Home » Newcomers » Newcomers » Source Code(Where to find example source code)
Source Code [message #1271830] Sun, 16 March 2014 05:42 Go to next message
I am an absolute beginner in both Java and Android. However I am experienced in windows/web application. I was brought up on things like PERL, Fortran C Basic. So I am clearly an oldie, but do understand the logic of programming.
I downloaded the eclipse bundle for windows, then found it was not complete, as I then had to find and download the JDK. OK no problem with that, but a link to the JDK would be helpful.
What I would like now, if possible, is to know a place where I can download sample code. I find things so much easier if I have some code to play around with. Does such a place exist ?
Thank you in advance
Re: Source Code [message #1271913 is a reply to message #1271830] Sun, 16 March 2014 11:49 Go to previous messageGo to next message
You should be aware that ADT is written on top of the Eclipse platform
by Google and community but is not a product/project that is supported
by eclipse.org. Any questions about installing ADT, using ADT, or
otherwise related specifically to Android development, should not be
asked here because they'll likely go unanswered. Instead, use one of the
Android-specific forums. Here are some links to help you find the right
place:
http://developer.android.com/resources/community-groups.html
http://stackoverflow.com/questions/tagged/android
http://www.anddev.org/
http://androidforums.com/application-development/
In addition, there are many, many tutorials for Android out there.
Google is your friend.
Best,
Re: Source Code [message #1271929 is a reply to message #1271913] Sun, 16 March 2014 12:32 Go to previous message
Thank you for the guidance and the links. I'm sorry to have mistakenly broached this topic on this forum. Clearly, I wrongly assumed that a forum on the eclipse site (www.eclipse.org) would be the right place to get some help on the eclipse program/environment and/or examples of android/java source code. My sincere apologies for my mistake in this conflict of names.
Once again thank you for the links. I am sorry to have disturbed you. I shall not bother you again.
Previous Topic:JRE or JDK must be available ERROR
Next Topic:Eclipse Arduino IDE problem
Current Time: Wed Jul 16 14:36:38 EDT 2025
Powered by FUDForum. Page generated in 0.09119 seconds
