How to start jboss4.2.2GA in eclipse [message #207257] |
Sat, 19 January 2008 14:30 |
Originally posted by: 3309696.gmail.com
when I start jboss4.2.2ga,the eclipse shows " Timeout waiting for
JBOSS 4.2 to start. Server did not start after 50s."
how to slove this problem.thank you
Re: How to start jboss4.2.2GA in eclipse [message #207259 is a reply to message #207258] |
Sun, 20 January 2008 03:08 |
kiril mitov 写道:
> When jboss is starting its output is redirected to the eclipse console.
> Can you check whether there are some exceptions or errors in this output?
> Best Regards,
> Kiril
I didn't see any exceptions or error which shows in eclipse console.I
can start jboss in netbean.when the eclipse shows "timeout waiting for
jboss 4.2 to start.server did not start after 50s",the eclipse console
shows:
" 11:00:13,497 INFO [Server] Starting JBoss (MX MicroKernel)...
11:00:13,507 INFO [Server] Release ID: JBoss [Trinity] 4.2.2.GA (build:
SVNTag=JBoss_4_2_2_GA date=200710221139)
11:00:13,537 INFO [Server] Home Dir: C:\jboss4.2.2.GA
11:00:13,537 INFO [Server] Home URL: file:/C:/jboss4.2.2.GA/
11:00:13,537 INFO [Server] Patch URL: null
11:00:13,537 INFO [Server] Server Name: default
11:00:13,537 INFO [Server] Server Home Dir: C:\jboss4.2.2.GA\server\default
11:00:13,537 INFO [Server] Server Home URL:
file:/C:/jboss4.2.2.GA/server/default/
11:00:13,537 INFO [Server] Server Log Dir:
C:\jboss4.2.2.GA\server\default\log
11:00:13,537 INFO [Server] Server Temp Dir:
C:\jboss4.2.2.GA\server\default\tmp
11:00:13,547 INFO [Server] Root Deployment Filename: jboss-service.xml
11:00:19,516 INFO [ServerInfo] Java version: 1.6.0_03,Sun Microsystems Inc.
11:00:19,516 INFO [ServerInfo] Java VM: Java HotSpot(TM) Client VM
1.6.0_03-b05,Sun Microsystems Inc.
11:00:19,516 INFO [ServerInfo] OS-System: Windows XP 5.1,x86
11:00:22,560 INFO [Server] Core system initialized
11:00:32,284 INFO [WebService] Using RMI server codebase:
http://127.0.0.1:8083/
11:00:32,294 INFO [Log4jService$URLWatchTimerTask] Configuring from
URL: resource:jboss-log4j.xml"
where is the problem?thank you
Re: How to start jboss4.2.2GA in eclipse [message #207268 is a reply to message #207259] |
Mon, 21 January 2008 13:42 |
Originally posted by: wknauf_NO_._INSIDE_hg-online.de
Hi Kiril,
seems your computer is too slow to start up a jboss in less than 50 seconds. In
the server preferences, there is a setting "startup timeout", which defaults to
"normal". Set it to "unlimited" so that eclipse does not kill the server if it
is too slow.
Hope this helps (I don't have a eclipse here, so I hope that I guessed the right
labels for the settings).
Wolfgang
Hello schrieb:
> kiril mitov 写道:
>> Best Regards,
>> Kiril
Re: How to start jboss4.2.2GA in eclipse [message #207278 is a reply to message #207268] |
Tue, 22 January 2008 07:54 |
Wolfgang Knauf 写道:
> Hi Kiril,
> is too slow.
> Wolfgang
> Hello schrieb:
>> kiril mitov 写道:
>>> Best Regards,
>>> Kiril
I cann't find any label which can define jboss start time in
eclipse.where is the problem? thank you
Re: How to start jboss4.2.2GA in eclipse [message #207279 is a reply to message #207278] |
Tue, 22 January 2008 11:07 |
--------------060300020306020401070506
Content-Type: text/plain; charset=GB2312
Hi Kiril,
see the attached screenshot.
Best regards
Wolfgang
Content-Type: image/jpeg;
name="unlimited.jpg"
Content-Disposition: inline;
filename="unlimited.jpg"
/9j/4AAQSkZJRgABAQEAYABgAAD/2wBDAAgGBgcGBQgHBwcJCQgKDBQNDAsL DBkSEw8UHRof
Hh0aHBwgJC4nICIsIxwcKDcpLDAxNDQ0Hyc5PTgyPC4zNDL/2wBDAQkJCQwL DBgNDRgyIRwh
MjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIy MjIyMjL/wAAR
CAIYAnIDASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoL/8QAtRAA
AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS 0fAkM2JyggkK
FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1 dnd4eXqDhIWG
h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW 19jZ2uHi4+Tl
5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcI CQoL/8QAtREA
AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMz UvAVYnLRChYk
NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0 dXZ3eHl6goOE
hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU 1dbX2Nna4uPk
5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwDr/HXjpvBbaeq6bFdi6Qnl lTbtVD3Q5zur
nE+LerSW63CeDpmhb7si8qfofKxS/FiGK58Q+EoJwDDJLscH+6fJB/SrniG8 gniS3aeOAQja
AHgHH0Moruo0acoRbjdu/V9zNt3epkP8bpo3KP4cjVh1DTKCP/IVNHxwk/6F 6L/v+v8A8brh
vE9vbLsmiu1mkLbSA0J4wf7krHt6Y969I8VWHhdvFV94anisI5rrUNPhsIdP shDNaK23zmeQ
RqGDK3Ay/JHAxxtKhQi17v4sy559yl/wu+T/AKF+L/v+v/xul/4XdJ/0L8X/ AH+X/wCN1lJ4
L8MfavEsh1C/Wz0JlglNwRFvlad0B3Ikh2hVUfcyzHPyDita107TE8FT6b4f 1S5a21TxNFp8
eoRgxO0Twr8sq4BkVd7jb8oJ+bgcFOlh+kfzDnqdwHxskP8AzL8X/f5f/jdK PjXJ/wBACL/v
8v8A8bqrb+BvCF74xttAttXvDcC9uLe4gVi77Ejdg+9oUVWDJgqN454biqOl eGPCU+hya7e6
nfRab9vjsUMv7pwfKDyPhElySSdq8AAcvk0exw/8r/EOep3Nr/hdMn/QAi/7 /L/8bpf+F0Sf
9AGL/v8AL/8AG6paZ4C0C/TQLeO8vppdaa+SK8RlSNBAW2P5RTcQwAJXcCOe ay7nwtpltceG
9K3XbX+tW9rP9r81RFD50mMeVty2B33jJ546UKjhm7cv5/5+Quep3Oi/4XPJ /wBAGL/v8v8A
8bpf+Fyyf9AGL/v6v/xusm98MeC4PEEGm/8ACQzWxTUXtbtZN0m2MZw28xIq Hcu0/fA3BskA
5wvF2hJ4f1eK2ijxDLbpPFILxblZlbOHVwiccYwV7E5IIqo0MPJ25fzB1Ki6 naD4ySf9AKL/
AL+r/wDG6UfGKQ/8wKL/AL+r/wDG68tFOFX9To9vxZPtp9z1EfGGT/oBxf8A f1f/AI3Tv+Fv
yf8AQDi/7+r/APG68vFOFH1Oj2/Fh7afc9PHxek/6AkX/f1f/jdKPi7J/wBA SL/v4v8A8brz
IU4UvqlHt+LD20+56Z/wtuT/AKAkX/fxf/jdL/wtqT/oCxf9/F/+N15oKeKP qlHt+LF7afc9
JHxYk/6AsX/fxf8A43Sj4ryf9AaL/v4v/wAbrzcU4UfVKPb8WP20+56R/wAL Wk/6A0X/AH8X
/wCN0o+Kkn/QHi/77X/43XnAp4o+qUe34sPbT7noo+Kcn/QHi/77X/4il/4W jJ/0B4v++1/+
IrzsU8UvqlHt+LD20+56EPihJ/0CIv8Avtf/AIinD4nSH/mERf8Afa//ABFe einCj6pR7fix
e2n3PQf+Fmyf9AmL/vtf/iKX/hZcn/QJi/76X/4iuAFOFH1Sj2/Fh7afc77/ AIWVJ/0Cov8A
vpf/AIil/wCFkyf9AqL/AL6X/wCIrgxThR9Uo9vxYe2n3O7/AOFkSf8AQKi/ 76X/AOIpR8Rp
P+gXF/30v/xFcKKcKX1Wj2/MPbT7ndf8LFk/6BcX/fS//EUv/Cw5P+gZF+a/ /EVw4pwo+q0e
35h7afc7f/hYUn/QMi/Nf/iKX/hYEn/QNi/Nf/iK4kU8UfVaXb8w9tPudp/w n8n/AEDYvzX/
AOIp3/CfSf8AQNi/Nf8A4iuLFOFH1Wl2/MPbT7nZ/wDCeSf9A6L81/8AiKUe O5P+gdF/47/8
RXHCnCl9VpdvzD20+52A8cyf9A+L/wAd/wDiKUeOJD/zD4v/AB3/AOIrkBTx R9VpdvzD20+5
