Home » Modeling » GMF (Graphical Modeling Framework) » Remove cut/copy/paste from Popup
Remove cut/copy/paste from Popup [message #209216] Wed, 22 October 2008 15:28 Go to next message
exquisitus is currently offline exquisitusFriend
Hi all,
I use GMF 2.0 with Eclipse Europa 3.3.
I didn't found how to remove the actions "cut"/"copy"/"paste" from the
popup menu. I know how to remove "deleteFromModel" and "deleteFromDiagram"
like this :
<popupContribution
class=" org.eclipse.gmf.runtime.diagram.ui.providers.DiagramContextM enuProvider ">
<popupStructuredContributionCriteria objectClass="MyEditPart"/>
<popupPredefinedItem id="deleteFromDiagramAction"
remove="true"/>
<popupPredefinedItem id="deleteFromModelAction"
remove="true"/>
</popupContribution>
But what must I specify for actions in sub-menu ?
Sylvain
Re: Remove cut/copy/paste from Popup [message #209251 is a reply to message #209216] Thu, 23 October 2008 05:21 Go to previous messageGo to next message
Prathibha is currently offline PrathibhaFriend
Hi Sylvain,
comment the cut,copy,paste from you plugin.xml.Hope this solves your
problem.
<ElementType
class=" org.eclipse.gmf.runtime.diagram.ui.editparts.IGraphicalEditP art ">
<!-- <GlobalActionId actionId="cut"/>
<GlobalActionId actionId="copy"/>
<GlobalActionId actionId="paste"/> -->
</ElementType>
regards,
Prathibha
Re: Remove cut/copy/paste from Popup [message #209267 is a reply to message #209251] Thu, 23 October 2008 07:51 Go to previous messageGo to next message
paolo russian is currently offline paolo russianFriend
Member
Prathibha ha scritto:
> Hi Sylvain,
> problem.
> <ElementType
> </ElementType>
> regards,
> Prathibha
Hi there, what is the best practice to override these actions? In our
application there's the need to copy & paste an item, and since our
application transforms gmf diagrams in seam web pages via jetemitters,
we provide a objecttype_[timestamp] as node id when one creates an item,
to avoid duplicate id in the webpages.
But happens that if you copy & paste an item these id remain the same
,avoiding somehow the overriden "on creation event" method of the
corresponding
node that would place a new timestamp.
Debugging leads me into thread, runnable methods far away, so where is
the right place to look for me to intercept the "on paste event" method?
Paolo
Re: Remove cut/copy/paste from Popup [message #209275 is a reply to message #209251] Thu, 23 October 2008 08:35 Go to previous messageGo to next message
Thanks you Prathibha for your answer.
Your solution allows to disable actions in the contextual menu.
BUT, is there a way to remove these actions from the contextual menu ?
like I can do with "deleteFromModel" for example.
More generally, I would like to control the content of the contextual menu.
Re: Remove cut/copy/paste from Popup [message #209293 is a reply to message #209275] Thu, 23 October 2008 09:03 Go to previous message
I have found !
All predefined items can be found in the plugin.xml of
org.eclipse.gmf.runtime.diagram.ui.providers plugin.
So I was able to remove "cut" action for exemple like this :
<popupPredefinedItem id="cut" path="/editMenu/copyGroup" remove="true"/>
Sylvain
Previous Topic:How to create link and node at the same time
Next Topic:Synchronization between editors
Current Time: Wed Mar 03 00:29:58 GMT 2021
Powered by FUDForum. Page generated in 0.01719 seconds
