Re: XML with DTD and XML Schema [message #211280 is a reply to message #211233] |
Fri, 28 March 2008 15:26 |
Originally posted by: dcarver.starstandard.org
I haven't tried this, but have you tried defining the entity declaration
within the XML itself and not calling the DTD. Does the content
assistance work for the XML schema as well as for the entity?
x86core wrote:
> I have an XML that has a DTD declaration and also uses schemas with
> different namespaces. The DTD contains only entity references while the
> structure/grammar of the document is defined by schemas. While editing
> the xml in the XML editor (bundled with WTP), the content assist and
> validation work based only on the DTD. The schemas are ignored even if
> the root element comes from one of the referenced schemas.
> The content assist and every thing else work as desired (correct
> proposals, warning, errors, etc) when the DTD declaration is removed. I
> assume that when both DTD and XML schema are used in the instance
> document, the XML editor considers only the DTD. Is it possible to
> configure this feature so that both DTD and xml schemas are used. If
> need be I�ll extend SSE to provide an editor for the requirement. Any
> help is greatly appreciated.
> Thanks in advance.
Re: XML with DTD and XML Schema [message #211292 is a reply to message #211287] |
Fri, 28 March 2008 17:06 |
Have you tried adding your DTD's public identifer to the XML catalog....
I think you may have to open a bug/enhancement request for this feature,
as I don't think the current loaders support both DTD and XSD mixtures.
You might be able to get around it by adding your DTD to a XML
catalog, and the same with your XSD. This way when you hit the
namespace for your XSD it can load via the namespace.
Dave
x86core wrote:
> Hi David,
> The inline DTD does affect the content assist in some way; it
> appears to offer completion for elements only. However that is not what
> I was looking for. To be precise, in my case it is required to separate
> out the entity declaration into an external DTD and reference them in
> the xml. I would like the content assist to look up the DTD and the XML
> schema as well. If that were not possible, then ignore the DTD (since it
> has entity declarations only) and offer content assistance for the
> namespace(d) elements in XML. Is there a preference setting that I am
> overlooking? Or is it possible to accomplish by extending the XML
> editor? Thanks.
Re: XML with DTD and XML Schema [message #211344 is a reply to message #211330] |
Sat, 29 March 2008 21:33 |
You could dynamically load the DTD if you knew the content type for the
XML file (i.e. it's always a particular type like XSL, DOCBOOK, etc),
and then dynamically load the DTD based on content type.
I think a bug should be opened to request that if a DTD and a XML Schema
are referenced, that both content models should be available. I think
currently the code is doing one or the other, but there are plenty of
use cases like yours that will have the need to intermix the two.
Dave
x86core wrote:
> Thanks Dave. I am afraid I cannot take the xml catalog approach as the
> DTD changes with XML.I haven�t looked much into it yet, but with a
> little exploration I ended up looking at some code in
> org.eclipse.wst.xml.core plug-in. Of interest is the following snippet
> from
> org.eclipse.wst.xml.core.internal.contentmodel.modelqueryimp l.CMDocumentLoader:
> public void loadCMDocuments()
> { //System.out.println("----------loadCMDocuments
> //long time = System.currentTimeMillis();
> boolean walkDocument = false;
> cmDocumentManager.removeAllReferences();
> String[] doctypeInfo =
> XMLAssociationProvider.getDoctypeInfo(document);
> if (doctypeInfo != null)
> // load the doctype if required
> walkDocument = handleGrammar(doctypeInfo[0], doctypeInfo[1],
> "DTD"); //$NON-NLS-1$
> } else
> { Element element =
> getRootElement(document);
> if (element != null)
> namespaceTable = new CMDocumentLoadingNamespaceTable(document);
> namespaceTable.addElement(element);
> if (namespaceTable.isNamespaceEncountered())
> { walkDocument = true;
> //System.out.println("isNamespaceAware");
> else
> namespaceTable = null;
> walkDocument = isInferredGrammarEnabled;
> //System.out.println("is NOT namespaceAware");
> if (walkDocument)
> visitNode(document); }
> //System.out.println("--- elapsed time (" + count + ") = " +
> (System.currentTimeMillis() - time));
> Is it possible to make a few modifications (loaders and content assist
> classes) and achieve the desired behaviour? Or would the change span
> several classes with possible side-effects? It would be helpful to have
> some feedback. I could use my own build of the plug-ins until the
> feature is implemented. Thanks again.
FUDForum. Page generated in 0.03122 seconds