1o8byf8AQPi/8d/+Ip3/AAmsn/PhF/47/wDE1yQpwpfVaXb8w9tPudYPGkn/ AD4Rf+O//E0o
8ZSf8+MX5L/8TXKinCj6rS7fmHtp9zqf+Exk/wCfGL8l/wDiaUeL5P8Anyi/ Jf8A4muYFOFH
1Wl2/MPbT7nTf8JdJ/z5Rfkv/wATS/8ACWyf8+UX5L/8TXNCnCj6tS7fmHtp 9zpf+Erk/wCf
OL8l/wDiaUeKpP8Anzi/75X/AOJrmxTxR9WpdvzD28+50Q8Uyf8APpF/3yv/ AMTS/wDCTyf8
+kX/AHyv/wATXPCnil9WpdvzD20+5vjxNJ/z6xf98r/8TTh4kkP/AC6xf98r /wDE1gCnij6t
S7fmL29Tubv/AAkcn/PrF/3yv/xNL/wkMn/PtF/3wv8A8TWGKcKPq1Lt+Y/b z7m3/wAJBJ/z
7Rf98L/8TS/2/J/z7xf98L/8TWKKeKX1al2/MPbz7mwNdk/594v++F/+JpRr kn/PCL/vhf8A
4msgU4UfVqXb8w9vU7muNakP/LCL/vhf/iaX+2ZP+eEX/ftf/iayhThR9Xpd vzF7ep3NT+15
P+eMX/ftf/iaUatJ/wA8Yv8Av2v+FZgp4o+r0u35h7ep3NL+1ZP+eUX/AH7X /Cl/tOT/AJ5R
f9+1/wAKzhTxS+r0+35h7ep3L41KT/nnF/37X/CrCSXUkauIrcK3I3eWM846 H6VlCr0sscNl
bySuqIIzlmOAPnbvWNenCnG6X5mtKc5ys2Wd11/zztfziqG1vJL23E9uLV4i zqG/dAEqxU4z
1GVIz0OOKrw3MFxu8ieOXb12OGx+VcPc6TY654Z8JabqUHn2k2p3PmR72XOB eMOVIPUDvXLz
L+X8/wDM6OV9/wAv8j0bddf887X84qr2eoPqETy2otpI0doy+IwNwYqcEjnl TyPSuEXwP4d8
NeJPD15pGnfZrh72SJn8+R8qbackYZiOqj8q6HwZ/wAimf8Ar5f/ANGS1UXF pvl29f8AMTUk
0r/l/kdFuuv+edr+cVVf7T/06Sz/ANHM8aK7qiI20NnGSBj+E8dfzFeV/wBr XX27yP7X1H/h
CPtu3+19x8zfn/U/aN+/7Pv487Gc/Jux81dtYf8AI56z/wBcrb+T0RaldW6P v/mDTWt/yPF9
RZn1O7d2LM0zkknJJ3Gikv8A/kI3P/XV/wCZoqSj1H4peFtc8SzaSdFsXujb IxkKOq7Nyx7e
pH90/lXJX/g34halbpHdeHg8qjBnEiB2Hvh8H8q+gdM/1s3/AFzi/wDQah1f xTomhXCW+p6h
HbSum9VdWORnGeB7V0UsVOEVFJaEOF23fc+bP+FVeNsk/wBgy5P/AE2j/wDi quS/D74iz6iN
Rm0++kvgyuLl7tTKGXG07i+cjAwe2BXu/wDwsXwl/wBBuD/vl/8ACj/hYvhL /oNwf98v/hWn
16p2X9fMj2Me54bbeBfiTZ3019a2mowXc2fNuIrxVkkycncwfJyRk570678D fEnUI3jvbTUb
lHkEzrNeK4Zwu0MQX5baAM9cDFe4f8LF8Jf9BuD/AL5f/Cj/AIWL4S/6DcH/ AHy/+FH12e9l
/XzD2Me7PGn8M/FaV4nkbWnaJt8bNqOSjYK5Hz8HDEZ9CfWq+n+B/iPpPmf2 daajZ+bjzPs1
4se/GcZ2uM4yfzr23/hYvhL/AKDcH/fL/wCFH/CxfCX/AEG4P++X/wAKX1ye 1l93/BH7GPdn
i48HfEsTwz+RqnmwNI8Un20bo2c5cqd/BYk5I655pv8AwhPxF/sz+zPsmo/Y P+fX7Wvldd33
N+OvPTrzXtX/AAsXwl/0G4P++X/wo/4WL4S/6DcH/fL/AOFH1yfZf18xexj3 Z5A/hv4pSPG8
jay7RNvjLahko2CuR8/BwSPoT61Ruvh/46v7l7m80y7uLh8bpZrhHZsDAyS2 TwAK9t/4WL4S
/wCg3B/3y/8AhR/wsXwl/wBBuD/vl/8AChYya2S/r5h7GPdnho+GnjD/AKAk v/fyP/4qnD4a
+MP+gJL/AN/I/wD4qvcP+Fi+Ev8AoNwf98v/AIUf8LF8Jf8AQbg/75f/AAp/ XqnZf18w9hE8
RHw28X/9ASX/AL+J/wDFU4fDfxd/0BZf+/if/FV7Z/wsXwl/0G4P++X/AMKP +Fi+Ev8AoNwf
98v/AIUfXqnZf18w9hE8VHw48Xf9AWX/AL+J/wDFUo+HPi3/AKAsv/fxP/iq 9p/4WL4S/wCg
3B/3y/8AhR/wsXwl/wBBuD/vl/8ACj67U7L+vmHsInjA+HXi3/oDS/8AfxP/ AIqnD4d+LP8A
oDS/9/E/+Kr2X/hYvhL/AKDcH/fL/wCFbel6tY61Zi80+cT25YqJApAJHXGQ M0fXanZf18w9
hE8BHw88V/8AQGl/77T/ABpR8PfFf/QHl/77T/Gvoqij67U7L+vmHsInzuPh 94q/6A8v/faf
401vA/iONyj6aysACQZYwQDnH8XfB/I19FVz2qf8hW6/64W//oU9J42p2X9f MPYRPFh4L8Qf
9A//AMjR/wDxVOHgzX/+fD/yNH/8VXrNFT9fqdl/XzH9XieTjwbr/wDz4f8A kaP/AOKpw8Ha
9/z4f+Ro/wD4qvVqKPr9Tsv6+YfV4nlY8H69/wA+P/kZP/iqcPCGu/8APj/5 FT/4qvUqKPr9
Tsv6+YfVoHl48I65/wA+P/kVP/iqUeEtc/58f/Iqf416fRS+vVOy/r5h9Wge ZDwnrf8Az5f+
RU/xpR4U1v8A58v/ACKn+NemUUfXqnZf18w+rQPNR4V1r/ny/wDIqf404eFt Z/58/wDyKn+N
ekUUfXqnZf18w+rRPOR4X1n/AJ8//Iqf404eGNY/58//ACKn+NeiUUfXqnZB 9WgeeDwzrH/P
p/5ET/GnDw1q/wDz6f8AkRP8a9Boo+vVOyD6tA4AeG9W/wCfT/yIn+NKPDmr f8+n/kRP8a76
ij67U7IPq0Dgx4d1X/n1/wDIi/404eHtU/59f/Ii/wCNd1RR9dqdkH1aBw48 P6p/z6/+RF/x
pRoGp/8APt/5EX/Gu3opfXanZB9WgcUNB1P/AJ9v/Ii/404aFqX/AD7f+Pr/ AI12dFH12p2Q
fVoHHDQ9R/59/wDx9f8AGnDRNR/59/8Ax9f8a6+ij67U7IPq0DkRouof8+// AI+v+NOGjah/
z7/+Pr/jXWUUfXanZB9WgcqNHv8A/nh/4+v+NKNIvv8Anh/4+v8AjXU0UfXa nZB9WgcwNJvv
+eH/AI+v+NOGlXv/ADx/8eX/ABrpaKPrtTsg+rQOcGl3n/PH/wAeH+NOGmXn /PH/AMeH+NdD
RR9cqdkH1aBz4027/wCeX/jw/wAacNOu/wDnl/48P8a3qKX1yp2QfVoGGNPu v+eX/jw/xpRY
XP8Azy/8eH+NbdFH1yfZB9WgYwsbn/nn/wCPCnCyuP8Ann/48K16KPrk+yD6 tAyhZ3H/ADz/
AFFOFpP/AHP1FadFH1yfZB9WgZotZv7n6inC2m/ufqK0KKPrk+yD6tAoi3l/ u/qKcIJP7v6i
rlFH1ufZB9WgVRDJ/d/WqOoWms3bqkN/axWyKFWGSyEuec5YlsHk+g7fWtii oniJTVpJDjQU
XdM59NO8QRIyQ6rYwqxBYRaXGmSM4zhhnqfzqlL4Wv7jS7fTbi7064tIGZ0j uNNWUbmd2LYZ
zz87D6fjXW0VHtF/Kvx/zL5H3f4f5HG2ngyewukurNtHtrhM7JYdGiR1yMHB DZHBI/GtS00r
VtP0aLT7LUIYiJGkkla23FiWZgAN/A+c+vQdO+9RQqtvsr8f8w5PN/h/kYH2 DxJ/0HIP/AAf
/F1LpOk3lnqN1e3t4lzLcLGpKw+WAE3Y43H+9+lbVFHtLbJfj/mHJ3Z873// ACEbn/rq/wDM
0UX/APyEbn/rq/8AM0UDPqXTP9bN/wBc4v8A0GuV8R60ugePYdQeCSdBpkcL JGGZsS3kMeQq
gliN+doGTjA611Wmf62b/rnF/wCg1zPiDTP7U8dJGZvs4TTEljnZdyJNHdRy xhhkZBaPlcgk
BsEdQlsDOkTxDpj28k/nyIkVxBayCSCRGSWYRmNCrKCCfOj7cbucYOKdn410 G+szdRXU6wmJ
ZozPZzQmdGIAMSugMuS6AbA3LoOrLmqumpceMbbVL17Ym0sowbiN9q3Fx+9U EJuJQRrJNwSQ
32nkkxg1z+m+C5tQ8J6TZ+ItR08z2WmQ2sNsluCkZVoJCk4MjCYbreNTtKAj f/eBVgddeeJ7
SLwrquuWiSTjT7eaWS3lR4JAyJv2OrqGQkYIyvRgcEEZ5vU/H11o9hBJIkF5 MkUlxcKbSeyd
0EF7IoEUoJjybQAEs2csdoG0nSh8M2cXg3V9BS70y2bUopo3aws0t4YjJH5e ViDZOAATuckn
PIGAsfiHwlYeI9Wku7jVligmt1t5Iowu7aIbuIkMTgEi8z0ONnfPABrSeLtH hSF5pLuISJ5j
eZYzqYE3Fd8wKZhTKthpNoIViDgEi5put6drEt3HYXHntaStBOQjARyKzKyE kY3Aqcjrgqej
KTyuq+D4dbvY7/Ur3Qbq8e3W2uJZtKSUKiu7KYFkkYRPiRslvMBKqduAQek0 a3ttIsZLb7dF
Lvu7m53ZC486Z5duMnpvxnvjPHSgDN0rx1puoeHtO1SWC+hkvYlkFqljcSyA 7FZiqrHueNd6
jzQuwkjnJArUTxHpEjokd9HI8jxLEsYLGXzV3IyYHzoVDHeuVARySNjY5Wfw TbT6dpVrLfaL
ef2TE9pZDUdOFxGLciMDenmjdMPKX94CowWGwZ42INFjtbyxuYdZiVrCJLW2 TyY1QW+E81GV
cDc5RTldoXZGAuA4kAL3hfxBF4n8PWerRW89v58SO0U0TptZkViFLqu9RuwH UbT2rYrF8PWq
aHo0GlvqNtcQWiLBasq7GWFFCoH+YhnwOWAUHsorU+123/PxF/32KAJqKh+1 23/PxF/32KPt
dt/z8Rf99igCaioftdt/z8Rf99ij7Xbf8/EX/fYoAmoqH7Xbf8/EX/fYo+12 3/PxF/32KAJq
hh/1tx/10H/oK0fa7b/n4i/77FJbOrvcMjBlMnBByPurQBPRRRQAVz2qf8hW 6/64W/8A6FPX
Q1z2qf8AIVuv+uFv/wChT0nsCKNc2fEd/d+JNU0fStNtpm0xYTcS3V20ILSK WAULG+QABknH
J6d66SuO1nTpr3XrptS8LJqVqqwtYXti0cdzEVJZg0jyoykOARs4weT1qCjX sfElq/h601bV
1/sTz/laHUXEJR+QV+bGfukjoSOcCrT69o8WnxahJq1illK2yO5a5QRu3PAb OCflP5H0rhH8
O+K2tPBt9ey3M+o6Ytyt41pJC1wokXCYMv7tiAArEknnI3daZN4Mv7jSLGI6 bM/neJ11K8iv
biGVzCcq7uFVUGRzsXd16noHYD0G21jTLyxlvbXUbOe0hz5s8U6tGmBk7mBw MA5Oe1Q3PiTQ
rPyvtWtadB50Ymi826Rd6Hoy5PKnHBHFcd4g8Ja5Nr13Z6OUi0DXmjfVGWbY 9uyn94YwOMyq
ADw2453YFQan4V1W21zxKbKzvm03VLSCGGDTJLWJCqRGMxyecMoPQoDgN6jA VgO+udY0yzvo
rK61Gzgu5seVBLOqyPk4G1ScnJGBjvV2uI0rwrc2PjnS72SzQ2Vj4ejsY5mk WQpOr4wDgMTs
J+baMgnpnFdvQAUUUUDCiiigAooooAKKKKACiiigAooooAKKKKACiiigAooo oAKKKKACiiig
AooooAKKKKACiiigAooooAKKKKACiiigAooooAa7rGu5jx04GSSeAAO5PpTZ Fu7a42XFvKVa
