Home » Eclipse Projects » GEF » How do I resize an element and the element inside it?
How do I resize an element and the element inside it? [message #209872] |
Mon, 20 February 2006 18:24 |
Originally posted by: ddv.certi.org.br
If I define a LAYOUT_ROLE to something like XYLayoutPolicy, then I can
resize the children, but not the parent. IF its a ResizableEditPolicy,
the parent can be resized, but not the childres.
Should I implement a new policy? If so, any tips how? I want that
whenever the parent resizes, so does the children. But the opposite is
not always true.
thanks
Re: How do I resize an element and the element inside it? [message #209883 is a reply to message #209872] |
Mon, 20 February 2006 18:39 |
You need to be using the XYLayoutPolicy on the *parents* of anything that
you want to resize. ResizableEditPolicy is not a LAYOUT_ROLE. It is
PRIMARY_DRAG_ROLE.
boa sorte.
"Daniel D. Vanzin" <ddv@certi.org.br> wrote in message
news:dtd1i7$4q0$1@utils.eclipse.org...
> resize the children, but not the parent. IF its a ResizableEditPolicy, the
> Should I implement a new policy? If so, any tips how? I want that whenever
> the parent resizes, so does the children. But the opposite is not always
> true.
> thanks
Re: How do I resize an element and the element inside it? [message #209890 is a reply to message #209883] |
Mon, 20 February 2006 19:27 |
But If I use ResizableEditPolicy as a PRIMARY_DRAG_ROLE, I loose the
selection handles in my element, together with the ability to move/resize.
installEditPolicy(EditPolicy.PRIMARY_DRAG_ROLE, new
ResizableEditPolicy());
installEditPolicy(EditPolicy.LAYOUT_ROLE, new
DiagramLayoutEditPolicy()); /extends XYEditPolicy
Is there something different I should be doing?
thanks
> PRIMARY_DRAG_ROLE.
> boa sorte.
>> true.
>> thanks
Re: How do I resize an element and the element inside it? [message #209893 is a reply to message #209890] |
Tue, 21 February 2006 00:18 |
Wait, It appears to have worked for now. I used SELECTION_ROLE_FEEDBACK.
Later I will try to make everything else to worl
> thanks
>> that you want to resize. ResizableEditPolicy is not a LAYOUT_ROLE. It
>> is PRIMARY_DRAG_ROLE.
>> boa sorte.
>>> can resize the children, but not the parent. IF its a
>>> ResizableEditPolicy, the parent can be resized, but not the childres.
>>> is not always true.
>>> thanks
Re: How do I resize an element and the element inside it? [message #209997 is a reply to message #209893] |
Tue, 21 February 2006 18:53 |
Now resizing/moving works fine, but I can't see the feedback (the gray
rectangle)! I'm using a XYLayoutEditPolicy. Should I ovewrite something?
thanks
>> move/resize.
>> thanks
>>> boa sorte.
>>>> is not always true.
>>>> thanks
Re: How do I resize an element and the element inside it? [message #210013 is a reply to message #209997] |
Tue, 21 February 2006 21:58 |
It sounds like you might have two of the same policies installed. resize
feedback is XOR, so if it paints twice, it will erase itself.
ResizableEditPolicy should be created inside the LayoutEditPolicy in
createChildEditPolicy(...). You shouldn't install it from the editpart.
news:dtfnkp$d47$1@utils.eclipse.org...
> thanks
>>> move/resize.
>>> thanks
>>>> boa sorte.
>>>>> not always true.
>>>>> thanks
Current Time: Thu Apr 25 05:05:27 GMT 2024
Powered by FUDForum. Page generated in 0.03565 seconds
