Setting up default project setup preferences [message #1271936] |
Sun, 16 March 2014 12:52  |
So a lot of Android developers have been running into the "problem" where the appcompat_v7 library is getting created in the eclipse workspace with every application, even if the application doesn't need it (is API 11+). Apparently, this is because the the recent sdk update has told the eclipse plugin that this is a good idea. I have seen a few articles talk about how it is a good idea to keep the library, but that you can edit what libraries are included by default on a project build. This is really intriguing to me as I often create multiple projects in sequence that utilize the same/similar libraries. However, I can't seem to find any information on how to actually do this. Does anyone know how to set what eclipse does by default on the creating of a project, specifically when it comes to dependencies?
Re: Setting up default project setup preferences [message #1271983 is a reply to message #1271936] |
Sun, 16 March 2014 16:00  |
An Eclipse Java project and Dynamic Web Project organize their
particulars along these lines in the .classpath file in the project.
This file is almost empty immediately after the new-project wizard runs.
It's been a while since I wrote Android software. I don't remember the
exact details, which may have changed anyway, of how a new Android
project is set up, but I'm pretty certain it's the ADT plug-in that
controls or implements the new-project wizard. For this reason, you'll
likely get more help with this question in an Android forum.
FUDForum. Page generated in 0.09355 seconds