NXXyYXk2klgVJUEZwAfx79SsiMWjkjfZLE2+NsZAOCOR3BBI/HjB5pP7W1Oe 5eOJYrdY0Xd5
sLOC5LZ2sGUEYCn8ecHiuatOopJRX9eZpBRadxySLIDgMCDhldSrKfcHkdj+ NOqONJA8sszq
80z73KrtXIUKMDJxwo7nvWT4j8KaR4rtYINWtvNEEgkjdW2uvI3LuHO1gMEf jwQCN4OTiubc
iVr6G1TlilcbkilZfVUJFRQwxW8EcEEaRQxqESNFCqqgYAAHQAVYiup4YxHG yhRnGR6nPrVE
hLbSwRxPIpAkUEHGMHGcEdjUVSyXk1xCqOeMAtxjJ/wzUVDAKKr2lhZ2PnNb 2yLJM2WfGSB/
dX+6M5PH8gKsUDPne/8A+Qjc/wDXV/5mii//AOQjc/8AXV/5mitCD6l0z/Wz f9c4v/Qa0qzd
M/1s3/XOL/0GtKktgYUUUUwCisvUtaFjcLaW1hd6leFBI1taGMNHGSQHYyOi qCQQATlsNgEK
xEia1YfbLWwuLqC11O5iEqafNPH5+MEn5Qxzja2SuR8p5OKANCisuz8S6DqF vdXFlrem3MFo
m+5khukdYVwTlyDhRhScn0PpUkOu6PcQW88Gq2MsNznyJEuEZZcOsZ2kH5vn dV4/iYDqRQBo
UVh3vinTYYpTZXVpfz297bWdzDDcqWgaadYfnAyVILE4OM7SOO25QAUUUUAF FFFABRRRQAUU
UUAFFFFABRRRQAVz2qf8hW6/64W//oU9dDXOavHHJqlyJFLDybc4EjJ/FP3U g0nsCKdFR/Zb
X/njJ/4FT/8AxdH2W1/54yf+BU//AMXUFElFR/ZbX/njJ/4FT/8AxdH2W1/5 4yf+BU//AMXQ
BJRUf2W1/wCeMn/gVP8A/F0fZbX/AJ4yf+BU/wD8XQBJRUf2W1/54yf+BU// AMXR9ltf+eMn
/gVP/wDF0ASUVH9ltf8AnjJ/4FT/APxdH2W1/wCeMn/gVP8A/F0ASUVH9ltf +eMn/gVP/wDF
0fZbX/njJ/4FT/8AxdAElFR/ZbX/AJ4yf+BU/wD8XR9ltf8AnjJ/4FT/APxd AElFR/ZbX/nj
J/4FT/8AxdH2W1/54yf+BU//AMXQBJRUf2W1/wCeMn/gVP8A/F0fZbX/AJ4y f+BU/wD8XQBJ
RUf2W1/54yf+BU//AMXR9ltf+eMn/gVP/wDF0ASUVH9ltf8AnjJ/4FT/APxd H2W1/wCeMn/g
VP8A/F0ASUVH9ltf+eMn/gVP/wDF0fZbX/njJ/4FT/8AxdAElFR/ZbX/AJ4y f+BU/wD8XR9l
tf8AnjJ/4FT/APxdAElFR/ZbX/njJ/4FT/8AxdH2W1/54yf+BU//AMXQBJRU f2W1/wCeMn/g
VP8A/F0fZbX/AJ4yf+BU/wD8XQBJRUf2W1/54yf+BU//AMXR9ltf+eMn/gVP /wDF0ASUVH9l
tf8AnjJ/4FT/APxdH2W1/wCeMn/gVP8A/F0ASUVH9ltf+eMn/gVP/wDF0fZb X/njJ/4FT/8A
xdAElFR/ZbX/AJ4yf+BU/wD8XR9ltf8AnjJ/4FT/APxdAElFR/ZbX/njJ/4F T/8AxdH2W1/5
4yf+BU//AMXQBJRUf2W1/wCeMn/gVP8A/F0fZbX/AJ4yf+BU/wD8XQBJRUf2 W1/54yf+BU//
AMXR9ltf+eMn/gVP/wDF0ASUVH9ltf8AnjJ/4FT/APxdH2W1/wCeMn/gVP8A /F0ASUVH9ltf
+eMn/gVP/wDF0fZbX/njJ/4FT/8AxdAElFR/ZbX/AJ4yf+BU/wD8XR9ltf8A njJ/4FT/APxd
AElFR/ZbX/njJ/4FT/8AxdH2W1/54yf+BU//AMXQBJRUf2W1/wCeMn/gVP8A /F0qwQI25InV
h0JuJW/RmI/SgD56v/8AkI3P/XV/5mii/wD+Qjc/9dX/AJmitCT6l0z/AFs3 /XOL/wBBrSrN
0z/Wzf8AXOL/ANBrSpLYGFFFFMDm9c0S9nvbi905Y53vLeK1uIZL6WyIWJ3d HSaJS6nMjhlx
8wI5XBD8/pngTVLe6tH1GaO+dnsrm7uX1S6AE0EUKn9wMJMS0AYSOQQXGVbY A3Wa94ks/D32
P7VHPL9pl2HyFDeRGPvzyZI2wpldz9F3LnrVj+3dH/tj+yP7Vsf7T/58vtCe d93d9zO77vPT
pzQBx914Dv7rQfDti1xAJNK0pLWTZNJH5kqS2koCuoDIp+zMu8fMu4EKSMVc 0PwbLZeILPV7
q3tFeJLpmQ3c15IksgtkVhNN8zHZA4JwmAwUA8seg8PeIdN8T6NBqml3Mc0E qKWVXVmiYqG2
PtJCuAwyM8VqUAeb/wDCD6/PrFpd3c8EjW/l+ZcyalPMbllu7WZnELJst8rb v8kZKgsq9FBH
pFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABXPap/yFbr/AK4W/wD6FPXQ 1z2qf8hW6/64
W/8A6FPSewIo1zFgunXuo6hHq3im+02X7Vci3iW4SOMxQpG8hy6kfKJMnnoC cYUkdPWJdeB9
B1vTp7XXoobrfqJvomRnjeLIQGPcFzhggDY9eOVVhKKYeDbqz1fTNQ1WwuNX uLEzPb2k+osM
TohjzKihVwCzMvOT8nY5UN1fX5bDVINPgisRNMqlGv702yzMzFQkWEfewI+Y cY3J13cdbNNa
rYpbWyQQwwxCKKGEEKqgrgAbQAAF6VzGt6Zf6tBNYpe20OnXMDQXCG2Z5SrA htj+YAp2njKt
g889KHuCK2meKrS4W4S/k+yyw3N1H5kkMkUJWKSQDEjDYzbE3EBj0Y4ABxdt vEGm3U0UKSzR
zyyeUkM9tJDITsdwdrqCFIjfDEYJUgHIxWdd+EYr7S00+e7cQ/a7y4dkQBit ws6lRknBAn68
529OeGXfhJ9W86XVryGa6l8qMtBA0UYhXzAy7S7Hc6TzIW3cBgQAVyUBtWOr WOpbPsk/mb7a
K6X5GGYpd2xuR32Nx1GOcVkaZ4qW9S5uZxYw2sCgukd4ZbqJ2OEjlhCfJITl dgZjuG0ZrR0z
RINLvtQuYjk3cm4DB/drlnK9Tn95JM+f+mmOiiuYk0rVvEdwsevadMmIykMh toFgX95HL+9T
7TI0iloIxgY4LDPOVAOjj8TaRJPbW4uXW4uWZIoHgkSUspTcChUMpAkRuQPl O77oJqQ+IdKW
1tbk3X7q6tvtUBEbZkjygGBjJYmWMBfvEsAATVLR/C6aTfQXavZoUjnRobOy W3iJkMPKqCSM
CEZ3FiSx5AAUR3Hg6znt9ViLIRfTxyqske9ECSecEZSfnUzNKxHBIkK5AC4A LsfibSJJ7a3F
y63FyzJFA8EiSllKbgUKhlIEiNyB8p3fdBNWtP1W01TzDaGZ0TH7xoJEjkBz go7KFkU4zlSR
gg9xWZo/hdNJvoLtXs0KRzo0NnZLbxEyGHlVBJGBCM7ixJY8gAKJtA0J9F+0 Fp4SJdoW3tIW
gtogueUiLuFYliWKkA4BxnJIA+bxHp629hNFOji/WOW33h1DxvJEm7hTg5mT AIGSRnAyQR+J
tIlOFuXALIsbPBIqzb3VFaMlcSLudBuXKjcpJwQarHwpAGvGim2G4vYLkfKT sWOYTlOvO6Qz
Nnt5uOigVnWXgK3sbOW3gexhZIFitbiDT1SVWRleOSZ8kysrRo2BsVjuypyN poB0lvq1jdXC
QQz7pX8/auxhnyZBHJ1HZyB79RkVDJ4h0qKGSV7rCRx3Mrny24W3cJMen8LE D37ZqDTPDNjp
Opm6tF2RLbJBFDlj5eFVWOSTnckUC4PTys9WbNK68E2N19t3Pj7TciQcN8kR 3+bH97nf5918
3VfO4+4uACfTPFVpcLcJfyfZZYbm6j8ySGSKErFJIBiRhsZtibiAx6McAA4m bxXpKRqzPeK7
SCJYDYTiYkqzAiLZv2kI/wA2MfI3PBqrd+EYr7S00+e7cQ/a7y4dkQBitws6 lRknBAn68529
OeGab4QSxu7W6B06B4LkTFNP05baNwIpYwCNzNu/fE5LEYUAKMkk0A2v7Wsf 7M/tHz/9G6Z2
Nu3btuzZjdv3fLsxu3fLjPFVX8TaXEkTSyXMYdd7b7OZTCmSN8oK/ulyrYZ9 oIUnOATTG0H/
AIkNzpm6zn865mn/ANMtfOi/eTtLho9w3Y3YByOQD7VkTeA4pjC89xbXk3kC CabUbQXbhd7v
+5aRjsIMjAb/ADOFTOdp3AG9b+IdKurr7NBdb5ftLWmBG2BMocshOMBgInOP TaejLmOTxNpE
Rw1y5AZ1kZIJGWHY7IzSELiNdyONzYU7WIOATTG0DOg3Omi5xLJczXUM/l/6 qVp2njbbn5tj
leCcNt54OKz9Q8DWF1PbmCKxWGK0jsgt3ZLdNFFGW2+UXPyNhzksHBwuRwcg G7YatY6nJcpZ
z+cbaRoZiEYBHVipUkjG4FTx1wVPRlJzLnxfYQtaNDFeXEE9z5BljtJiCDHI 4ePCHzVPl9Uy
MMGzjrp6Xp/9m2kkHm+ZvuZ5923GPNleTHXtvxnvjPFYVr4RuLQLNDf20NzD Os1tFBaslnEQ
kiHEHmHBYSuTtZQSFOMhtwBoax4ltNIt78skzXFrbSTqkkUkccxSMybElK7G bAJwpJADHHyn
D38TaXEkTSyXMYdd7b7OZTCmSN8oK/ulyrYZ9oIUnOATWLf+A4tR1KSee4tv JlacvKLQfbGW
WKSMoZy3KqJPlGzgIg5xmp9R8Htq13HeX8ml3F00C288kumCQKis7KYQ7t5b Yc5LbwSFO3gg
mgG7qGq2mmeWLgzM8mdkcEEk0hAxk7EUttGQCcYBYDuKz9G8SQ6hLJa3AeK6 W7uYEzbyJHII
5XUBZGG122JkhSTwxwMHFrUtNuri+tr+wu4be7gjkhBngM0ZRyhb5Q6HdmNc HOMZ4OQRSl8L
+dYwWv8AaE0Xl3t3d+bANkg88TjCnPysvn5Dc8r054AJm8V6Skasz3iu0giW A2E4mJKswIi2
b9pCP82MfI3PBoufFmjWlqLmS4maIRmVzFayymFQSCZAqkx4KsPnxyjDqpxm aX4K/s/WYtR8
3TofLkjfyNP0/wCzRttjnTkb2+Y/aOvogGO4paz4Z1WC0vrXSG899XjuILl5 IVMcSvLNIvJl
Vlx9ocFgsmQoO0dGNAOnPiHSlupYHuvL8vfumkjZISUBLgSkBGZQrZAYkbWz 904s2F/DqMDT
QJcoobaRcW0kDZwD92RQSOeuMflXPp4Kt4tQurlE0thM08itNpivMzy7twlk LfPHl2+UBTgK
pbGd2voWkvo9i8D3PnF5DJtQMsUQwAEiRmYogCj5dxAJOMDAABp0UUUDCiii gAooooAKKKKA
CiiigAooooAKKKKACiiigAooooAKKKKACiiigD53v/8AkI3P/XV/5mii/wD+ Qjc/9dX/AJmi
tCD6l0z/AFs3/XOL/wBBrSrN0z/Wzf8AXOL/ANBrSpLYGFFFFMDk/EPg+fxL rM8tzq93aae2
mNYpFaeVuYSsftAbfG3DKkABBBG1umea9n4X1o6NcRald2k2oXOp6dfTSoSF YwLaeaeFGCWt
5CABjlenOOg1LWhY3C2ltYXepXhQSNbWhjDRxkkB2MjoqgkEAE5bDYBCsRIm tWH2y1sLi6gt
dTuYhKmnzTx+fjBJ+UMc42tkrkfKeTigCv4X0+80fw9Z6TeCA/YIktYZYZC3 nRoiqrsCo2Mc
ElQWA/vGtiseHxZ4buLO5vIfEGlSWtrt+0TJexlItxwu5gcLk8DPWpJPEugw 6XDqkut6amnz
Psiu2ukETtzwr5wT8rcA9j6UAalFY+teKNH0GK5+230AuobSS8FksqefLGis zFEJBPCN7cHn
