Re: Another bug - could not load the Tomcat server configuration [message #209795] |
Thu, 06 March 2008 14:47 |
Originally posted by: eclipse-news.rizzoweb.com
This question is not appropriate for the eclipse.foundation newsgroup;
I've redirected it to eclipse.webtools
Vijay wrote:
> Hi there,
> There is another bug related to tomcat server in eclipse.
> I get the following error:
> Publishing failed
> Could not load the Tomcat server configuration at \Servers\Tomcat v5.5
> Server @ localhost-config. The configuration may be corrupt or incomplete.
> I am in Windows XP system logged in as admin user.
> After going through all the bug reports i figured out the issue with all
> the 3 xml files(server.xml,tomcat-users.xml, web.xml) which are copied
> to the server directory. String "<!DOCTYPE Server SYSTEM "null">" is
> appended in all the xml files (End of file)...
> [workspace]Servers\Tomcat v5.5 Server @ localhost-config
> server.xml
> ========== <Context docBase="spring" path="/spring"
> reloadable="true" source="org.eclipse.jst.j2ee.server:spring"/></Host>
> </Engine>
> </Service>
> </Server><!DOCTYPE Server SYSTEM "null">
> tomcat-users.xml
> <user password="tomcat" roles="role1" username="role1"/>
> </tomcat-users><!DOCTYPE tomcat-users SYSTEM "null">
> web.xml
> </web-app><!DOCTYPE web-app SYSTEM "null">
> I tried removing these string and starting the server. Then the error
> was little different :
> Publishing failed
> Resource is out of sync with the file system: /Servers/Tomcat v5.5
> Server @ localhost-config/server.xml.
> What might be the problem pls help me to solve this issue...
> Set up
> OS Windows XP
> Eclipse version : Eclipse SDK Version: 3.2.2 Build id: M20070212-1330
> Tomcat version : 5.5
> Thank you,
> Vijay
FUDForum. Page generated in 0.03419 seconds
