigator.handleOpen( ResourceNavigator.java:650)
at
org.eclipse.ui.views.navigator.ResourceNavigator$6.open(Reso urceNavigator.java:409)
at
org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredV iewer.java:741)
at
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1044)
at org.eclipse.core.runtime.Platform.run(Platform.java:783)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:44)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:14 8)
at
org.eclipse.jface.viewers.StructuredViewer.fireOpen(Structur edViewer.java:739)
at
org.eclipse.jface.viewers.StructuredViewer.handleOpen(Struct uredViewer.java:968)
at
org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(Stru cturedViewer.java:1067)
at
org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrate gy.java:243)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.ja va:238)
at
org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:277)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1021)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2867)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2572)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at
at
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Re: Serial Version InvalidClassException [message #211735 is a reply to message #211683] |
Wed, 15 March 2006 15:39   |
Java serialization is not a robust mechanism for storing and reading in
data. If the class changes, it breaks compatibility with data stored using
the class' previous incarnation. There are some things you can do to improve
this. Google "java serialization UUID".
"Joshua Garcia" <joshuaga@usc.edu> wrote in message
news:15ae28ab12c09e549076a6abc372667e$1@www.eclipse.org...
>I am writing an editor using gef for eclipse. I am updating code that used
>editor run.
> Josh
> = -278808807177420868, local class serialVersionUID = -7667399604280763487
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: Serial Version InvalidClassException [message #211888 is a reply to message #211735] |
Thu, 16 March 2006 06:36   |
Hi Randy,
Do you happen to know where I can get info on those no longer existing
classes like CompoundSnaptoStrategy and ToggleGridVisibilityAction? The
only possibility there seems right now is to grab an old version of GEF
and possibly eclipse and then hope there are javadocs that come with it.
Thanks for the help.
Josh
Re: Serial Version InvalidClassException [message #211957 is a reply to message #211888] |
Thu, 16 March 2006 20:32  |
news:fe5bbecadd0926ebfe52a6f7e08729b4$1@www.eclipse.org...
> Hi Randy,
Those classes were never in an official release of GEF. The correct classes
are CompoundSnapToHelper, and ToggleGridAction.
> Josh
FUDForum. Page generated in 0.06690 seconds