ipLPxFpWoXCRWd/aTpKitDLFcxusxJl+VMMSSPJkJ4x8pwTtbaAalFc/qPjP RNKvIYby9gih
klEJumuIhFG5E+Q5L5XBt3XkfeIAyQ23YW/s38vbdwN5srwR4kB3yJu3IPVh sfI6ja3oaALF
FFFABRRRQAUUUUAFFFFABRRRQAVz2qf8hW6/64W//oU9dDXPap/yFbr/AK4W /wD6FPSewIo0
UVk+GfC+ka7JrdxqMEsssepyRIVuZYwF2IcYVgOrH86hK5TZrUVYHhvStBWZ 9OtmiaWLDl5n
kOA69N7HHXt149K5fXdVv7G+SOOWGytPLDm7nsZbqMnJ3BjGyiFVAUlnOCH7 bDQ0FzoKKwrz
xZYWNpNPJFcs0DXIlgRVMiLCrMzsueFICbSevmxdNwoPieNHNvLpl9HqJZFj sW8oySBg7Ahh
IYwMRSnlwfkPHK5AN2iuYsvElwuq6jFf2N4lqt7DBHMfKKW5khhKxNtcsW8y TGQGHzj5sDie
18WQ31jZXFnpeozvexmaCDZHHI8QCbn+d1AUGRV65JOVDL81AHQUVz9t4vsr ubdBaXj2PmQx
fb9qCLdMkbRjaW8znzYx9zgtzgAkQQeMYUs7Ce8srxLe5svthvQkYj2CESO5 jWRpFUZC9CAz
KMnIJAOnorF0DxPYeI/tC2hxLb7TInnRS4DZ2ndE7rztbjORjkAEE0m8c6am kLqrQzLYzSCO
0meWBUuidx+UmQBMBGJEmw9sbvloA6eiubtvGlhfIzWNnfXmy0N2wt4lcBQZ VKhg21m3xMoC
k7iQV3LuYSaj4y0nTo3kaTzoh5QSWOSMRSNIrOEEjMEDBF3ncRwyYyWAIB0F Fc3beN9Ku0aW
JbloIrQ3k86oGjhjBlVsspIJDQsMLu3ZBXcuSNG21uGTRJdXureaztIozMWl aOTdEF3b1MTO
CuOmDk46dMgGnRXPyeK1hmjtZNH1EahJIqLZZg8whkkYPu8zZtxDIPvZyvTk ZujXbU6VFqHl
zBHuUtWjIG9JWmEJU84+VyQSCRwSM8ZANOiuf/4TLTCqGMTSmTzBGse07ysk caAfNj94ZomQ
nAKuGJANPh8U28uoQad9gvkvpGdXgKKxhKeUTvZWKgbJkfIJGOPvYUgG7RXE WPiy9utE8MXN
vFc30lw0Ud20KxKLhzayu6oWKrlXRSxGACCoJIZRdvfiDomnmJbl3jYqzTK8 kSNAFdo2yGcF
yGjkGIt5+XjOV3FgOqorn/8AhL7KPzpbu0vLWzjkuIlu5VRo5Gh3+YFCMz9I pCMqMhfUgGCf
xBqaa3YRLoeohJba5Z7TdbeYSjQbZM+bt2jewxuzk9OhoA6eisi78R2Ftpdh fxl7iPUGjSzR
NqNOzruUDzCoBKgn5iPTqQDWtPEVw8+tfa9Nmht9PwwkLxKAPIikMbEyY3gu 3PCYA+bvQB0F
Fc3p3jXTtVntYLOG5mmnaRSsXlyLGUMe7c6MUwFlVshiOq/fwpk8OeJJNXsd K+2WM1td31kb
oZ2eWwURbmXDsQpMowDzgHOOMgHQUVzdh4ytNQEcsen3yWbtBGbtxHsR5kje NSA5fJ86NchS
AT1wCa6SgYUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUU UUAFFFFABRRR
QB873/8AyEbn/rq/8zRRf/8AIRuf+ur/AMzRWhB9S6Z/rZv+ucX/AKDWlWbp n+tm/wCucX/o
NaVJbAwooopgYd/YalbazJq+kRWlzPcW8drPb3c7QrtjaRkdXVHIOZXBUqc5 UgrtIbLl8Pax
cXlwsiWKWt/qFpqdzItw7PBJCIMxIvlgSKTbj5yyEbydvy4bpI9Shl1m50tV k8+3t4bh2IG0
rI0iqBznOYmzx3HXtT03xRo+pxaX5d9BDdanaJeW1lNKiztGy7gdmcnABzjI +U88UAc23grU
jp3hK38+036PZW9vcHe2GaO4spSU+XkbbaQDOOSvqSDVfBmoT+IrvWIDHMZL iRo7ddTuLE7H
gtULNLCpbIa1PyYIIcHIK4rc0Lxjo+t2umL/AGhYw6nfWkVz/Z32tGmTfEJN u3hjhTnOBxzX
QUAcPF4Ov7XR9V8PW/2EaZqlp5L3SvIr2pFolsAkJDb1/dK3zSg/MRzty1i6 8PaxqN1farKl
ja6mbS1+xLFcPIkVxBLcONz+WreW6yqjYAJVpF75PYUUAcO3gu807WLTUNKe Cf7BFbCKO7mK
PcyIt4kryyKhwzfa/MLBWLMGyBndWhpmjf8AFX6leFJ0sbWUtbQyjEf2iWND NLGuMbcYAYc7
5brOd1dRRQAUUUUAFFFFABRRRQAUUUUAFFFFABXPap/yFbr/AK4W/wD6FPXQ 1z2qf8hW6/64
W/8A6FPSewIo1Joqw6LFdrFM7td3LXMm6IEKxAGB8w4wo/X6VHVZtQskco95 bqynBBlUEH86
hFGzdX63ETAkltu0Yj2jqD/ePpXOarox1bdFNqN5HZyRmKe0iEXlzKc7gxKF xkHB2sOOmDzV
2G6t7lmWCeKVlG4hHDEDOM8fUfnU1AHJXWhanfanq5uLDThaajGbQyxXjLLH AV2s4UwkGVhj
PzYIjiX+DJ1r7w/b3uoNqAubm3vAsSxzRFcxFPNAKhlIJKzyKdwIwRgAjNa9 FAGQPD9uYJ45
bm5lae7t7yWRioZpIRFt6KAAfJXIA7nGOMMHhuGGx023s768tJdPtvssNzF5 bSGLCgqwdGU5
8tCTtByvGASDtUUDMWDwvp1rYvZ2/nR27XNtcKgfOwwCIIoJBO3ECZzknJ59 Ktp4NtLWJ7b+
0L6WyltEs5bWQxlZIli8sKWCBwMZbCsBuZiAMnPSUUCKWn2Ell5jTaheX0r4 G+5KDaBnACoq
qOp5xk9yQABmL4Stlmluzf3janJIkn9obYVlBRGReBGEPyySLllJw3X5V29B RQMz7DSIrC7l
uhcXM88sEcMjzuGLbGkfd0GCTK3AwoGAAAMVVXwzZQ2MdvayTWrxXLXMM8IT fExDLgAqVKiN
jGoKnCBQPugjaooAzLbRUtZLmaO9vDc3FskDzu6s42tIwcZXAbMrHGNowAFA GKjtPDlhbaXf
2Ege4j1BpHvHfajTs67WJ8sKASoA+UD16kk69FAGLB4bhS/gv7m+vLy8hkVx NN5YJCpKioQi
Ku0edIemcnkkACp20K1bRrnTPMmEU8k03mAjzI3kkaTchxwyu2VOMggHqM1p 0UAYs3hbTJJJ
Xji+zl44kjEKqogMTBkdBjAbKRZzkEQxgghcU+x8P29lqC6gbm5uLwrKsk0p XMpfygSwVQAQ
sEajaAMA5BJzWvRQBzf/AAhtpFFpqWWoX1k1gqBHhMZMjJEYldw6MpbYSuQB kYznau2dPC1v
CQ1tf31uzqVumidQ10C7yHcduUJaWU5j2EbzjGFxu0UCMWfwvp11YpZ3HnSW 63NzcMhfG8zi
UOpIAO3E74xgjA59Z7TRjBfQ3lxqN5e3EMcsSPOIhhZDGSMIijgxDH1PXjGn RQBkPoEf/CO2
2iQXtzBbQQLblgkUjSxqmza4kRlII6/KPy4qFPCdhDA9tay3NvassW2BGUqk sQjEcoLAtuUR
RjBJU7eVOTndooAxdN8Nw6fqb6k99eXd2/mb5J/LG7esKnhEUcC3TGB65znh kfhiO3gto7XU
763a0VobaRPKZoYCE/cjdGQV/dpywL/L97k53aKAOV0rwaNPklik1C5fTknt 5ILTKbX8mGFE
aQ7A24PCGwrBTgcckV1VFFAwooooAKKKKACiiigAooooAKKKKACiiigAoooo AKKKKACiiigA
ooooAKKKKACiiigD53v/APkI3P8A11f+Zoov/wDkI3P/AF1f+ZorQg+pdM/1 s3/XOL/0GtKs
3TP9bN/1zi/9BrSpLYGFFFFMDm7zwhpureKrvVNX0zTdQgeyt7eBbqBZWjZH mZyNykAESJ0P
O056Cub0X4e32mtp8VwYLiNPsMs8g1K5RI5LeKFMLbLiOXJgDB3II3DKsEAb sL7xFBp2uQab
c2s6Ry2kt418zxLBDHFjeXLOGGN6fwkfOOcBsSR+JdBm0ubVItb019PhfZLd rdIYkbjhnzgH
5l4J7j1oA4fw14X162tJdCuLe0js7e902WS9Mz7na2t7Mny4zGA6FoNu7eMZ bglcH0ysOy8X
6DfXWo28Wp2gewQSylp0wYTFHL5y/N/qtsijecDIP1NPUfGtnbXGlCwEGo2u ofcuYLkFB/pV
vbnBAIbBuCev8GO+QAdRRWHY+JYb3xBcaSLeQFHnEFwpDRzLCIBIc9iJJzHg Z5ifJBGKLfxf
oM0yW8up2lrdyXEtvFa3M6JLIyTPDlU3ZILxsBjr9eKANyisO98U6bbeItO0 KK6tJ9QurgxS
2y3K+bAogkl3snJx8ijnH3wc9jHceN/Ddva2l5/bNjLY3N2bP7ZFdRtDFIIm kw77sLwmPXLL
xzQB0FFU49W02bVJtLi1C0fUIU3y2izKZUXjlkzkD5l5I7j1q5QAUUUUAFFF FABRRRQAUUUU
AFc9qn/IVuv+uFv/AOhT10Nc9qn/ACFbr/rhb/8AoU9J7AijXDSeIfDXhiS/ u/Enh9L21udS
ukF79kWYxOkUTJEcj+PL45HI9NzL3NFnDZ2UE0KW7Os9yLuQSMrAygqQwBU4 wUUj02g9ealO
xTM3wja6iug3Wo6poljo09/I0sFjawqjQW/7sRpJhQS+d7HPI39F+6uB418U DRJ7aCLVLazm
igk1CSOR03XKRFQLcBvumQscMOR5ZwDzjvZ78zxsrBySNoLMOOQeyj0rNW0g S+lvFTFxLGkT
vk8qhYqMdOC7fn9KG9QRkHxLE0F3PBEk0MN/a2aSJKCsqzCAiQEDoBP05zt6 jPGfoviDWrrR
NEWSys59TvrIXQZ7spG8arFudiIjtctKvyBSAM/NwAdNfCejJ9mEdvNGlt5P lxx3UqxkxbfL
LoG2uw2IMsCcKo7CnnwzpfkJCkdzEqMzRmG8mjaIEAFEZWBSP5V/dqQnyjjg UgMm18ZXWpPG
bDS4WguZI4bVp7sxszvbLc/OBGwVRGWGQWO4AYwch58bQvPpjwWjy2V6tvuk AkLwPOV2K+2M
xqfnjJBkBw2QD8u7ah0PTLeSOSC0SIxzidAhKqriHyQQoOABH8uOnfGeaqr4 T0ZPswjt5o0t
vJ8uOO6lWMmLb5ZdA212GxBlgThVHYUaAYWneKtTj0nQp9RgSS5vrASIIpxs md3to0aT92Ch
LT8hchRnhzjGhrPiq50K1iku7CGSVI2nvIrWWaYwxgnDArDjkBseZ5YypGcA kaA8M6QECfZn
2qrpGpnkIhVijYj+b92AYoyu3GwqNuKZc+FNJvLUW9wl46eWYXP2+cPKhJO2 Rg+6RRubAYkD
ccYyaNAOf0TXLq31y9F1JNPatciAs8pIg33t7GhC85yywx4HQEHotbsniGU+ GodXt7NJDczx
R20bzFFkSWZY4pC20lQysr425GcHkU+68M2MtpewWy/Z/t2Eumyz+bEZXkkT k8bvNmGRgjfk
dBi1rWlLrWm/YnmeJTPDKWQkNiOVZMAggqTtxkHIzntQBS07xDLda1/ZNzZp DdRrMZjHMZEV
kEDAKSqlgVuF5IGCpGD1rF0LxRf3P2nUprRDptzd2ajN0zSW7T29ttRUKbSo eUEncvVjjPB6
A+GdLMCRiO5VlZm89LyZZ2JAB3Sht7AhUGCxHyL/AHRhlr4T0aymjkt7eZRH 5e2I3UrRZjRU
QmMtsLKETBIzlQeozQBzGh+MLq38O2fnL5ziOBZLzULkx26f6Lbud8ojbazN LxvzuO75vurW
