Home » Eclipse Projects » GEF » TextFlow doesn't return correct height from getPreferredSize()
TextFlow doesn't return correct height from getPreferredSize() [message #210319] Fri, 24 February 2006 16:14 Go to next message
I have a custom figure with a FlowPage contianing 2 TextFlows with
different fonts. For some reason the TextFlows layout correctly width-wise
and wrap if they are supposed to, but when my custom figure returns the
sum of the height of the TextFlows called by getPreferredSize(-1,-1) it
gets the size as if the TextFlows were on one line. I notice that this is
because the Figure.bounds variable of the TextFlows are already set. If I
repaint the figure (My canvas is in a ScrolledForm that gets reflow()'ed)
the TextFlow's bounds gets set correctly.
Any idea why this might be happening. I understand that InlineFlows get
laid out differently than most figures.
TIA,
Nate
Re: TextFlow doesn't return correct height from getPreferredSize() [message #210337 is a reply to message #210319] Sat, 25 February 2006 11:38 Go to previous message
Any time you call getPreferredSize, the current state of the figure is not
important. You are asking the figure for its size with no width (or height)
constraint. The result is that everything will be on 1 line. If you want the
preferred size with wrapping, tell it where to wrap with wHint.
"Nathan Snapp" <nathan.snapp@altiris.com> wrote in message
news:0ec65e0f1066fe6e24a74776eff50688$1@www.eclipse.org...
>and wrap if they are supposed to, but when my custom figure returns the sum
>of the height of the TextFlows called by getPreferredSize(-1,-1) it gets
> TIA,
> Nate
Previous Topic:How can I reverse the direction of the Y axis?
Next Topic:How do i add Alignment Actions etc. ?
Current Time: Sun Jul 20 07:11:14 EDT 2025
Powered by FUDForum. Page generated in 0.03817 seconds
