Using WSDL Explorer with a wsdl that incorporates Transport-Level/SSL Security [message #209243] |
Thu, 28 February 2008 23:01 |
Originally posted by: jryding.us.ibm.com
I have been trying to access the web services of a WSDL file that uses
https to access the web services. When I try to submit a query with this
security i get the following error:
IWAB0135E An unexpected error has occurred.
javax.net.ssl.SSLHandshakeException
sun.security.validator.ValidatorException: PKIX path building failed:
sun.security.provider.certpath.SunCertPathBuilderException: unable to find
valid certification path to requested target
I found this newsgroup message from 2005 that solves the problem of being
able to access the web service over https:
http://dev.eclipse.org/newslists/news.eclipse.webtools/msg08 577.html
My problem is how can I acquire the SSL certificate on my computer so that
I can have my web services talk to the server I that holds the data I
need? I have no access to the server and I am using the web services that
they supply. All that their site says is that for their WSDL file, it
uses transport-level security (HTTPS) and a username and password token to
secure access the information, nothing else on how to utilize it other
than this link to developerWorks:
http://www-128.ibm.com/developerworks/websphere/library/tech articles/0504_cowan/0504_cowan.html
Which does not explain how to enable this stuff with eclipse or acquire
the SSL certificate to a server that I have no access to whatsoever.
Any ideas?
Thank you.
Re: Using WSDL Explorer with a wsdl that incorporates Transport-Level/SSL Securi [message #209417 is a reply to message #209259] |
Tue, 04 March 2008 00:42 |
I tried the program that was posted on that site, running the following
command from the command line;
java InstallCert <host>
(where <host> is the website i am trying to access) and the only thing
that comes up is:
"Exception in 'main' java.lang.NoClassDefFoundError: InstallCert"
The only thing that I have been able to to change this line of code:
File file = new File("jssecacerts");
from jssecacerts to the path of another file. Does anyone have an idea?
FUDForum. Page generated in 0.03109 seconds
