LinkageError? [message #1259376] |
Fri, 28 February 2014 10:08 |
Ludwig Moser Messages: 476 Registered: July 2009 |
i launch my Application as a Plug-In based Product. (launching works without any problems)
as i want to use the self update feature i need to turn it into a feature based product.
i added all features and plugins which i need to get it started.
but while launching i get the exception listed below
any ideas where this is coming from?
Thanks in advance
!ENTRY org.eclipse.e4.ui.workbench.swt 4 2 2014-03-04 13:46:19.252
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.e4.ui.workbench.swt".
!STACK 0
org.eclipse.e4.core.di.InjectionException: java.lang.LinkageError: loader constraint violation: when resolving interface method "org.eclipse.e4.ui.workbench.swt.util.ISWTResourceUtilities.imageDescriptorFromURI(Lorg/eclipse/emf/common/util/URI;)Ljava/lang/Object;" the class loader (instance of org/eclipse/osgi/internal/baseadaptor/DefaultClassLoader) of the current class, org/eclipse/ui/internal/registry/ViewDescriptor, and the class loader (instance of org/eclipse/osgi/internal/baseadaptor/DefaultClassLoader) for resolved class, org/eclipse/e4/ui/workbench/swt/util/ISWTResourceUtilities, have different Class objects for the type org.eclipse.e4.ui.workbench.swt.util.ISWTResourceUtilities.imageDescriptorFromURI(Lorg/eclipse/emf/common/util/URI;)Ljava/lang/Object; used in the signature
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:63)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:877)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:119)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:84)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.inject(ContextInjectionFactory.java:73)
at org.eclipse.ui.internal.Workbench.createWorkbenchWindow(Workbench.java:1396)
at org.eclipse.ui.internal.Workbench.getActiveWorkbenchWindow(Workbench.java:1369)
at org.eclipse.ui.internal.services.WorkbenchSourceProvider.updateActiveShell(WorkbenchSourceProvider.java:924)
at org.eclipse.ui.internal.services.WorkbenchSourceProvider.getCurrentState(WorkbenchSourceProvider.java:133)
at org.eclipse.ui.internal.services.WorkbenchSourceProvider$6.handleEvent(WorkbenchSourceProvider.java:684)
at org.eclipse.swt.widgets.Display.filterEvent(Display.java:1262)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1056)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1081)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1066)
at org.eclipse.swt.widgets.Decorations.WM_ACTIVATE(Decorations.java:1667)
at org.eclipse.swt.widgets.Shell.WM_ACTIVATE(Shell.java:2151)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4608)
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:340)
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1627)
at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2075)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4977)
at org.eclipse.swt.internal.win32.OS.BringWindowToTop(Native Method)
at org.eclipse.swt.widgets.Decorations.bringToTop(Decorations.java:231)
at org.eclipse.swt.widgets.Shell.open(Shell.java:1217)
at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.postProcess(WBWRenderer.java:767)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:649)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:735)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:706)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:700)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:685)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1038)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:997)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:138)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:610)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:567)
at my.app.application.Application.start(Application.java:47)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
Caused by: java.lang.LinkageError: loader constraint violation: when resolving interface method "org.eclipse.e4.ui.workbench.swt.util.ISWTResourceUtilities.imageDescriptorFromURI(Lorg/eclipse/emf/common/util/URI;)Ljava/lang/Object;" the class loader (instance of org/eclipse/osgi/internal/baseadaptor/DefaultClassLoader) of the current class, org/eclipse/ui/internal/registry/ViewDescriptor, and the class loader (instance of org/eclipse/osgi/internal/baseadaptor/DefaultClassLoader) for resolved class, org/eclipse/e4/ui/workbench/swt/util/ISWTResourceUtilities, have different Class objects for the type org.eclipse.e4.ui.workbench.swt.util.ISWTResourceUtilities.imageDescriptorFromURI(Lorg/eclipse/emf/common/util/URI;)Ljava/lang/Object; used in the signature
at org.eclipse.ui.internal.registry.ViewDescriptor.getImageDescriptor(ViewDescriptor.java:109)
at org.eclipse.ui.internal.ViewReference.<init>(ViewReference.java:46)
at org.eclipse.ui.internal.WorkbenchPage.createViewReferenceForPart(WorkbenchPage.java:1912)
at org.eclipse.ui.internal.e4.compatibility.ModeledPageLayout.createViewModel(ModeledPageLayout.java:376)
at org.eclipse.ui.internal.e4.compatibility.ModeledPageLayout.insertView(ModeledPageLayout.java:398)
at org.eclipse.ui.internal.e4.compatibility.ModeledPageLayout.addView(ModeledPageLayout.java:236)
at my.app.application.Perspective.createInitialLayout(Perspective.java:14)
at org.eclipse.ui.internal.WorkbenchPage.setPerspective(WorkbenchPage.java:3914)
at org.eclipse.ui.internal.WorkbenchWindow.setup(WorkbenchWindow.java:675)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
... 53 more
[Updated on: Tue, 04 March 2014 13:42] Report message to a moderator
FUDForum. Page generated in 0.02745 seconds
