Home » Archived » Java WorkFlow Tooling (JWT) » move to STP
move to STP [message #20115] |
Fri, 03 February 2006 14:15 |
Originally posted by: fabrice.dewasmes.openwide.fr
Hi all,
Following discussions with STP PMC, it appears that we've got three
options for project creation :
- first we have an opportunity to be incubated as part of the STP BPMN
subproject.
- second we can be incubated inside technology project as every other
project and wait to move to a TLP.
- third start being incubated by technology project and move to STP at a
later time.
What are the consequences of the various options ?
In option 2, we are independant from anyone. But this state is expected
to be temporary as we should move to a TLP anyway.
In option 1, we are still 'somehow' independant from the TLP but in
software group that is clearly our concern.
In option 3, we start by being independant and keep the choice to move
to STP at a later time. HOWEVER, if this will be possible only if no
overlapping project exist inside STP at that time.
I *strongly* invite you to take a look at STP proposal at
http://www.eclipse.org/proposals/stp/
and eventually look at STP web site (even if it is really ready yet) at
http://www.eclipse.org/stp/.
Please keep in mind that process/workflow modeling is typically part of
the tools used to achieve SOA and moving to STP could be wise choice.
I wanted to know what you guys think of this and how we should request
the creation review. Anyone listed in the current JWT proposal state is
called to vote so please do so.
Fabrice Dewasmes
Re: move to STP [message #21504 is a reply to message #20115] |
Fri, 03 February 2006 16:47 |
Originally posted by: rzulauf.objeng.ch
Hi Fabrice
Fabrice Dewasmes wrote:
> Hi all,
> subproject.
> later time.
I feel this is a very important decision. The problem I see is that we
wanted to focus on XPDL while STP has the immediate goal of creating and
using BPEL processes.
In my opinion it would be best to get STP to use our editor and
contribute to it if it is missing support for some stuff they need. The
point is that our mission in terms of workflow editor and tooling is a
bit broader than that of STP - I consider WAM for example misplaced in
STP, and they do not have any need for XPDL or differeng graphical
representations.
Therefore my vote is for option 2, if the STP project agrees on using
our editor. If no consensus can be found, then we will be forced into
option 1 as STP clearly has more support from commercial companies at
the moment and I do not think two BPML editors will eventually survive.
However I do not think it is important as to whether we are considered a
subproject of STP or if we are a TLP, as long as:
- we still have somewhat control over our roadmap
- there is no risk of *two* BPML editors being written
Roman
> Best regards,
> Fabrice Dewasmes
confused<--move to STP [message #21522 is a reply to message #21504] |
Fri, 03 February 2006 23:07 |
I also want XPDL and/or even non-standard (pluggable) XML.
XPDL is just superset of BPEL, BPML, etc.
BPEL is linked to WSDL
But :
- SOA is NOT synonym of webservices;
- workflow designers are needed NOT only to specify webservices and SOA!
They are needed first of all for business processes with user interaction
what BPEL lacks!
- webservices is not the means of interoperability in intranet and
webservices make sense for external to enterprise comm. This is specific
problem of Java that Java doesn't have interoperable binary protocols
Well, all this is serious and we should discriminate what doesn't overlap
with others. If GMF (after pushing EMF) satisfies its requirements of
extensibility, interoperability, pluggability and support of different
languages... JWT designer may also be seen as GMF subproject and GMF will
make many parts of STP redundant also
I feel bad about all this scattering and multiplication of centrifugal
projects, framewroks without observable intentions to create integrating
them architecture
Less of all, I want to see JWT designer restricted by webservices/BPEL
Guennadi Vanine
interoperability is not webservices [message #21571 is a reply to message #21522] |
Sun, 05 February 2006 14:13 |
The problem is that webservices in Java platform is synonym of
interoperability and this is wrong policy and distorted concept, if to speak
about general purpose Workflow Designer.
http://elearning4guruscom.ntitemp.com/only4gurus/techlib/mis cellaneous/j2ee_vs_net.pdf
"J2EE vs. NET - An Executive Look"
"Sun's interoperability strategy for J2EE is based on the communications
protocol called IIOP which have the following problems: Only supports J2EE
and CORBA, is not designed to transport over the Internet and current
specification of IIOP is inadequate to ensure interoperability[16].
The.NET platform has a much stronger technology neutral e-Collaboration
strategy than does J2EE.
Inaddition, the .NET platform have a set of application servers that
supports other forms of e-Collaboration..."
Guennadi Vanine
"Guennadi Vanine" <vgv8@yahoo.com.br> wrote in message
news:ds0nn8$sr7$1@utils.eclipse.org...
> But :
> what BPEL lacks!
> them architecture
> Guennadi Vanine
Re: confused<--move to STP [message #21661 is a reply to message #21522] |
Tue, 07 February 2006 13:46 |
> But :
beware that WSDL does not necessarily mean web service. More and more
WSDL is used as a interoperable contract. Kind of interface in the java
programming language but understable and usable by any language.
This is true. But what should be taken into consideration is the
visibility. If we get more visibility being incubated by STP then it may
be acceptable to switch to STP even if get a 'SOA label'. Of course this
depends of a shared agreement.
> what BPEL lacks!
I guess this won't ever happen. GMF won't host subproject.
> them architecture
> Less of all, I (don't ?) want to see JWT designer restricted by webservices/BPEL
neither do I.
> Guennadi Vanine
already decided: share schemas and not types [message #21706 is a reply to message #21661] |
Fri, 10 February 2006 07:47 |
"Fabrice Dewasmes" <fabrice.dewasmes@openwide.fr> wrote in message
news:dsa8kc$a3u$1@utils.eclipse.org...
> beware that WSDL does not necessarily mean web service. More and more WSDL
We already agreed but I'd like to comment
For ex., I need to interoperate through Repository, or drop-file... no
bindings, porttypes of WSDL
I really like .NET(Indigo/Avalon/Vista/Biztalk/MS SWL Server 2005/WWF/)
approach: share schemas and not types, use internally XML/XAML for
everything
I recommend to look into Biztalk2004/2006 how they realized what we need in
JWT. It has many replies and interesting approaches
Guennadi Vanine
repository is not registry [message #21751 is a reply to message #21706] |
Sat, 11 February 2006 19:41 |
I saw that repository is sometimes considered to be synonym of registry.
I do not. IMHO registry (UDDI, WSDL) is usually for services and repository
IMHO for data, files.
Guennadi Vanine
news:dshgf1$epm$1@utils.eclipse.org...
> everything
> in JWT. It has many replies and interesting approaches
> Guennadi Vanine
dependencies to take into account [message #21796 is a reply to message #21661] |
Sat, 11 February 2006 21:24 |
I beleive the following thread is relevant to this decision
http://www.eclipse.org/newsportal/article.php?id=1111&gr oup=eclipse.technology.gmf#1111
i.e. there are extensibility, interoperability (both inside and outside of
Eclipse, as well as integration), (re)unification/cooperation (with other
Eclipse projects), XML formats pluggability depending on...
Guennadi Vanine
>> But :
>> what BPEL lacks!
>> them architecture
>> webservices/BPEL
> neither do I.
>> Guennadi Vanine
Re: repository is not registry [message #22025 is a reply to message #21751] |
Mon, 13 February 2006 09:50 |
Completely agree.
Current Time: Thu Apr 25 02:07:58 GMT 2024
Powered by FUDForum. Page generated in 0.04089 seconds
