"Program does not exist" [message #209720] |
Thu, 14 February 2008 17:49 |
Originally posted by: ron_e.novax.com
In the run manager i get the message "Program does not exist". How do i
know what 'program' this refers to? The C/C++ Aaapplication doesn't exist
yet since it hasn't been compiled yet but i belive it must refer to
something else.
The Error log doesn't give a whole lot of more info either:
java.io.FileNotFoundException: /home/reg/src/prg-new/Debug/prg-new not
found
at
org.eclipse.cdt.launch.AbstractCLaunchDelegate.verifyProgram Path(AbstractCLaunchDelegate.java:369)
at
org.eclipse.cdt.launch.internal.LocalCDILaunchDelegate.runLo calApplication(LocalCDILaunchDelegate.java:76)
at
org.eclipse.cdt.launch.internal.LocalCDILaunchDelegate.launc h(LocalCDILaunchDelegate.java:62)
at
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:639)
at
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:565)
at
org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:754)
at
org.eclipse.debug.internal.ui.DebugUIPlugin$6.run(DebugUIPlu gin.java:944)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)
I'm not really sure about this so any help would be greatly appreciated!
Ron
Re: "Program does not exist" [message #209729 is a reply to message #209720] |
Thu, 14 February 2008 20:21 |
Originally posted by: jim.marshall.wbemsolutions.com
Ron Eggler wrote:
> exist yet since it hasn't been compiled yet but i belive it must refer
> to something else.
> found
> at
> at
> at
> at
> at
> at
> at
> Ron
I would presume the error message tells you what is missing:
'prg-new'
see the 'java.io.FileNotFoundException' text.
It would also help if you gave some context as to when/how this message
pops up - e.g. what are you doing before this message appears...
Re: "Program does not exist" [message #209752 is a reply to message #209729] |
Thu, 14 February 2008 22:41 |
Jim Marshall wrote:
> Ron Eggler wrote:
>> Hi,
>> to something else.
>> found
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Thanks,
>> Ron
> 'prg-new'
Right, of course it doesn't exist, it hasn't been compiled yet.
It pops up in the Run Manager or how ever this is called, you know in
"Run-Run..." on top when you select your project's Run configuration under
"C/C++ Local Application".
Re: "Program does not exist" [message #209863 is a reply to message #209752] |
Fri, 15 February 2008 23:42 |
Ron Eggler wrote:
> Jim Marshall wrote:
>> Ron Eggler wrote:
>>> Hi,
>>> i know what 'program' this refers to? The C/C++ Aaapplication doesn't
>>> refer to something else.
>>> not found
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Thanks,
>>> Ron
>> 'prg-new'
>> message pops up - e.g. what are you doing before this message appears...
> under "C/C++ Local Application".
Just curious - have you tried doing a "Build->Build Project"? Also be
sure "Build->Build Automatically" is selected.
FUDForum. Page generated in 0.02809 seconds
