Re: ETL trafo plug-in - no target model visible [message #1269836 is a reply to message #1268952] |
Wed, 12 March 2014 08:39 |
Hi Alexander,
When I run your code on Model_Fowler.uml in a new workspace, I get the following exception.
at org.eclipse.core.internal.runtime.Activator.getURLConverter(Activator.java:321)
at org.eclipse.core.runtime.FileLocator.toFileURL(FileLocator.java:205)
at de.uni.due.swe.propman.propgen.pcm2pcptrafo.handler.BaseHandler.getFileInBundle(BaseHandler.java:229)
at de.uni.due.swe.propman.propgen.pcm2pcptrafo.handler.BaseHandler.executeEtl(BaseHandler.java:179)
at de.uni.due.swe.propman.propgen.pcm2pcptrafo.handler.BaseHandler$1.run(BaseHandler.java:265)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
To speed things up, it'd be useful if you could strip your example down (400+ lines of code hardly qualifies as "minimal" ) to the bare essentials.
Dimitris
FUDForum. Page generated in 0.02159 seconds