voWsX6SpBewo9tdape21tcC5Z5NyyzsAyFQFULGyjDHooxg8aCeE9Gjt0t47 eZLdduYVupRH
IBGkYDruw67I0XDAggH1ObqaTYx+Rsgx5FzJdR/O3yyyb97dec+a/B4GeOgw AYp13UbW/wBc
8yCGe0t72C1tSZtriSVLcKhAThN8pJfJIycKcCjVdXupvB3iVmT7HqGn208b mCYsFfyBIrI+
FPR15wCDn0BOvcaJp9zPPNLC+64ULKFmdVYggq+0EASDauJAN42jBGBTJNCt Bol7pkKfJdxu
kjTvJKXLLty7Ft7cYH3gcAAEYGADLuvF/wBhjlvbmx/4liyXMMckc26ZngWV nzGVChT5EmDv
JPy5Ayds+oa5qWmWMbXGn2bX0khCW0FxPNmMAZf5LcvwSAfkwNw+bJAqzF4c 0/eZrqBJ5pFb
zUJf7OXcESMsLMyIW3NkgZO9sk7jkPhrTmgSItfEozMsp1C481cgZUSb94U7 VJXO3IBxkZoA
z9B137bY65q6R3k9uJI7iC3A3S7DZwSBFXONxLHgHGSfWqsnjadYLdY7C2ub yZpcxWs08yxL
GE3CTZAZEkBkUbGjGO5BwD0Nlomn6dYS2VnC8EEqqrBJnDYWNYhhs7gQiKMg g8Z681AfDOlm
BIxHcqyszeel5Ms7EgA7pQ29gQqDBYj5F/ujABnp4tnkt9QvDo80NnYeU073 EgSRVaOKVyYw
CQ0aSOWX1QBdxY7Wah4xkt5/JtNNe5Z550hYeayukJRJGIiikdSJHKAFcHYT u5UHoLLTrPTh
KtnbpAsrKzKnC5VFjGB0ACoowMDiq0nh/TXsbO0EU0UVnGIbdoLmSKREAA27 0YMV+VcgnBKg
nJAoAy08WXU1vqFxFoV55Vp5ShWyZWeSOJwpjVWYbfNO/glQvyhySF2tJvv7 S0yG732b+Zu+
azufPiOGI+V9q56c8DByO1MXRNPjtLi1ghe2huGRnFtM8JBVURdpQgqAsaDC 4GB7mrVpaQWN
qltbJsiTOASSSSckknlmJJJJySSSck0ATUUUUDCiiigAooooAKKKKACiiigA ooooAKKKKACi
iigAooooAKKKKACiiigAooooAKKKKACiiigD53v/APkI3P8A11f+Zoov/wDk I3P/AF1f+Zor
Qg+pdM/1s3/XOL/0GtKs3TP9bN/1zi/9BrSpLYGFFFFMDj/F/h7WNdvJVsks Ray6JfaeZJrh
1cSThNp2iMgqDEuTuz85OPlwx4g8NX99rk2qWcUEkwitVtWN/JavbyxfasyA rG4bi4ACspVs
tuGBg7F94ig07XINNubWdI5bSW8a+Z4lghjixvLlnDDG9P4SPnHOA2K9x438 N29raXn9s2Mt
jc3Zs/tkV1G0MUgiaTDvuwvCY9csvHNAGfH4f8QWtrqlsmoQXEl95NxLfb2t 5JJUihikj2op
8tZFhb94rbkMnyqSoJw7XwBrP9pC8la0hBvVuDE2oT3bBRLp7482RAzHFnL1 6bkHTJHePruj
x3l1ZyarYpdWkRnuYWuEDwxgAl3XOVXBByeORUcniXQYb2Gyl1vTUu5n2RQN dIHdt5jwq5yT
vVlwO4I6igDm9I0nWIbHR9cs7WA3zxXks1hfSvb+T9smS5ZS4RzujKhMFRuy T8uNpyx4X143
ev6SlvaeRq+mbLq7eZ1W3ae4vZHEQ8siYoJ+hMecKTt3cdpqXijR9Mi1TzL6 Ca60y0e8ubKG
VGnWNV3E7M5GQRjOB8w55rQsb+z1OzjvLC7gu7WTOyaCQSI2CQcMODggj8KA OPm8M+IPPt7S
znsba1ttQvb+HUfMZ5le4S52/uCm07HuB1k+YJnAzgU7LwfrlrrZ1pYbRZ4H t3gtZ9ZubsSl
Euo23TSxloxi6BACsMoem7I9EooA4vSvB1xYeJRdyrHJbxXtzfRTtqNy53TG Q7VtsiKMjzmX
eC2QpO0F8r2lFFABRRRQAUUUUAFFFFABRRRQAVz2qf8AIVuv+uFv/wChT10N c9qn/IVuv+uF
v/6FPSewIo0UUVBYUUVmazqV1YNYRWdpDc3F5cmBFmnMSLiOSQksEY9IyMY7 0AadFYtn4msZ
rC8uLlvs72EbyXiAM4jCPLGzAgfMu6GTHGSAMgZxWZL4yEehaxMV2ahZ/bvJ WS2lWGUwNJtA
cgK7bY8kK2eG6YOAR1tFZEHiKyllSAs7zvPJFstoZZgm2VowXIT5ASjcthcq 2CwUms/SPGFv
f6Fp91N+6vLiO2MkcsEsKMZGRGMZZTvUNIBlcj5lywDbqAOnorFtvFmjXdqb mO4mWIxiVDLa
yxGZSQAYwygyZLKPkzy6jqwy/wD4SKyl0fUtRt2fbYK5mW5hlgKMqB8MGTcB tZTkKeDwD0oG
a9Fc/feMNNtrHUZofOlls47hgskEkUczwhi0aSMu1m+RvuknCscEA1ZfxNpc SRNLJcxh13tv
s5lMKZI3ygr+6XKthn2ghSc4BNAjXorMt/EOlXV19mgut8v2lrTAjbAmUOWQ nGAwETnHptPR
lyTeINNghWZ5ZvIMksTTLbSNHGY3KOXYLhFBB+ZiBgE5wM0DNOisJNelXw9d ajJAkk8d3Paw
QoSoldbhoYkyc4LEICx4BJPAoPia1s7h7G+keW8jYoRZWc8pYrHEzsUVW2DM y8ZYYI+bOQAR
u0VSudWsbaxivGn8yCbHkmBGmM2RkbFQEvwC3yg8AnoCahHiDTTdRW5lmV5N gy1tIqIzgFUd
iu2NzuXCMQ3zLx8wyDNOisgeJtLaB5lkuWjDKqMtnMfPJBI8rC/vRhS2U3Da M9OaY3izRkkV
DcTHMYldltZSkKlmXMrBcRYKODvK7drZxg0AbVFc/f8Aiq0ttVsrSOT909zJ HdXEkMghRUhl
dsTECPcGjAIycYYEAg4mk14H7HdRRTCxkuRazm5tZYJEZ8CNgHAJUuVThTy+ cgI2QRtVkf8A
CQI1xcRQaZqtz5Ehike2s3kUMMHGVyOhB/GtG1u4L2Fpbd96LJJETgj5kcow 59GUj8KraBdX
lj4Y8Y3mnW/2i+gvLmW3h2F/MkWBCq7RyckAYHJppXBsg/tyT/oBa9/4LZP8 KP7ck/6AWvf+
C2T/AArpfDGqXWpfaheahBcSR7CIV0qewkjBz8zJM7MytggMABlWGSQcdBVc qFc86/tyT/oB
a9/4LZP8KP7ck/6AWvf+C2T/AAr0WijlQXPOv7ck/wCgFr3/AILZP8KP7ck/ 6AWvf+C2T/Cv
RaKOVBc86/tyT/oBa9/4LZP8KP7ck/6AWvf+C2T/AAr0WijlQXPNT4ljVira RrQI4INg/H6U
g8Twb0VtN1WPe6xq0lmyLuYgAEnAGSQOav614pktrm6tbS21YSxGRFlSxleL fubBwCNw5HQj
OOD3rm5dU1PUtP0ixvE1S7u4b23kluZNPkhRwrjLEZIU468469OlTYZ2ciGK V42xlSVOPam1
Nd/8fk//AF0b+dQ0hhRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFAHzvf/8A
IRuf+ur/AMzRRf8A/IRuf+ur/wAzRWhB9S6Z/rZv+ucX/oNaVZumf62b/rnF /wCg1pUlsDCi
iimBx/i/w9rGu3kq2SWItZdEvtPMk1w6uJJwm07RGQVBiXJ3Z+cnHy4aTV/D upTeLE1+xNpI
9ulsYbeeVoxIyLdo4ZwrbRtugwIDZKEEDOa2NY1oaMbNpLC7nguLiO3aeEx7 YGkkSNC4ZwxB
Zx90NjBzipIdd0e4luYodVsZJLWVYLhEuEJikZtiowB+Vi3ygHknjrQBw+of D2+uotWtozAy
z/2hLbXM2pXLASXKzAD7N/qo9vnkFxvJCk7QXyu5q3hSa6t/EVvYC0t4NQ0K PS7SMZRYmQXA
GQBhUAmQDGeh44Gdy+13R9Miklv9VsbSOOUQO89wkYWQqHCEk8MVIbHXBz0r QoA87ufh3cXj
6laSyRrb3D30sV419cylGuVmHy2mREhXz2G4FtwU8Avle8sXvJLONr+CCC6O d8cExlReTjDF
VJ4x/CPTnrViigAooooAKKKKACiiigAooooAKKKKACiiigArntU/5Ct1/wBc Lf8A9Cnroa57
VP8AkK3X/XC3/wDQp6T2BFGiiioLCszWdDtdcawW8jhmt7W5M7wTRCRJf3ci AEHjguGzz938
Rp0UAc3rHheW8gu4NMu7awhvLAafNG9qZFWJQ4XywrptIEr9cj7vAwc1rrwb dX1jdWFxqkP2
R5Lya3EdoRJG9wJgd7GQh1UTvwApJC8jkHraKLiOYTwk8eoQXC3kMYjuZJ2l hgaO5cNO83lG
UPgxZcAoykHBPBIKh8IZtNCg+3f8gq2ig3eT/rdktvJn73y5+z4xz9/Pbnp6 KAOVuPCbJpOl
Rx3LyzaTYCCIJEMzSI8EiHBYDG63AK7hkMfmXGaLDRdT1Dw/4gg1Vkt7nWGk GViAMSmBIQSg
kcZ+QnAc5GOQSQOqoouBxF3os99Amjz6Xqgtft95K90htgpS4E6kjMxYACfO dpJ2/d5wLuo+
D21a7jvL+TS7i6aBbeeSXTBIFRWdlMId28tsOclt4JCnbwQeqoouBitoGdBu dNFziWS5muoZ
/L/1UrTtPG23PzbHK8E4bbzwcVma74Gg1SxSztXs4rdLIWUSXlobr7OoBAaE l1KPg8sc52J/
d562igDCn0GUeHrmxt50e5+1yX0DSAqnm/aDcIrYydobaDjkgHGCeCw0Nk8Q Sa68jxtcLIxt
XQboy8dsuCwYgkfZ+2R83XjJ3aKAOfl8NufC2m6NHNZu9jHFGs9zas+CibQ6 BZFaN+4YNlec
etVYvBNvDq0V55ltcENDI9xeWaz3ZeJEQFZiflBEak/KTkuQQSCvVUUAc3D4 cv7ewsbWLUrb
Glsh05mtGO1VjeLEv7z94djnldnzDOMfLTF8IYsNYtzfZfVLJreRxDwju88j uBu+7uuDhc5A
UZY9a6eii4HMT+FrqSZI1vrNtPiubm6S3nsjIWeZJQwdvMAZMzsdu0EgAZ6k kPh66t7W000y
+bbtereXDplIoFiKtHFCjMxRS6R/LkqB5mCuUFdPRQBDaxTxQstxcee5kkYP sC4UuSq4H91S
Fz3xnvT/AAVCtzY+I4HMgSTVJkYxyMjAGKMcMpBU+4II7U+pEmMaBUSEDr/q l/E9KadgaNfS
tFGm3FxdzX93qF5cIkb3N0Iw3loWKIBGiLgF3OcZ+Y5JAAGpXLfaZP7sX/fp f8KPtMn92L/v
0v8AhT5hWOporlvtMn92L/v0v+FH2mT+7F/36X/CjmCx1NFct9pk/uxf9+l/ wo+0yf3Yv+/S
/wCFHMFjqaK5b7TJ/di/79L/AIUfaZP7sX/fpf8ACjmCxma14v0ezubq0j1S xiu4zIrGWISB
JNzY3DjOOMgEemRXM3PidNU03R7SfUtPn1Fr62adbGIxof3gOFzyQOOp5xnA 6DuftMn92L/v
0v8AhR9pk/uxf9+l/wAKVxhd/wDH5P8A9dG/nUNK7s7s7HLMck+9JSGFFFFA BRRRQAUUUUAF
FFFABRRRQAUUUUAFFFFABRRRQAUUUUAfO9//AMhG5/66v/M0UX//ACEbn/rq /wDM0VoQfUum
f62b/rnF/wCg1pVm6Z/rZv8ArnF/6DWlSWwMKKKKYGHrthqWqzWtlFFaJp63 FvdS3LTt5qtD
MsuxYtmCD5ajcXGNxODjB5u18D6ndas8msz74zp89q97HqU0s0kzyQus8cUi eXbMDEXAjJCt
txkKDXWaxrQ0Y2bSWF3PBcXEdu08Jj2wNJIkaFwzhiCzj7obGDnFZ+j+M7LV LeG4uLO70uC4
sjqEEl+0QWW3UKWkykjBQokjJ37T83GcHABnz+GdZ/suz2yx3F3I8lxqUMeo z2SzXEm071ni
