Home » Modeling » TMF (Xtext) » Serialization Issue with Mathematical Expression(When serializing EObjects more the wrong rule is taken from my grammar)
Serialization Issue with Mathematical Expression [message #1273046] Wed, 19 March 2014 11:49 Go to next message
Marcus Höpfner is currently offline Marcus HöpfnerFriend
Member
I have a grammar for mathematical expressions (formula) generated from my Ecore model.
When serializing a certain expression from EObject it uses the wrong ParserRule which results in a wrong formula string.
I cutted it down to what is relevant.
Here is the grammar:
grammar org.xtext.example.math.Math with org.eclipse.xtext.common.Terminals
import "http://www.eclipse.org/emf/2002/Ecore" as ecore
generate math "http://www.eclipse.org/example/math/Math"
FormulaDefinition returns FormulaDefinition:
	{FormulaDefinition}
	formulaToken=FormulaToken?;
FormulaToken returns FormulaToken:
	Prio1Operation;
Prio1Operation returns FormulaToken: // like +
	InfixOperand ({FormulaOperator.childToken+=current} code=InfixOperatorPrio1
	childToken+=InfixOperand)*;
InfixOperand returns FormulaToken:
	'(' FormulaToken ')' | FormulaConstant | PrefixOperation2Operands;
PrefixOperation2Operands returns FormulaOperator:
	code=PrefixOperator2Operands '(' childToken+=FormulaToken ',' childToken+=FormulaToken ')';
InfixOperatorPrio1 returns ecore::EString:
PrefixOperator2Operands returns ecore::EString:
	'MAX';
FormulaConstant returns FormulaConstant:
	value=INT;
Here is the test which fails:
	@Test
	def void testTwoArgPrefixOperation() {
		val op = MathFactory.eINSTANCE.createFormulaOperator
		op.code = 'MAX'
		var arg1 = MathFactory.eINSTANCE.createFormulaConstant
		arg1.value = 5
		op.childToken += arg1
		var arg2 = MathFactory.eINSTANCE.createFormulaConstant
		arg2.value = 8
		op.childToken += arg2
		var formulaDef = MathFactory.eINSTANCE.createFormulaDefinition()
		formulaDef.formulaToken = op
		val formula = serializer.serialize(formulaDef)
		assertEquals("MAX ( 5 , 8 )", formula)
The serializer returns
5 MAX 8
instead of expected
MAX ( 5, 8 )
Xtext is assuming an Prio1Operation instead of PrefixOperator2Operands.
BTW: I formula expressing 5 + 8 is working as expected!
I was already able to solve by either
1.) Create new EMF-Objects which inherit from FormulaOperator. These would be FormulaOperatorInfix and FormulaOperatorPrefix and adapt the test accordingly.
	{FormulaDefinition}
	Prio1Operation;
	InfixOperand ({FormulaOperatorInfix.childToken+=current} code=InfixOperatorPrio1
PrefixOperation2Operands returns FormulaOperatorPrefix:
	'MAX';
	value=INT;
2.) Instead of pointing to rule InfixOperatorPrio1 and PrefixOperator2Operands use the strings directly in Prio1Operation and PrefixOperation2Operands in respect. So the grammar would look like this
	{FormulaDefinition}
	Prio1Operation;
	InfixOperand ({FormulaOperator.childToken+=current} code=('+')
	code='MAX' '(' childToken+=FormulaToken ',' childToken+=FormulaToken ')';
	value=INT;
But actally option 1.) I don't want to go.
For option 2.) I wonder why I need to do that. It decreases usability and reuse. I though that there is no difference whether I write a String directly or reference a parser rule (which indeed returns a unique return).
Is there any other solution or way I can force Xtext to kind of "follow" the rules containing the operators.
Thanks, Marcus
Re: Serialization Issue with Mathematical Expression [message #1287141 is a reply to message #1273046] Mon, 07 April 2014 12:57 Go to previous messageGo to next message
Pawel Pogorzelski is currently offline Pawel PogorzelskiFriend
Member
Marcus,
try looking here:
ISequenceAcceptor.acceptAssignedDatatype
Maybe these two require modifications as well:
ElementMatcherProvider.getAllStates
ElementMatcherProvider.matchNext
Paweł
Re: Serialization Issue with Mathematical Expression [message #1287153 is a reply to message #1287141] Mon, 07 April 2014 13:13 Go to previous message
Member
Marcus,
one more thing. In general flattering your model with:
is not the best idea. It creates more problems than solves. And the three pointers I gave you in the previous reply might not the only code that requires modifications. In this case I'd simply use a dedicated type for the operator.
Previous Topic:Importing implicit global scope
Next Topic:XtextCON
Current Time: Thu Apr 25 18:02:50 GMT 2024
Powered by FUDForum. Page generated in 5.04001 seconds
