Re: "document" unresolved for javascript files [message #208890 is a reply to message #208876] |
Thu, 21 February 2008 11:40 |
Kevin McGuire wrote:
> When authoring a Javascript file (e.g. test.js), I get code completion
> fine for javascript'y things like function, var, etc. (great!) but oddly
> a line like
> document.getElementByID("something");
> gets a compile error on 'document' being unresolved.
> Am I missing something that will properly add in resolution to things
> like document?
Possibly. Go to your project's Properties dialog and look for the
Javascript Libraries page. From Libraries tab you'll want to "Add
Runtime Library...", and choose the Base Web Browser Library. That
should make available the browser objects you're used to seeing.
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
_
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: "document" unresolved for javascript files [message #208962 is a reply to message #208915] |
Fri, 22 February 2008 16:41 |
> Final stupid question: shouldn't "document" with a lower case 'd' be
> available in the ECMA bindings?
I think "document" is a variable only available if you set the super
type to a web Browser object. I don't know what "Document" refers
to, but I'm guessing it is a W3C DOM object, but then I'm not an
expert in Javascript. For all I know they're unrelated.
Nitin Dahyabhai
IBM Rational
_
Nitin Dahyabhai
Re: "document" unresolved for javascript files [message #209072 is a reply to message #209065] |
Mon, 25 February 2008 18:07 |
Kevin McGuire Messages: 12 Registered: July 2009 |
Thanks Bradley! By selecting the project and going into
Properties->JavaScript Libraries -> Global Order/Super Type and changing
the dropdown at the bottom of that page to "Window" I now have my little
example working.
I'll comment though that this isn't at all obvious (apparently <g>). So
there's some usability concern around getting novice developers going
quickly.
Thanks again,
Kevin McGuire
Bradley Childs wrote:
> The super type of a project is the type who's fields / methods are inherited
> by all .js (and .html files if in a web project).
> By definition for .js files the super type is (an instance of) the Global()
> object. When JavaScript is running within the context of a browser,
> inheritance is Global()--->Window() and [an instance of]Window() is the
> super type. 'document' is a field in the Window object of type Document().
> -Brad
> "Kevin McGuire" <eclipse@kevin.mcguireclan.net> wrote in message
> news:fpn7ka$tdm$1@build.eclipse.org...
>> Hi Nitin,
>> Thanks for the response. Sorry I don't understand. The super type of
>> whom? I should be able to write:
>> <script type="text/javascript">
>> function doit() {
>> var newString = "hello world";
>> var content = document.getElementById("content");
>> alert(content);
>> content.innerHTML = newString;
>> </script>
>> Both document and alert() get compile errors (yet this is normal legal
>> javascript AFAIK and runs just fine in Firefox).
>> Btw, the "Document" choice is quite odd. Its a browser class alright that
>> you'll find in a Javascript book, but I don't think you typically send
>> static methods to it and code completion offers instance method choices on
>> the static.
>> I've logged:
>> https://bugs.eclipse.org/bugs/show_bug.cgi?id=219886 :: "document" shows
>> as error even with ECMA 3 lib added
>> https://bugs.eclipse.org/bugs/show_bug.cgi?id=219880 :: Code completion
>> offers illegal choices
>> The first one might be a bug or might be a UI issue (not guiding the user
>> to the right configation), the second is definitely fishy.
>> Its a very nice javascript editor otherwise! :)
>> Cheers,
>> Kevin McGuire
>>> I think "document" is a variable only available if you set the super type
>>> to a web Browser object. I don't know what "Document" refers to, but I'm
>>> guessing it is a W3C DOM object, but then I'm not an expert in
>>> Nitin Dahyabhai
>>> IBM Rational
FUDForum. Page generated in 0.02980 seconds