UyFIwDGiMMbCmTmNa6Dw1ps2jeFdI0u4aNp7Kyht5GjJKlkQKSMgHGR6CjQN ch8Q6Wt7Fa3d
m4cpLaXsYjngYdpEydpKlWAPVWU961KACiiigAooooAKKKKACiiigAooooAK KKKACiiigArn
tU/5Ct1/1wt//Qp66Gue1T/kK3X/AFwt/wD0Kek9gRRrE0q31XXb7UI4fENt ZGG6liit3tFk
dkQRksPnBIBkUHjjI55rbrmL/wCHlp4isZ11G7nsrn+0ZbiC4s7hQ4t5USOW NgTj50QjvjIz
kblMopmh4YvItWh1S5g11dXt7WdrRZYrUQxmRfLLMpDNvX94ADwOCRkYNSax rtron2X7RHNJ
58m0+UAfJT+KZ8kbYlyNzdBuHrW/FZ6bpWiw6bpdtFa2dtD5cUKOpx8ynsSS Tgkk8kkkkk1x
+t+GJte1SaSfU7m2smsGs1jtvL3MJGPnbt8bcELDgg5G09O49wRvNeWq+Zuu YR5ciwvlx8rt
t2qfRjvXA6ncPUVl2fi3QrzRLfV/7Us4LSbau6e4Rdjld3lsc4DgHlc5rITQ dfECwzvY3LXN
3ZXt7cmZkZZIRAJAiCPDA+RkHK/fxgY5nstG1jTINJMEVjPNplo+nor3LxrN ERFiUkRttbMP
3MMPm+/xygNq417R7SeeC51axhmt1DzRyXKK0SkgAsCeASy9f7w9amfUrCLU ItPkvbZL2Vd8
ds0qiR155C5yR8p/I+lc5o/hK60k2Ef2iGWK0vY5t/Kl0SwFt05wxcZxnGO+ eKpReEtZjtdH
tZJoZks/sOXF/NGkQgMZdBCq7JclGYO+D84HG0UAdBpvirSdVsYLy2u4fs8l s1w7tPH+4ChC
yyDdkMBIM9QO5GRm0Ne0dktHXVrEreMUtmFymJ2B2kJz8xyQOO9c3/wiupm0 0mAvZj+yLYQQ
sJWP2jy5baSMt8v7vd9nYEDdt3AjfT/Emh69r+nyxFbZGntHg8hNTnijgc7h vykY88MCmVdQ
BsIGdxoA1NJ8SxalqdzZSRJbtExSMtKCZWE1xHgDA5xbF+/BP93J05tSsLez kvJ722itY2KP
O8qqisG2kFicAhvl+vFclJ4cv9PXUbxAkt1JOj2Jh3MY5TeXEil+MiPbcKsm 3nZ5o+unrOmS
2XhS2sdNie6mgu7Nl8xjulZbmNmeRlU8khmZsHqzYoA2rXUrC+SJ7S9trhZl Z4milVw6qQrF
cHkAkA46Eis/T/FGmahqt1pyXtmLiORVgjFyrPcI0KSiRV6lcOemR8pOfTPi 0bWLbVn1yOKx
kvZ2lElo1y6xorpbrkS+WSxH2YHGwf6w8/L81LSPC2sWNhFpc/2E2vn2Nw9w k7lw1vHbgqIy
gBBaDGdwwGzjjBANrT/FenXOh2+qX1xbadHKsWftFzGFDvEsoXOeuG6EAnGc YIJm0fxFYavL
cW0dxbLe2888clqs6tIqxytHuK9QDgHp/EOvWuYsfBusadZQJbTW0V+ipGl9 HdODbr9mt4nx
EYyswLQE7WxwFwVJyu9b6FdQ/wBm7pIT9l1a7vXwTykv2jaBx9798ue3B5PG QC7H4h0x7/Ub
J7uGG40/5p0lkVSE2I5kxnOwBwCxwMg1Zi1Kwn086hDe20lkFZzcpKpjCrnc dwOMDBz6YNYt
7od/JPqQgNs0N1d2+oIzyMrCWEw4iICn5WEH385G77hxyS6Hf3fh/wARQTG2 ivdYWQiNJGeO
JjAsKjeVBYfIGJ2jGSMHGSAa8usaZDJBHLqNnG9xI0MKvOoMjq21lUZ5YNwQ OQeKYNe0dp3g
GrWJmSdbdoxcpuWUkgRkZ4YlWwOvB9Kwtb8Ite3zG1hh+yTWUdi0P2ye2jhR C+P3cWBKuJCN
hKgBcA/McR3fhO/nsbuBZbYNNaatApLNgNdTiSPPHQAfN6HpmgDev/EOmWEe ob7uGW4sLZ7m
e1ikVplRV3E7M5HBGM4HI9aeNe0dktHXVrEreMUtmFymJ2B2kJz8xyQOO9cX fWT6i8vh+QXM
Vt9rvHju10+6cs9wJ02keUECqbgnf5hBCA8Bvl09W8NahrN291cwWwa7tFtL iFNTuEjiVWkO
7EYTzwRJyjbMbSAfmJAB09/qVhpcCz6he21pCzbBJcSrGpbBOMkjnAP5Ux9Y 0yO6uLV9Rs1u
LaMzTxGdQ8SAAlmGcquCDk8cis/xDpV/fz2k+mMlveRLJGt6bhla3VyucRbG SYHaMq+PujBB
+YYV74Ju7iPUoE8kib7bJBPLfXBAedZQB5H+rjx5xBcbiQCdoLZUA7D+0rDZ O/222226l5m8
1cRKCyktzwAUcc91b0NMfWNMjuri1fUbNbi2jM08RnUPEgAJZhnKrgg5PHIr P1Lw5Fdz2Qtg
lvaoot7qCPCLLbqQyx7QMEBlC4PGySUfxVhXvgm7uI9SgTySJvtskE8t9cEB 51lAHkf6uPHn
EFxuJAJ2gtlQDrZdY0yGSCOXUbON7iRoYVedQZHVtrKozywbggcg8Vdrn7rR LpNbs7jSVhsY
I44oZpY5z80MbMfJ8jYU24JAcMrLuOOBhugoGFFFFABRRRQAUUUUAFFFFABR RRQAUUUUAFFF
FABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAHzvf8A/IRuf+ur/wAzRRf/APIR uf8Arq/8zRWh
B9S6Z/rZv+ucX/oNaVZumf62b/rnF/6DWlSWwMKKKKYGHrthqWqzWtlFFaJp 63FvdS3LTt5q
tDMsuxYtmCD5ajcXGNxODjB5+H4emDwHDokdzIuoS2UFhd3L3UkwSElBcrB5 u4RhkVgAqqMh
MgbRjc1bxZBpGo3NtLp19NDZ2iXt5dw+V5dtCxkG5gzh2wInJCKxwOAScVY0 zxFZ31jeXM8s
Fr9jluFnV5h+7jimliEjE42q3kscngYIycE0AV9A0G90XWNWmm1We/tb/wAm bNyIxIJ1Uxuf
3caDaUSADryrdM89BWf/AG7o/wDbH9kf2rY/2n/z5faE877u77md33eenTmo 7/xFpWk3EkWp
39pYoiRt5t1cxxqxcyYUZbOf3bHkAHBwThsAGpRWXqeu22n6ImqxJJfwSvAk C2jIxmMzqke0
swUgl15LAY5qOHxLYCzuZ9Sb+yGtdpuYtQkjjMIc4RiwYoVY8BlYgkFc7lYA A2KKpjVtNa3e
4XULQwJbrdPIJl2rCwJWQnOAhCsQ3Q7T6Vn6z4p03SrLWGiurS61DS7KW8l0 9blRLtRN3zLy
VByvJH8QoA3KKz313R47y6s5NVsUurSIz3MLXCB4YwAS7rnKrgg5PHIqv/wl nhv+zv7R/wCE
g0r7D5vkfaftsfl+Zjds3ZxuxzjrigDYorPfXdHjs7q8k1WxS1tJTBczNcIE hkBAKO2cK2SB
g88io38S6DHcWlu+t6as96iPaxtdIGnVzhCgzlgx4BGc9qANSisvR/EOm66b xLK5jaeyuJLe
5g3qZImSR48soJKhihK5xkc1qUAFFFFABRRRQAVz2qf8hW6/64W//oU9dDXP ap/yFbr/AK4W
/wD6FPSewIo0UUVBYUUVVv8AUrDS4Fn1C9trSFm2CS4lWNS2CcZJHOAfyoAt UUyGaK4gjngk
SWGRQ6SIwZWUjIII6giqratYrplzqRnxaWvnedJsb5fKZlk4xk4KN0HOOM0A XaKZFNFOheGR
JFDMhZGBAZSVYcdwQQfQg1BBqNncafbX8dwn2W5WNopH+QMJMbOuOSWAA65I FAFqiimTTRW8
Ek88iRQxqXeR2CqqgZJJPQAUAPopk00VvBJPPIkUMal3kdgqqoGSST0AFPoA KKKKACiqseo2
ctnNeC4RbaFpVklf5FQxsyvknGACrc9OM9KktruC8jLwPuxjepBV0JUMAynl WwynBAPIoAmo
oooAKKKKACioZ7uC2mtopX2vcyGKEYJ3MEZ8e3yox59KJbuCG6gtpH2yz7vK BBwxUZIB6bsZ
OOpAYjhTgAmoorJ8M+F9I12TW7jUYJZZY9TkiQrcyxgLsQ4wrAdWP50JXE2a 1FZ39ieAzp32
9be+e3aXyYij3rNcNjdmFQd0ylcsGQMpUE5wCRoWPgrwhqNnHdWtrPJC+QCb y4UggkMrKXBV
gQQVIBBBBAIquUVxaKn/AOFeeGf+fGf/AMDp/wD4uj/hXnhn/nxn/wDA6f8A +Lo5QuQUVP8A
8K88M/8APjP/AOB0/wD8XR/wrzwz/wA+M/8A4HT/APxdHKFyCip/+FeeGf8A nxn/APA6f/4u
j/hXnhn/AJ8Z/wDwOn/+Lo5QuQUVmX/hHw3YrJI9nfMqB3IivJ2OAzDAUEkn A6DJNc9dWGi/
2XpOo2Gnahavc3tujR300odFLgMrRsevBHOQR0yCDSsO52lFTXf/AB+T/wDX Rv51DSGFFFFA
BRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAfO9//AMhG5/66v/M0 UX//ACEbn/rq
/wDM0VoQfUumf62b/rnF/wCg1pVm6Z/rZv8ArnF/6DWlSWwMKKKKYHN3nhOD U/FV3qd+ZJLS
Syt7ZYEupUWQo8zOJY1ISRCJFGG3A/MCMHnn7zwbr0WneILewGmzvrdvdWrm e5eIW6vcXUqO
MRtvO26wV+XBTgtnI6TVvFkGkajc20unX00NnaJe3l3D5Xl20LGQbmDOHbAi ckIrHA4BJxWw
1/Zp5m67gXypUgkzIBskfbtQ+jHemB1O5fUUAcGNP1B/E9loP2OSTT7XU7zU Jr6M3ELBLiO4
OA3lqmQ1yFzHKzcZwvzbNT/hD54PF+n6lbT7rG18nIubmWaY7I75W+Z9xPN0 mMt0DdMAHcs/
Eug6hb3VxZa3ptzBaJvuZIbpHWFcE5cg4UYUnJ9D6Vj6d44F1CZb3Q9SsYoE h+33Evl+VZyP
DHKVfLCTCiVQzeWAvJbABIACfw7qS+FJbC3NpJeDWDqMYklZI2X7f9pClgpI O3j7pwfUc1T1
bwlqeszx6xc+QmppLERZ21/NBH5caToq/aUUSBs3LuWCAEBU29XO5rPinTdK stYaK6tLrUNL
spbyXT1uVEu1E3fMvJUHK8kfxCrljruj6nFHLYarY3cckpgR4LhJA0gUuUBB 5YKC2OuBnpQB
zcfggi102ENHAheRdThjnkkWeF5Wn2M0m5pj5nyEvgMk0/yrvAGXqHw9vrqL VraMwMs/9oS2
1zNqVywElyswA+zf6qPb55BcbyQpO0F8r2l74l0HTUje/wBb021SR5ERp7pE DMjbXAyeSrcE
djwa1KAPN/E/hbWJPDOq2ccUEtrbf2nf2zwu7z3ElxFcgQ+VswuDckBg7E7B 8o3fLsJ4e1i+
8VWWv36WNtJDLEHtoLh5h5ccN2oYOY0yxa6Hy7QAEzuJOB2FFAHm/wDwr/U1 tdIJmgkm03T9
Pt/KivZrbzZIIrqN/wB9Gu9FxchgQCTtKkAHNXI/BF7FoniGzia0ifVNHNnG vnyyBJme6di7
vl3GblcueWIY7V4Wu8ooAx9A0+80pb20mEDWpu57m3mSQ7386V5WVkK4XaX2 ghm3Yz8vStii
igAooooAKKKKACue1T/kK3X/AFwt/wD0KeuhrntU/wCQrdf9cLf/ANCnpPYE UaKKKgsKwvEd
vf3F1oR08ok0d+zmWSBpUjX7PMMsoZeMkDqOSPod2igDhdThv/D9hrdvE+oz vd6c5tHs7eVx
9sd7iSQqIw3lfNLHgsegHzNtJGXe2d2dI1i1sLbVzeSyap9qidLjyXhf7QY/ LD/uyzOYCPL+
