Re: how to add TabbedPropertySheetPage like wtp in my GEF project ? [message #213979 is a reply to message #210923] |
Wed, 12 April 2006 07:31 |
Originally posted by: cadu.codetic.com
heima2008 a écrit :
> how to add TabbedPropertySheetPage like wtp in my GEF project?
> someone has done with it ??
> thx
> welcome any replies!
hello heima2008,
i've the same problem than you, i want to use property tabs to edit a
GEF model
did you acheive in doing it ?
i've like to get an example showing how does it work
mygsm
Re: how to add TabbedPropertySheetPage like wtp in my GEF project ? [message #214022 is a reply to message #213979] |
Wed, 12 April 2006 14:00 |
Originally posted by: tmxk2008.gmail.com
it needs to define in plugin.xml and write yourself's section,and sectionfilter, and your ediotr must implements ITabbedPropertySheetPageContributor interface. Generally your section extends AbstractPropertySection class;
following is my code:
<?eclipse version="3.0"?>
<plugin>
<extension
point="org.eclipse.ui.editors">
<editor
class="org.beamframework.codegen.ui.gef.editor.ModelEditor"
icon="index.gif"
default="true"
contributorClass=" org.beamframework.codegen.ui.gef.action.DiagramActionBarCont ributor "
name="ModelEditor"
id="org.beamframework.codegen.ui.gef.editor.ModelEditor"
extensions="bml"/>
</extension>
<extension
point="org.eclipse.ui.views.properties.tabbed.propertyContributor ">
<propertyContributor
typeMapper="org.beamframework.codegen.ui.gef.editor.ElementTypeMapper "
contributorId="org.beamframework.codegen.ui.gef.editor.ModelEditor "
labelProvider=" org.beamframework.codegen.ui.gef.editor.PropertySheetLabelPr ovider ">
<propertyCategory
category="element">
</propertyCategory>
<propertyCategory
category="other">
</propertyCategory>
</propertyContributor>
</extension>
<extension
point="org.eclipse.ui.views.properties.tabbed.propertyTabs" >
<propertyTabs
contributorId="org.beamframework.codegen.ui.gef.editor.ModelEditor ">
<propertyTab
label="Advanced"
category="other"
afterTab="logic.tab.GefMetaModel"
id="logic.tab.Advanced">
</propertyTab>
<propertyTab
label="Diagram"
category="other"
id="logic.tab.Diagram">
</propertyTab>
<propertyTab
label="GefMetaModel"
category="other"
afterTab="logic.tab.Diagram"
id="logic.tab.GefMetaModel">
</propertyTab>
<propertyTab
label="Property"
category="other"
id="logic.tab.GefProperty">
</propertyTab>
<propertyTab
label="Relation"
category="other"
id="logic.tab.GefConnection">
</propertyTab>
</propertyTabs>
</extension>
<extension
point="org.eclipse.ui.views.properties.tabbed.propertySections ">
<propertySections
<propertySection
tab="logic.tab.Diagram"
filter=" org.beamframework.codegen.ui.gef.editor.section.DiagramSecti onFilter "
class=" org.beamframework.codegen.ui.gef.editor.section.DiagramSecti on "
id="logic.section.Diagram">
<input
type="org.beamframework.codegen.ui.gef.model.Diagram">
</input>
</propertySection>
<propertySection
tab="logic.tab.GefMetaModel"
filter=" org.beamframework.codegen.ui.gef.editor.section.MetaModelSec tionFilter "
class=" org.beamframework.codegen.ui.gef.editor.section.GefModelSect ion "
id="logic.section.GefMetaModel">
<input
type="org.beamframework.codegen.ui.gef.model.GefMetaModel">
</input>
</propertySection>
<propertySection
tab="logic.tab.GefProperty"
filter=" org.beamframework.codegen.ui.gef.editor.section.GefPropertyS ectionFilter "
class=" org.beamframework.codegen.ui.gef.editor.section.GefPropertyS ection "
id="logic.section.GefProperty">
<input
type="org.beamframework.codegen.ui.gef.model.Property">
</input>
</propertySection>
<propertySection
tab="logic.tab.GefConnection"
filter=" org.beamframework.codegen.ui.gef.editor.section.GefConnectio nSectionFilter "
class=" org.beamframework.codegen.ui.gef.editor.section.GefConnectio nSection "
id="logic.section.GefConnection">
<input
type="org.beamframework.codegen.ui.gef.model.Connection">
</input>
</propertySection>
<propertySection
tab="logic.tab.Advanced"
class=" org.eclipse.ui.views.properties.tabbed.AdvancedPropertySecti on "
id="logic.section.Advanced">
<input
type="org.beamframework.codegen.ui.gef.model.Element">
</input>
</propertySection>
</propertySections>
</extension>
<extension
id="product"
point="org.eclipse.core.runtime.products">
<product
application="org.eclipse.ant.core.antRunner"
name="bsfl"/>
</extension>
</plugin>
FUDForum. Page generated in 0.03065 seconds
