| [ECP] Trouble viewing new model elements [message #1266757] |
Fri, 07 March 2014 18:19  |
I am have trouble viewing new model elements or double clicking on existing model elements to edit them. The tab comes up but no data is displayed to the user.
I am trying to replace the model explorer with my own, but use the ECP editors. Also I have no repository explorer since the repository will be fixed.
I have gotten EMF Client 1.1 installed and working on Eclipse 3.8.2. Every thing installed but the model views which I put in dropins.
I have a small application that consists of just application3x and things work well on it with the same model that does not display data. I am using the right click to create the new model elements and reading the data via ECP.
Has anybody run into this problem?
Thanks Susan
| Re: [ECP] Trouble viewing new model elements [message #1267106 is a reply to message #1266757] |
Sat, 08 March 2014 08:11  |
I am sorry, I am not sure, if I fully understand your set-up. Are you
trying to create an RCP app based on ECP or are you trying to use ECP
within the IDE? Where do you double clicke the model element and what do
you mean by "the tab comes up?" are there any error in the console or
error log?
Have you re-tested with 1.2?
Best Regards
Jonas
Am 08.03.2014 00:19, schrieb Susan Carswell-Hurdis:
> be fixed.
> the data via ECP.
> Has anybody run into this problem? Thanks Susan
FUDForum. Page generated in 0.03168 seconds
