Home » Modeling » GMF (Graphical Modeling Framework) » Remove referenced nodes
Remove referenced nodes [message #210742] Fri, 07 November 2008 14:04 Go to next message
Viktor Kazakov is currently offline Viktor KazakovFriend
Hello!
I want to remove the nodes, referenced by a selected node (and all the
links).
The question is: how to better do this?
There are generally 2 ways to go:
1. Through the model
2. Working just with the graphical nodes.
In 1-st case I should remove the corresponding elements from the model,
using a RecordingCommand. But how to do this right?
In the 2-nd case I need to remove the node from the view. Is there any
way to do so?
And which way is better and more correct?
Thanks!
Viktor Kazakov
Re: Remove referenced nodes [message #210804 is a reply to message #210742] Mon, 10 November 2008 12:01 Go to previous messageGo to next message
Alexander Shatalin is currently offline Alexander ShatalinFriend
Hello Viktor,
> links).
you can do something like:
EditPart editPart = (EditPart) getHost().getViewer().getEditPartRegistry().get(view);
DestroyElementRequest request = new DestroyElementRequest(getEditingDomain(),
false);
Command cmd = editPart.getCommand(new EditCommandRequestWrapper(request,
Collections.EMPTY_MAP));
and then execute this command.
> way to do so?
In GMF we have two different kind of diagrams - synchronized and non-synchronized.
Content of the synchronized diagram will always reflect actual model content,
so you can not remove only visual representation of the node from there.
If you have non-synchronized diagram then content of thsi diagram should
be managed externally (in this case yu can remove only visual representation
of the node keeping the node in a model.
Alex Shatalin
Re: Remove referenced nodes [message #210863 is a reply to message #210804] Tue, 11 November 2008 10:23 Go to previous messageGo to next message
> DestroyElementRequest(getEditingDomain(), false);
> EditCommandRequestWrapper(request, Collections.EMPTY_MAP));
Cool! Maybe I can create the element in a similar way? That is what I
was asking about just a moment before.
> non-synchronized. Content of the synchronized diagram will always
> reflect actual model content, so you can not remove only visual
> should be managed externally (in this case yu can remove only visual
> representation of the node keeping the node in a model.
For now I think I just can make nodes non-visible and use synchronized
model (thanks for the hint before!). But in future maybe we'll have to
switch to non-synchronized model to get more fine-grained control. Is
there any manual / tutorial on non-synchronized model?
Viktor
Re: Remove referenced nodes [message #210880 is a reply to message #210863] Tue, 11 November 2008 11:21 Go to previous message
Hello Viktor,
Try using "CreateElementRequest".
Unfortunately now. But in general you should just switch one property in
a .genmodel and regenerate the code. As a result diagram synchronization
will be switched off. In addition you can find this document useful http://wiki.eclipse.org/GMF_GenModel_Hints.
Alex Shatalin
Previous Topic:Cannot open logic example diagram
Next Topic:Shared Editing Domain disposed when closing editor
Current Time: Sat Feb 27 04:20:36 GMT 2021
Powered by FUDForum. Page generated in 0.01472 seconds
