Re: XML code formatting [message #207977] |
Sun, 03 February 2008 19:00 |
Originally posted by: dcarver.starstandard.org
Mansour wrote:
> Whenever I add the DOCTYPE declaration for any xml file I loose the
> ability to format the code with CTRL-SHIFT-F. I have googled for this
> but no luck. Can any one suggest something?
Do you have an example? I've also added the Eclipse Webtools project on
this reply as well.
Dave
Re: XML code formatting [message #207993 is a reply to message #207977] |
Sun, 03 February 2008 20:26 |
Originally posted by: mansour.own.net
Davide, any example will do it. You can try a docbook document or and
SVG file:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<!DOCTYPE svg PUBLIC "-//W3C//DTD SVG 1.1//EN"
"http://www.w3.org/Graphics/SVG/1.1/DTD/svg11.dtd">
<svg xmlns="http://www.w3.org/2000/svg" version="1.0">
<defs>
</defs>
<g>
</g>
</svg>
If you hit CTRL-SHIFT-F nothing will happen. Remove the DOCTYPE
declaration and try again.
> this reply as well.
> Dave
Re: XML code formatting [message #208000 is a reply to message #207993] |
Sun, 03 February 2008 21:42 |
> SVG file:
> <defs>
> </defs>
> <g>
> </g>
> </svg>
It's formatting regardless of the DOCTYPE's presence for me. Which
version of WTP are you using?
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
_
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: XML code formatting [message #208022 is a reply to message #208000] |
Mon, 04 February 2008 03:22 |
Nitin Dahyabhai wrote:
>> SVG file:
>> <defs>
>> </defs>
>> <g>
>> </g>
>> </svg>
In Web Tools 2.0.1 it doesn't format, in Web Tools 3.0 it does format.
In 2.0.1 there is a null pointer exception tossed, if the error logs is
reviewed.
Dave
Re: XML code formatting [message #208028 is a reply to message #208000] |
Mon, 04 February 2008 03:27 |
I am using WST 2.0.1.v200709110510
Eclipse Platform
Version: 3.3.1.1
Build id: M20071023-1652
WTP UI Plug-in 1.1.101.v200709122200
Linux gtk 32-bit
>> SVG file:
>> <defs>
>> </defs>
>> <g>
>> </g>
>> </svg>
> Nitin Dahyabhai
> IBM Rational
Re: XML code formatting [message #208034 is a reply to message #208022] |
Mon, 04 February 2008 03:42 |
Here's some more info:
eclipse.buildId=M20071023-1652
java.version=1.6.0_02
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Command-line arguments: -os linux -ws gtk -arch x86
at
org.eclipse.wst.xml.core.internal.provisional.format.Element NodeFormatter.formatStartTag(ElementNodeFormatter.java:395)
at
org.eclipse.wst.xml.core.internal.provisional.format.Element NodeFormatter.formatNode(ElementNodeFormatter.java:121)
at
org.eclipse.wst.xml.core.internal.provisional.format.NodeFor matter.format(NodeFormatter.java:75)
at
org.eclipse.wst.xml.core.internal.provisional.format.Documen tNodeFormatter.formatChildren(DocumentNodeFormatter.java:42)
at
org.eclipse.wst.xml.core.internal.provisional.format.Element NodeFormatter.formatNode(ElementNodeFormatter.java:132)
at
at
at
at
at
at
at
at
at
at
at
org.eclipse.wst.sse.core.internal.format.AbstractStructuredF ormatProcessor.formatNode(AbstractStructuredFormatProcessor. java:405)
at
org.eclipse.wst.sse.core.internal.format.AbstractStructuredF ormatProcessor.formatModel(AbstractStructuredFormatProcessor .java:346)
at
org.eclipse.wst.sse.core.internal.format.AbstractStructuredF ormatProcessor.formatDocument(AbstractStructuredFormatProces sor.java:167)
at
org.eclipse.wst.sse.ui.internal.format.StructuredFormattingS trategy.format(StructuredFormattingStrategy.java:58)
at
org.eclipse.jface.text.formatter.MultiPassContentFormatter.f ormatMaster(MultiPassContentFormatter.java:193)
at
org.eclipse.jface.text.formatter.MultiPassContentFormatter.f ormat(MultiPassContentFormatter.java:142)
at
org.eclipse.wst.sse.ui.internal.StructuredTextViewer.doOpera tion(StructuredTextViewer.java:454)
at
org.eclipse.ui.texteditor.TextOperationAction$1.run(TextOper ationAction.java:131)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
at
org.eclipse.ui.texteditor.TextOperationAction.run(TextOperat ionAction.java:129)
at
org.eclipse.ui.texteditor.RetargetTextEditorAction.run(Retar getTextEditorAction.java:237)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:546)
at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:490)
at
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:402)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1101)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3319)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2971)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 19)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:461)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:106)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
at
at
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
>>> SVG file:
>>> <defs>
>>> </defs>
>>> <g>
>>> </g>
>>> </svg>
> reviewed.
> Dave
Re: XML code formatting [message #208042 is a reply to message #208022] |
Mon, 04 February 2008 03:44 |
>>> SVG file:
>>> <defs>
>>> </defs>
>>> <g>
>>> </g>
>>> </svg>
But it's formatting when there's no DOCTYPE !!
> reviewed.
I sent you the log. I guess that's the same exception you are talking
about. What do I need to do to fix this?
> Dave
Re: XML code formatting [message #208088 is a reply to message #208042] |
Mon, 04 February 2008 16:48 |
>> is reviewed.
Can you upgrade to WTP 3.0 ?
Eric
Re: XML code formatting [message #208132 is a reply to message #208088] |
Mon, 04 February 2008 17:30 |
>>> is reviewed.
I will if I know exactly how. I have added Callisto Discovery, and I
have previously WTP updates and Europa Discovery. I followed them and
installed and updated everything under WTP updates. I am still getting
the same error.
> Eric
Re: XML code formatting [message #208140 is a reply to message #208042] |
Mon, 04 February 2008 19:19 |
>> is reviewed.
From what I can tell it comes from an xml:space attribute
declaration in the referenced DTD (or another file it includes) not
having a default value given. If you open a bug with this stack
trace there's a chance it will be fixed in 2.0.2.
Nitin Dahyabhai
IBM Rational
_
Nitin Dahyabhai
FUDForum. Page generated in 0.02346 seconds
