Home » Modeling » OCL » Preconditions and inheritance
Preconditions and inheritance [message #19988] Fri, 27 April 2007 09:02 Go to next message
Youmm P. is currently offline Youmm P.Friend
While in Java all objects automatically inherit the methods of their
superclass(es), in C++ you have to add the 'virtual' keyword.
If I have a class B that inherits from a class A which contains a method
'start'
context A::start():void pre
is no doubt a valid constraint.
But what about "context B::start():void" if start is not redefined in B ?
This would have a meaning in Java but not in C++ if start is not virtual.
Since OCL is language independent how should I handle this ?
I tried to do something like "context B::start():void pre..." without
success.
I'm using an Ecore model and inheritance works well for attributes.
Thanks for your help,
Youmm.
Re: Preconditions and inheritance [message #20030 is a reply to message #19988] Fri, 27 April 2007 12:12 Go to previous messageGo to next message
Hi, Youmm,
In OCL, it is not necessary to redefine an inherited operation or attribute
in a specializing classifier in order to add pre/post conditions or
redefine the body expression.
What you are trying to do should work. In what way is it not? Is it not
parsing?
You will find examples of this in the
org.eclipse.ocl.ecore.tests.OperationConstraintTest class, which parses
preconditions and body conditions in the Apple context for operations
inherited from Fruit.
Christian
Youmm P. wrote:
> Hello,
> 'start'
> success.
> Youmm.
Re: Preconditions and inheritance [message #20068 is a reply to message #20030] Fri, 27 April 2007 13:57 Go to previous messageGo to next message
> parsing?
Ok I think I get it : with OCLHelper you've got to use setEOperation
with the inherited class and with the method of one of the superclasses.
Thanks for the explanations.
Re: Preconditions and inheritance [message #20097 is a reply to message #20068] Fri, 27 April 2007 14:05 Go to previous messageGo to next message
Hi, Youmm,
I see ... you were using the OCLHelper. Yes, in that case, you specify an
EClass that is not the one that owns the EOperation, but rather inherits
it. The same works for the attribute context.
Christian
>> parsing?
Re: Preconditions and inheritance [message #39997 is a reply to message #20097] Mon, 08 October 2007 09:16 Go to previous messageGo to next message
Hao Zhang is currently offline Hao ZhangFriend
I'm also facing this problem, but I can't find setEOperation() in OCLHelper,
but only setOperationContext(), and I have no idea what should I pass the
arguments.
For example, I defined operation "isValid()" in class A, class B inherits A,
how do I configure my OCLHelper to let expression "b.isValid()" work?
Hao
"Christian W. Damus" <cdamus@ca.ibm.com>
??????:f0svu5$b9i$1@build.eclipse.org...
> Hi, Youmm,
> Cheers,
> Christian
>>> not
>>> parsing?
Re: Preconditions and inheritance [message #40028 is a reply to message #39997] Mon, 08 October 2007 09:53 Go to previous messageGo to next message
One more word, I also defined some operations in class B (e.g. getPrice()),
and I need an expression like "b.isValid() and b.getPrice()>100" to be
evaluated. Thanks.
"Hao Zhang" <bjzhanghao@21cn.com> д
Re: Preconditions and inheritance [message #40058 is a reply to message #40028] Mon, 08 October 2007 10:20 Go to previous messageGo to next message
It seems I solved this problem now, I invoked
OCLHelper.setOperationContext() on any method I defined in A, then it works
for all the inherited methods. Is this the right?
Re: Preconditions and inheritance [message #40088 is a reply to message #39997] Tue, 09 October 2007 14:20 Go to previous message
Hi, Hao,
The arguments to the setOperationContext() method are "context" and
"operation." The first is the classifier context in which you want to
define this constraint and the second is the operation, which may be
defined by the context classifier or inherited by it.
So, doing
EClass a = ... ;
EOperation isValid = ... ;
EClass b = ... ;
OCLHelper<EClassifier, EOperation, ?, Constraint> helper = ... ;
helper.setOperationContext(b, isValid);
Constraint constraint = helper.createPrecondition(...);
is equivalent to this concrete syntax of the context declaration:
context B::isValid() : Boolean
pre: -- some OCL condition
assuming, of course, the A::isValid() has EBoolean or EBooleanObject type.
HTH,
Christian
Hao Zhang wrote:
> OCLHelper, but only setOperationContext(), and I have no idea what should
> I pass the arguments.
> A, how do I configure my OCLHelper to let expression "b.isValid()" work?
> Regards,
> Hao
>> Hi, Youmm,
>> an EClass that is not the one that owns the EOperation, but rather
>> inherits
>> Cheers,
>> Christian
>>>> not
>>>> parsing?
Previous Topic:[Announce] MDT OCL 1.2.0 1.2M2 is available
Next Topic:OCL for UML AssociationClass
Current Time: Sat Sep 14 20:11:20 GMT 2024
Powered by FUDForum. Page generated in 0.04573 seconds
