Home » Newcomers » Newcomers » A fatal error has been detected by the Java Runtime Environment:
A fatal error has been detected by the Java Runtime Environment: [message #1271473] Sat, 15 March 2014 04:01 Go to next message
I got this problem while working in eclipse kepler.I'm using jdk 7u51.Could any one help me out of this problem.
Re: A fatal error has been detected by the Java Runtime Environment: [message #1271633 is a reply to message #1271473] Sat, 15 March 2014 14:33 Go to previous messageGo to next message
This question doesn't really have anything to do with Eclipse.
It looks like the VM crashed while going into some native code. You should file a bug report as the instructions in the log suggest, or contact Microsoft for support.
Re: A fatal error has been detected by the Java Runtime Environment: [message #1272152 is a reply to message #1271633] Mon, 17 March 2014 03:35 Go to previous messageGo to next message
Is there any alternative way to complete my project after reporting bug?or should i wait till fixing.....
Re: A fatal error has been detected by the Java Runtime Environment: [message #1272238 is a reply to message #1272152] Mon, 17 March 2014 08:41 Go to previous messageGo to next message
I can only suggest you see if there are other (newer?) drivers for the SQL server that don't make use of native libraries, or try using a different SQL server entirely.
[Updated on: Mon, 17 March 2014 08:41] by Moderator
Re: A fatal error has been detected by the Java Runtime Environment: [message #1272648 is a reply to message #1272238] Tue, 18 March 2014 08:05 Go to previous messageGo to next message
thank you Sir.
Re: A fatal error has been detected by the Java Runtime Environment: [message #1272960 is a reply to message #1272648] Wed, 19 March 2014 03:12 Go to previous messageGo to next message
Now i changed my DB to MS access.I got the following error "java.lang.ClassNotFoundException: sun.jdbc.odbc.JdbcOdbcdriver".
I heard that Ms Access need not require separate jars while working with java.But due to this error i included rt.jar in libraries, still i'm getting the same error.Can any one help me out?
Re: A fatal error has been detected by the Java Runtime Environment: [message #1273079 is a reply to message #1272960] Wed, 19 March 2014 09:06 Go to previous messageGo to next message
To repeat what Nitin said before, these forums are for discussions related specifically to Eclipse. You should ask general programming questions on a general programming forum, such as Stack Overflow.
Re: A fatal error has been detected by the Java Runtime Environment: [message #1273103 is a reply to message #1273079] Wed, 19 March 2014 10:15 Go to previous message
k sir.Thank u.
Previous Topic:Different results between running in eclipse and run in DOS
Next Topic:Licease transfer/upgrade?
Current Time: Mon Jul 07 23:25:05 EDT 2025
Powered by FUDForum. Page generated in 0.13190 seconds
