Home » Eclipse Projects » Mylyn » Hudson server connexion issue
Hudson server connexion issue [message #1268517] Mon, 10 March 2014 16:04 Go to next message
Tony Hedoux is currently offline Tony HedouxFriend
I would like to connect Eclipse with an Hudson server. But I failed to etablish a connexion. When I validate the server information, the error msg is :
Server validation failed: Unexpected error: Forbidden
Hudson server authentification is based on LDAP, and according to this post (http://www.eclipse.org/forums/index.php/t/478730/) I already try to disable the "Cross Site Request Forgery prevention" in Hudson. It does not correct the issue.
Test has been done with both direct authentification and HTTP one.
Hudson version used is 3.0.1.
Thanks for help,
Tony
ALL4TEC
Re: Hudson server connexion issue [message #1277346 is a reply to message #1268517] Tue, 25 March 2014 21:59 Go to previous messageGo to next message
Tomasz Zarna is currently offline Tomasz ZarnaFriend
What version on Mylyn Build are you using? Any chance for the full stack trace? Is the server you're trying to connect publicly available?
Re: Hudson server connexion issue [message #1392637 is a reply to message #1268517] Wed, 02 July 2014 16:28 Go to previous message
tony hedoux is currently offline tony hedouxFriend
Sorry for the late answers Smile
The full stack trace is in attachment.
The server is a private one.
Tony
Previous Topic:How to include an issue active time from mylyn to the commit message?
Next Topic:htmltext example
Current Time: Sat Jul 11 09:14:36 GMT 2020
Powered by FUDForum. Page generated in 0.02372 seconds
