Re: Why are my children and edges null when i get my diagram not usingan editor? [message #210223 is a reply to message #210210] |
Fri, 31 October 2008 22:17 |
Brian Jakubik Messages: 140 Registered: July 2009 |
OK, after more research I realized I can add a CrossReferenceAdapter to
my ResourceSet, I think I have everything I need, however I will play
with it more on Monday. Thanks for the help.
B
Brian Jakubik wrote:
> Alex thanks for the reply, I did find that my connection was transient,
> and after changing it to false, it appeared in the diagram file, and
> persisted children and persisted edges were in my inspected DiagramImpl.
> However, passing that to ValidateAction still results in incorrect
> validation results...
> An example is we have validation that checks that particular nodes have
> incoming connections, it is being validated incorrectly saying it has no
> incoming connections although it does. This may be in part because I
> cannot get a CrossReferenceAdapter from the EObject I'm validating when
> I validate not through the editor...
> Any more ideas?
> Thanks
> B
> Alex Shatalin wrote:
>> Hello Brian,
>> Can you check that the diagram content (child nodes) was actually
>> stored into this file? If all the diagram nodes are "transient" then
>> seved diagram will be empty.
>> Alex Shatalin
FUDForum. Page generated in 0.02870 seconds