Y5PbdXp1FFxHCxf2r/bFp539o3P+mzBbU/aYFjT7XKRKZl/duojCYik4KqNp G7a1Ww0/VNK0
fw1BZrqiCa0tWvY2kmfy3We0BXDE+WNjT5UbQVByMLx6JRRcDz6C11my0bR/ KbV2a606OXVP
NmmlkVhJbeYF3EtG/lvcYVMMSOASq4tWs08vhfximlyao7RNKlks7Tm4Rvsk TAL5v7wHexI+
vHUV2k0MVxBJBPGksMilHjdQyspGCCD1BFMtLO1sLVLWztoba3TOyKFAiLk5 OAOBySfxouBw
mp6Vq0+iXQthqMt5qFzqVrLHNPI0ZhK3PlYR22RqSsIDADggZwxyapFqMlxb /wBlXmr29kLY
fYvMtbyaVrjzJN+/dImP+WWPtGUI6YXdn0Gii4HJQ22p22lXOqmbUZru31G4 nFq7MfMt1mlX
y0QY3ZjYsnq3l5O1VAy/Ea6/ZaZCqTXn9oQ20lyk1rFdXKzXTszNEojYBUQ7 QvnKylWAx8rZ
7e/02w1SBYNQsra7hVt4juIlkUNgjOCDzgn86LDTbDS4Gg0+ytrSFm3mO3iW NS2AM4AHOAPy
oA5i4hlt/BN6biN44U1See5V1Izai+Z5SR/Eph3HHO5TgA5wQ2F7qPjO6hvH 1RNNDTtGYbma
BM+VZhcMjDIyZ8DOM7+4NdjTIYYreCOCCNIoY1CJGihVVQMAADoAKLgcreza lN4J0ea6mvIr
x44XvIorafzJm8slo2MA3w5bBLAcEYIIO050MWvN4gtWmlvrMq1t5NoI57lV h8uPzVebzBCT
u84FpFaTjK5JjFd9RQBwtv5/9k2f2r+3fP8AMj/tzb9qznypM+Tj+HztmfI4 xj+CoPsusyWm
rXZbVxPaacZdLUTTLuYS3JiDJnEj+WLfKyBmPAYZJz6DRRcDz6/hu5NVgdn1 eLVYr28dpxb3
E9vBD5NwsLqgBhZgph4X5iSQfmLVatxOdFsojBcx3T6xALSWeadnmVSrSuBP +8hBiScFCegY
AtvBbt6YYYmnScxoZkVkWQqNyqSCQD2BKrn6D0ouBV0v/j0k/wCPz/j5n/4+ /v8A+tfp/sf3
P9jbUOj6bNrPhDxtpdu0az3tzd28bSEhQz26KCcAnGT6GtOpNFWHRYrtYpnd ru5a5k3RAhWI
AwPmHGFH6/SmmDMqLS9ZivrTUYNM1UWFjdpOmm3t+lxdu5huIpGR3mddp86H CtIP9XIQASN/
UeGLG4sNFMd1H5U013dXRjLAmMTTySqrEZG4BwDgkZBwSOSv9sf7X/kH/wCz o/tj/a/8g/8A
2dVdCsa9FZH9sf7X/kH/AOzo/tj/AGv/ACD/APZ0XQWNeisj+2P9r/yD/wDZ 0f2x/tf+Qf8A
7Oi6Cxr0Vkf2x/tf+Qf/ALOj+2P9r/yD/wDZ0XQWOZ1nwzobXV3f3q3ryO0k r+VJM5wGPAVX
yenCgegArnZLPw4unaTq+kw3M6XN5biFrhp0G0yDD7WbJ6ZGRg8HkdeivdFF 9eS3LeIdaj8x
iwji8tUTJzhRjpVb/hF7V5oHn13WbhYZUmWOXyypZSCM8e1SM3bv/j8n/wCu jfzqGpJ3EtxJ
IucMxYZ9zUdIAooooGFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQ B873/wDyEbn/
AK6v/M0UX/8AyEbn/rq/8zRWhB9S6Z/rZv8ArnF/6DWlWbpn+tm/65xf+g1p UlsDCiiimBye
teDTrWvX1/JdyQpLZW0EKpNJsZo5JndZ4QQksTCRVKtnILgbc5qvd6Br09xM qQ6b5F/qdjqV
07XbhrdoTb740XysSDFvwxKZ38qMcs1fxFc2msT2Npa6hfTxjzZI7aSNfKRm YISZHQHJR+mc
becZGVfxHaR3VxavrMK3FtGZp4jdAPEgAJZhnKrgg5PHIqeYdijqfhTUoPCe j6fiOZ4tCOgX
Bg3OUa4a1iMyjHzIipI5zt4UdMkjUvPD2sXdz4j08pYrpGuS5luRcP58UZto oXVYvL27j5bY
YvgbgSrY2ln9uw7J3/tVNtupeZvtAxEoLKS3PABRxz3VvQ0x/EdpHdXFq+sw rcW0ZmniN0A8
SAAlmGcquCDk8cijmCxm6h8Pb66i1a2jMDLP/aEttczalcsBJcrMAPs3+qj2 +eQXG8kKTtBf
K6k+ga9d63H4ilh02PULd4RFYrdu0UixpcplpvKBUn7WxwI2/wBWBn5srr6H em8uHK3PnxgM
uRJuAZW2sPqCCD6EEVu007iPJ9Y0XX9I0XVraOxgvL/xFaXVq0MDTuluzz3M qYkWAqc/a8Zk
8pRszuwSV9YoopgFFFFABRRRQAUUUUAFFFFABRRRQAVz2qf8hW6/64W//oU9 dDXPap/yFbr/
AK4W/wD6FPSewIo1kf8ACQI1xcRQaZqtz5Ehike2s3kUMMHGVyOhB/GteuRT UPGOkxX974V0
6DVIzq9xBc2chw2+SOAQyg8fKjA7uR8rHOAN6SlcpnSWF5JfmbOn6haiJQxa 7tmhDcgYXd16
9un5VaqHQPDt94d0GddW1STUtWvpHvL64b7plbyl2oMDCKqKB9OAowo47XNH l1jxhqEUFlYv
N/ZdsqX07ES2TNJcASQgIcsD833k5Vee4GtQR29FcWdU1JbD7Veax9mtJtWu bV7kRRoLOCN5
wpLMCu5mSNNzDGCoA3HcaUet6zcSyONUmSKP7LDEUiixOk17NbickocsY1jk UrhCcHaVO2lY
D0GivOJfE9+s1+j675V3Z2z/AGKzKwg6hMlxcxAFSu5mbyYgRGV5Y4xkY6Pw kBH/AGpA9+8k
639y72TlAbZXuJWQ4ChgHUhhuJyMEcUWA6GGaK4gjngkSWGRQ6SIwZWUjIII 6gimXN5a2flf
armGDzpBDF5rhd7noq56sccAc15po+u3tn4S06PSNXTUANLhNyXaIrprb4Ew WRP3YCPM2ZA+
PJzghWB09Gm1DVPEWlST6skvkwXhS4snSVZ4w9oSjSGFVYbiwJjVcYAzuDUW C531Fedr4j1e
S1tDa6skt5crbm9jeKN102d7i3TySqhWUESTDa5L/u+GBBNXZtW1mDxaun/2 lbCOKeCGOC4l
US3cRRC8vlLCWc5aT5ldEBTkAI2SwHb0VyWu3+pQ69cR22ozQQRR2CCJI4yC bi4khZyWUnco
AK84yBkMMg4us+LtSsdKMqX8MFxZfajuup44UvvKmkjVQpiYyPiIF1Qx/wCs XBG4bSwHokU0
U6F4ZEkUMyFkYEBlJVhx3BBB9CDT687i1C5tbYxTskUEuuNHaKY1dJ2Opnfk sOJFAO1RjjLg
sQfKfBres2ujaPPLqk1wdT06O7uJpooh9kHmWyyOm1FAVUnkYlwwGxSeA2Sw HoNFcQNVe48G
+MJYtVTVobRZ0t7l1hkVlFqj4IRQjAMzDkexzT473W7n7HjV/L+2a1dWY22y Hy4IvtWAM9X/
AHa4Y8DauVPzbywHaUVwtvqmvX/iG7sU1WztXeS5gW33CWW2Rd4im8jygy5x G255CjB+AN6A
GoeINbl00X8bQ6bby3KWknnToqWxRJDM5mMbhf3wEPzIQdmV/wBYCCwHdUyW aKBA80iRqWVA
zsACzEKo57kkAepIri9N1XXLk3ckmq2KpaaWtwrOv7iVy9yqSPKVU+XtjRmK qobAZMLw2DqW
rtd21k0+pTeUsnz6hN9mcLtvLDLwyogVohubkgZKneuVwCwXPUjNEs6QGRBM 6s6xlhuZQQCQ
O4BZc/UetPrzS81rUFv/ALRY3qXywQXENtqLlAskLSWPmSl0XZhC8o3BCq+X 8wba2eh0zVdV
bwfql6s1tqd3brK1m9uxnWcrGGUbljjWQ78r8igcbc7g1FgOnM0SzpAZEEzq zrGWG5lBAJA7
gFlz9R60+uIiVNU8RaYNP8WXN2FtL3N5btayMPntf3fEZTHIPTdz1xxVIeMd Qnn0O5F1bW7X
K2KzWUs6J55nKbniiMZd1AkIDCQANG2Qdp3FgPRKK8+g1vWbXRtHnl1Sa4Op 6dHd3E00UQ+y
DzLZZHTaigKqTyMS4YDYpPAbNWbxJqPmTQ2niS2l05LuRF1W4ubeBTtht2WP zRC8ZJMkpxs3
HZ1+UglgPS6K47Tda1CfxLaWt9eo8kkCM1pp5TbEfJDM1xHIomjBc/KQccoG Ck/NJf63qthr
N+HGbGxkW8nOV+WzMaJ6ZPzi5k4y37jbjDrRYDraZDNFcQRzwSJLDIodJEYM rKRkEEdQRXne
kSX58UWcms332G5jzbzyIkKCa4a3sGMLNtIZmIkxt+YhcKcLUen3N7pvh7wr am9e6gvbSym2
XMMTCDbcWiBUwg4xM3LbmBVSCCCSWA9LorkvC9/qUn9h/bdRmvf7U0k3snnR xr5Tr5PCbFX5
T5zZ3ZPyrgjnOL4h8XalY6jqAs7+GP8Ad3Ua2c08bTwmK3lcSiHygwUtEGDM 7Aq4+X5htLAe
j0Vi6VJdwa3faXcX016kNtBcJNOkYkBkaVSvyKq7R5QI4zknk8Y5LTvEmvS2 ks1xqFnlo4mu
44pBLJpxaWNXLKIVEOxGlJWVpCDH3CPksB6Ik0UrypHIjtE2yRVYEo2A2D6H DA/Qj1p9eSTz
rc6lfC11f7bbm9Ezakogd1WN9MLPvVNgVBuJ42/JlgdtdO2t3C6mscOtedKt zaxWlp+6P2+2
dYvMuMBdzY3yndGQg8rpgNksB2lFYvhKe+u/C2m3uo3f2m5u7aKdmEaxhdyK cAD8ye5JxgYU
bVAwooooAKKKKACiiigAooooAKKKKACiiigAooooA+d7/wD5CNz/ANdX/maK L/8A5CNz/wBd
X/maK0IPqXTP9bN/1zi/9BrSrN0z/Wzf9c4v/Qa0qS2BhRRRTA818X6Rdaze SwRafpzY8xYd
QnlIns3YkeZEvln5lwrDDqSQORjNYF74Ju7iPUoE8kib7bJBPLfXBAedZQB5 H+rjx5xBcbiQ
CdoLZX2Q2tuzFmgiJPJJQc0n2S2/594v++BU2Hc851Lw5Fdz2Qtglvaoot7q CPCLLbqQyx7Q
MEBlC4PGySUfxVhXvgm7uI9SgTySJvtskE8t9cEB51lAHkf6uPHnEFxuJAJ2 gtlfX547C1t5
bi4S2hgiQvJJIFVUUDJJJ4AA5zWXoms6VrenQXX2NrCaaVoPsV/EsVwkgBbY yZOGKDeB12EN
0oswuM8PwxW8wggjSKGOHYkaKFVVGAAAOgAroa5vxB4q0Lwxol1qT3enCWOG cwQG5SNrmSLO
6JT3bcNpABIPGM8VoDxFpSG3S5v7S1lubiW2t4prmMNM6SGMhAGO47scDkZA IByA0rCZqUUU
UwCiiigAooooAKKKKACiiigAooooAK57VP8AkK3X/XC3/wDQp66Gue1T/kK3 X/XC3/8AQp6T
2BFGpEmMaBUSEDr/AKpfxPSo6Kgsla4kZGX5AG4O2NRnv2FRUUUAFFFFAEK2 kCX0t4qYuJY0
id8nlULFRjpwXb8/pU1FFABRRRQAUUUUAFFFFABTJolngkhcuFkUqSjlGAIx wwIIPuDkU+ig
ClbaVaWljLaQiZUmz5khnkMrkjGTIW3lsAAHOQAAMYFWoYlggjhQuVjUKC7l 2IAxyxJJPuTk
0+igAooooAKKKKACiiigAooooAZNEs8EkLlwsilSUcowBGOGBBB9wcioLDT7 bTYGitlcBm3u
8kjSO7YAyzsSzHAA5JwAB0Aq1RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQA UUUUAFFFFABR
RRQAUUUUAFFFFABRRRQAUUUUAfO9/wD8hG5/66v/ADNFF/8A8hG5/wCur/zN FaEH1Lpn+tm/
