Changing diagram resolution [message #209328] |
Thu, 23 October 2008 20:28 |
Originally posted by: d.kleinrath.inode.at
Is there any way to change the resolution of a GMF diagram so I can
display and print high quality images in my editor?
When I create a default editor the resolution of a Din A4 diagram seems to
be about 1000x700 pixel (~85 DPI). This is a very low quality for
displaying/printing images so I'd like to use diagrams with 300 DPI or
more in my editor.
Thanks for your help,
Dieter
Re: Changing diagram resolution [message #209430 is a reply to message #209351] |
Fri, 24 October 2008 11:11 |
Thanks Anthony,
You mean that implementing a way to save higher quality image files also=
means that the resolution of the diagram needs to be changeable as a =
whole? So one should be able to insert higher quality bitmaps into the =
diagram once this is fixed?
Dieter
> Hi Dieter
> This is https://bugs.eclipse.org/bugs/show_bug.cgi?id=3D139574
> Cheers...
> Anthony
> "Dieter Kleinrath" <d.kleinrath@inode.at> wrote in message
> news:op.ujhu5xe8pj7es5@ben-f9ea5088efe...
>> Hi,
>> When I create a default editor the resolution of a Din A4 diagram see=
ms =
>> to
>> displaying/printing images so I'd like to use diagrams with 300 DPI o=
r
>> more in my editor.
>> Dieter
FUDForum. Page generated in 0.02939 seconds
