Should C++ code generation work with Kepler SR2? [message #1261234] |
Sun, 02 March 2014 10:38 |
Joost Kraaijeveld Messages: 273 Registered: July 2009 |
Should C++ code generation, as mentioned in the user guide
(http://wiki.eclipse.org/Codegen_description), work with Kepler SR2?
And if so, are there any dependencies on other plugins (e.g. XTend)? In
an attempt to make it work I tried to re-install the "Papyrus C++
profile, view and code generation (Incubation)" plugin and I noticed
that the update manager ad to change the version of Xtend. I then
assumed it was an upgrade (arrow pointing up), but currently its version
is 1.4.0.v201306110406, which seems to be rather old.
TIA
Joost
Joost
Re: Should C++ code generation work with Kepler SR2? [message #1403651 is a reply to message #1261234] |
Thu, 24 July 2014 20:34 |
The C++ code generation should well work with Kepler SR2.
Currently, the C++ code generation is based on Acceleo and should not imply a dependency to xtend (although we will likely migrate to xtend2 C++ soon).
The message "MissingTextEditorModel" might indicate that the plugin oep.texteditor.model is not active.
If you have the option to install Eclipse Luna, could you please provide feedback if the problems still exist?
FUDForum. Page generated in 0.02087 seconds
