Home » Modeling » Papyrus » Papyrus Kepler SR2a
icon4.gif  Papyrus Kepler SR2a [message #1259579] Fri, 28 February 2014 15:03 Go to next message
Camille Letavernier is currently offline Camille LetavernierFriend
Hi all,
Kepler SR2 has just been released. We've noticed two important bugs with this version:
-	The profile diagram is partially broken
	o	Symptoms: some common operations, such as deleting a property, fail and throw an exception (See Error log)
-	The Diagram Stylesheets (Extra-component) is partially broken if you updated from Kepler SR0 or Kepler SR1 (New installations of this component should work properly)
	o	Symptoms: all UML-related stylesheet rules are ignored. For example, newly created SysML Blocks have all compartments visible
We recommend updating to Papyrus 0.10.2a which fixes these issues. Here's the process:
-	Add the following update site to Eclipse:
	o	http://download.eclipse.org/modeling/mdt/papyrus/updates/releases/kepler
	o	To add the update site, go to Help > Install new software. In the "work with" field, add this update site
-	Update Eclipse to Kepler SR2 (Help > Check for updates)
	o	The expected version of Papyrus UML is "0.10.2.v201402281227" (Instead of "0.10.2.v201402191038")
If you had previously installed the extra-component Papyrus Stylesheets, you will need to reinstall them. Here are the steps:
-	Go to Help > About Eclipse > Installation details
-	In the Installed Software tab, find "Papyrus CSS Feature" and "Papyrus UML CSS Feature"
-	If you can find both, everything's fine. You don't need to do anything
-	If "Papyrus UML CSS Feature" is missing, uninstall "Papyrus CSS Feature"
-	Restart Eclipse, then reinstall the Diagram stylesheet feature:
	o	Go to Help, Install Papyrus Additional components
	o	Select "View stylesheets"
	o	Press finish
If you have trouble with the Papyrus SR2 update, do not hesitate to ask for help
Camille
Camille Letavernier
Re: Papyrus Kepler SR2a [message #1266107 is a reply to message #1259579] Fri, 07 March 2014 01:22 Go to previous message
Matt Park is currently offline Matt ParkFriend
I'm having problems with the the new tables working after the upgrade. I cannot drag and drop model elements onto a generic diagram. I'm using:
Papyrus SysML Table - New Version (Incubation) 0.10.2.v201402281314
I've re-installed Eclipse Kepler, Modeling Tools, and Papyrus.
Any thoughts?
Previous Topic:State machine metamodel
Next Topic:Placing Testcase on Requirements Diagram
Current Time: Sat Jan 23 12:22:56 GMT 2021
Powered by FUDForum. Page generated in 0.02461 seconds
