Home » Modeling » QVT-OML » helper with side effect in QVT - OML(helper with side effect in QVT - OML)
helper with side effect in QVT - OML [message #1267828] Sun, 09 March 2014 16:59 Go to next message
Ben Haldo is currently offline Ben HaldoFriend
According to QVT - operational specification, a helper with side effect can be declared as:
helper computeCandidates(inout studentList:Sequence(String)) : Sequence(String) {
var newStudent:String := "a new Student";
studentList += newStudent;
return studentList;
But in eclipse QVTO transformation project, This crates an error stating:
"Can't assign a value to 'inout' parameter 'studentList'"
Any ideas on how to fix this?
Re: helper with side effect in QVT - OML [message #1267878 is a reply to message #1267828] Sun, 09 March 2014 18:39 Go to previous messageGo to next message
Use a mutable Collection; ie. List.
Ed Willink
> Sequence(String) {
> return studentList;
Re: helper with side effect in QVT - OML [message #1269788 is a reply to message #1267828] Wed, 12 March 2014 07:38 Go to previous message
Sergey Boyko is currently offline Sergey BoykoFriend
Hi Ben,
Ben Haldo wrote on Sun, 09 March 2014 12:59
return studentList;
This is certainly valid script.
You must switch to the recent QVTo version (most reasonable is to use 3.4.0 M6 http://www.eclipse.org/mmt/downloads/index.php?project=qvto&showAll=0&showMax=5).
Then helper will be compiled and executed without errors.
main() {
  var list = Sequence{};
  var list2 = computeCandidates(list);
  assert (list2 = Sequence{"a new Student"});
Sergey.
Previous Topic:Running qvto Transformations with in/out Metamodels registered by Metamodel-Plugins
Next Topic:Adding qvto editor in RCP application
Current Time: Mon Jan 18 07:59:14 GMT 2021
Powered by FUDForum. Page generated in 0.03065 seconds