65xf+g1pVm6Z/rZv+ucX/oNaVJbAwooopgFFFFAGP4p0m417w5d6TbXP2f7Z shmkGM+QzqJg
uVYbjHvA46kdOtc//wAIhrNjrUmpWuqf2ntu4r+OLUHSIyT+RLbSZeKEBF8t oSMK2TGRgbt1
dRrmrJoOh3urS209xDZxNNJHBt37F5YjcyjgZPXtxk4FRweItKmv4tMe/tIN WdAzabJcxm4Q
lN+0orHkLzxkY5BI5oA4uTwd4kTRdbghj0p7rXLS5trhXvJFS18ye6lVlYRE ycXWCCExs77u
LEngvWEttbtYXsXj1yK5tbiR5nU2sclzdSK6qEPmNtuuVJQApjcQ2R0F9438 N6fOkU+s2P8A
x9/Y53F1HttZNkjgSkt8mfKZRnndgY64k1nxTpulWWsNFdWl1qGl2Ut5Lp63 KiXaibvmXkqD
leSP4hQBuUVh2XinTZooje3VpYT3F7c2dtDNcqGnaGdofkBwWJKg4GcbgOe5 e+KdNtvEWnaF
FdWk+oXVwYpbZblfNgUQSS72Tk4+RRzj74OexANyiufk8WQRaxc2T6dfC3tr uKylv/3XkrNK
sZRcb/MOTNGuQmAW5IAJGpLq2mwW/wBom1C0jg3yJ5jzKF3RhjIMk4yojckd tjZ6GgC5RXP3
Hjfw3b2tpef2zYy2Nzdmz+2RXUbQxSCJpMO+7C8Jj1yy8c1YHinRFlMNzqlj a3A84+RNdxBy
kTOrvgMflHluT6bTuAIIABsUVny67o8P2HzdVsY/7Qx9i3XCD7TnGPL5+fO5 emfvD1qSPVtN
m1SbS4tQtH1CFN8tosymVF45ZM5A+ZeSO49aALlFFFABRRRQAVz2qf8AIVuv +uFv/wChT10N
c9qn/IVuv+uFv/6FPSewI4AeIPEd3qd/babYWkyWkzRktwQNxAzlxnoelS/b /Gv/AECLL/vs
f/HKPCf/ACH/ABJ/19f+zSV1lcsIuSu2z3cZXp4er7KNGLSS3Tvqk+5yf2/x r/0CLL/vsf8A
xyj7f41/6BFl/wB9j/45XWUVXs3/ADM5vr8f+fMPuf8A8kcn9v8AGv8A0CLL /vsf/HKPt/jX
/oEWX/fY/wDjldZRR7N/zMPr8f8AnzD7n/8AJHJ/b/Gv/QIsv++x/wDHKPt/ jX/oEWX/AH2P
/jldZRR7N/zMPr8f+fMPuf8A8kcn9v8AGv8A0CLL/vsf/HKPt/jX/oEWX/fY /wDjldZRR7N/
zMPr8f8AnzD7n/8AJHJ/b/Gv/QIsv++x/wDHKPt/jX/oEWX/AH2P/jldZRR7 N/zMPr8f+fMP
uf8A8kcn9v8AGv8A0CLL/vsf/HKPt/jX/oEWX/fY/wDjldZRR7N/zMPr8f8A nzD7n/8AJHJ/
b/Gv/QIsv++x/wDHKPt/jX/oEWX/AH2P/jldVJLHDGZJXVEHVmOAPxqv/adh /wA/tt/39X/G
j2b/AJmL+0I/8+Yfc/8A5I537f41/wCgRZf99j/45R9v8a/9Aiy/77H/AMcr ov7TsP8An9tv
+/q/40f2nYf8/tt/39X/ABo9m/5mH9oR/wCfMPuf/wAkc79v8a/9Aiy/77H/ AMco+3+Nf+gR
Zf8AfY/+OV0X9p2H/P7bf9/V/wAaP7TsP+f22/7+r/jR7N/zMP7Qj/z5h9z/ APkjnft/jX/o
EWX/AH2P/jlH2/xr/wBAiy/77H/xyui/tOw/5/bb/v6v+NH9p2H/AD+23/f1 f8aPZv8AmYf2
hH/nzD7n/wDJHO/b/Gv/AECLL/vsf/HKPt/jX/oEWX/fY/8AjldF/adh/wA/ tt/39X/GnxXt
rcSCOG5hkkOSFSQEnAyeB7Uezf8AMw/tCP8Az5h9z/8Akjmvt/jX/oEWX/fY /wDjlTaHrmq3
evXGmanbW8Lww+YRGDkHK453EdGrpq5Ow/5KVqn/AF6r/KOpacWtXudFKrTx FOqnSirRbTSd
73S6t9zrKKKK3PHCiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKK KKACiiigAooo
oAKKKKACiiigD53v/wDkI3P/AF1f+Zoov/8AkI3P/XV/5mitCD6l0z/Wzf8A XOL/ANBrSrN0
z/Wzf9c4v/Qa0qS2BhRRRTAKKKKAMfxXp95q/hLVtMsBAbq9tJLZDPIURd6l SxIVjwCTjHOM
cZyMt/DupXNvqLTG0invdYsNR2JKzqiwi18xdxUEnMD44GcrnGTjoNT1KHSr VLidZGR7iC3A
QAndLKsSnkjjc4J9s9elF5q2m6fcWtve6haW092+y2jmmVGmbIGEBOWOWAwP UetAHH6f4V16
whsnhNokWl3CSafpD3zzRRqIZomH2lohIARMCFZX2+WACA2Ep+JfA+v65c3I 8+CRX+2bLmbU
pwNsttPFGn2UIYk2eail1O4hCx5ciu8l1bTYLf7RNqFpHBvkTzHmULujDGQZ JxlRG5I7bGz0
NV4/EugzaXNqkWt6a+nwvslu1ukMSNxwz5wD8y8E9x60AcXc/D2+luL1nMFx HqH2iKZDqVzb
pFG91czKWSLH2jK3OCjFANhAbDkjYt/D2sW+sabFssW0yy1W71L7R9ocTP56 3HyeV5e0bWuM
Z3nITOBnA0NL8Y6PqmtXmlR6hYi6ilRbaNbtGe6jaCOYSIvUrhyMjI+QnPpY sPFOiahPbWsW
qWIv7iJJVsvtcTzAMgkHyoxz8pzlSQRyCRzQBjz+D531rU9Zjn3XUmoR3ltb SXMv2aVUgijC
yx/dDb0LK4VmUrG3zbdhy9d8G69qOmzaNbjTRZ/aNRuo7qS5cSM11FcgIYxG QArXON285CZx
k7R2lrruj32oz6dZ6rY3F9Bu862huEeSPadrblByMEgHPQ1oUAcnq/h3UpvF ia/Ym0ke3S2M
NvPK0YkZFu0cM4Vto23QYEBslCCBnNZ8HgrUop9Qdp7TFxe21wmHbhY9Tnu2 B+Xr5cqgf7QI
4HJ7yigDze5+Ht9LcXrOYLiPUPtEUyHUrm3SKN7q5mUskWPtGVucFGKAbCA2 HJHSaJo2padr
19NvjtdJleaRbNLprgSzSSbzN86KYT97MasyEuSMEEt0lFABRRRQAUUUUAFc 9qn/ACFbr/rh
b/8AoU9dDXPap/yFbr/rhb/+hT0nsCOF8J/8h/xJ/wBfX/s0lbkWtWU+oGyh +0ySBmQyJaym
EMudw80LsyCCD83BBHXisPwn/wAh/wASf9fX/s0lRajpep3VxexaLaX2lSSr cK9xNeAW8m6N
wrRxpI2xjKY5NwRW4Yk5JDYUfg+/8z081/3p+kf/AElHY0V59p/g9jPZo2nX kWni9WSe3uWt
oxgQTqW8u2AQqxkjU5JLjhhtXnUvvDmozTajBaXHk26x3Fxpzbtvl3c6MpO4 HeNhMrZ5B+0Y
AHlitDzjraha7gS+is2fFxLG8qJg8qhUMc9OC6/n9a4TT/B7GezRtOvItPF6 sk9vctbRjAgn
Ut5dsAhVjJGpySXHDDavOv4nk0uy8RaHqGrfYWhiWaONbmWFGjkZ4WEy+Yw4 QIclcsNwwDk4
AOnhlWeCOZA4WRQwDoUYAjPKkAg+xGRT6870PwZNFDYDUtItmbz4Eu/MEb77 dNPRNjcnconR
Tt5+ZQ2OAaNN8Max/aWnXeppfS3qLaN9pEtuVhCRRiVHlZWmyWWUlYzsbfyR ucgA9EqFruBL
6KzZ8XEsbyomDyqFQxz04Lr+f1rhIPDepJBa+XpfkXFpHC1/IHjB1SeOeCTz AQ2XYiKbDS7T
mUZxliLVto91c+KTrd/oDtC125ihnMDyQFo7RVn++VAUwSfdYvyMA5OADrdS v4tL0u71CdXa
G1ged1QAsVVSxxnHOBRqV/Fpel3eoTq7Q2sDzuqAFiqqWOM45wK5Xxnolxqf 9o/8SX+1vtGn
fZ7L/VH7JP8AvNz/ALxl27t8XKZP7vnouczUPCWpzTa26QXkt5cR3oWfzLZI pkkSQRRbtvnP
gNGNrkICmQcIgIB6PRXC3Ph28v8AxZ513YTeRcyTQ3s0It44JbVoZERSy4uG b/VZDHaGBI4V
SLukWk9/oyareJ/alxeSWhjfIg3QRSKY5cDgcl7jbjPz+Wc4FAGj4x/5FHUv +uX9RW26eAo5
9bhfS9KEmiRLNqA/s4fuUZDID9z5vlBPy5/OsTxj/wAijqX/AFy/qKf4r8La zdWXiq80yz86
/u5ZYbeLzUX7TbT2dvBIMscJtkjWTnk+TtGA+aqOwmdh/wAIn4b/AOhf0r/w Cj/wo/4RPw3/
ANC/pX/gFH/hXD654T1a8tdVgtdH/wCJnL/aLS6pviH26CaKdYLffu8w7TJA NrgIvk8H5Uzo
at4HSTWJpbXSIJYVi02GGWQq7lBdyteAs53HfFId+T+83sDuJIqhHUf8In4b /wChf0r/AMAo
/wDCqemaL4V1W1e4g8O6aqJcT25D2UQO6KVomPAPG5CR7Y6dK4vX/CviC40U 2sOmTvJafbf7
INkLMvas08pi3PPzFGIxbbPJIZdrA4Kpj0Dw1Y3Gn6VPDdR+XI2oXswG4HKS XUsiHj1VlPtn
nmgA/wCET8N/9C/pX/gFH/hVW/8ACvh1IlI0DSxgseLRBnCMew9q6Kqeo/6g f8D/APQGpMDz
ma/+H9vPJBOnhaKaNijxvJErKwOCCC3BBqzZWtnaePI47KxtbSM6VOxW3iCb juXk9z0pl14O
0O88UW/iKexRtRgXAb+FmGNrsO7KBgHtn2XE8P8AyUCL/sET/wDoS1KKNauT sP8AkpWqf9eq
/wAo66yuTsP+Slap/wBeq/yjrGpvH1PRwHw1v8D/ADidZRRRWp54UUUUAFFF FABRRRQAUUUU
AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAfO9/wD8hG5/ 66v/ADNFF/8A
8hG5/wCur/zNFaEH1Lpn+tm/65xf+g1pVm6Z/rZv+ucX/oNaVJbAwooopgFF Y+oa8bTUTYWm
lX2p3SRLNMloYV8pHLBCTLIgO4o/3c42nOMjMc/ii2guJf8ARLt9Pgcx3Opo E+zwODhgxLby
FPDMqlUO7cw2PtAJPE+n3mp6KILAQNdR3drcos8hjRvKnjlKlgrEZCEZwetc 34s8OeJfE2lz
wstoj3NlJbfZk1i4hitpDvHmZjjH2gMrJlJFAXYQM72NdhpmpQ6ravcQLIqJ cT25DgA7opWi
Y8E8bkJHtjp0rLsvFkF3dMkmnX1rafa5LKO+n8ryZJklaLaNrlly6kKXVQTg Z3MoIBzeu+Dd
e1HTZtGtxpos/tGo3Ud1JcuJGa6iuQEMYjIAVrnG7echM4ydo2NX8O6lN4sT X7E2kj26Wxht
55WjEjIt2jhnCttG26DAgNkoQQM5rch13R7iW5ih1WxkktZVguES4QmKRm2K jAH5WLfKAeSe
OtF9ruj6ZFJLf6rY2kccogd57hIwshUOEJJ4YqQ2OuDnpQBhv4d1K5t9RaY2 kU97rFhqOxJW
dUWEWvmLuKgk5gfHAzlc4ycZ+i+CtS03wqNLmntGnF7pdxuR2K7bZLNZByuc k2z447rnGTjo
D4p021l1QapdWmnQWN6tms11cqiys0Ec3BbABxIRjn7pP0uf27o/9sf2R/at j/af/Pl9oTzv
u7vuZ3fd56dOaAOP8J2upw+IdNsJbLFjoGlTaYLzbMnntvtwrbZIkHIgY/u2 kUd25Ut6BWXZ
+JdB1F4Esdb026ed3SFYLpHMjIoZwuDyVUgkDoCCaG8S6CqXrtremhLBwl4x ukxbsWKgSc/I
SwIwccjFAGpRWGfF+g/bdLt11O0dNUSU2dwk6GKZo3RCitu+Zy0gAAz91vSt ygAooooAKKKK
ACiiigArntU/5Ct1/wBcLf8A9Cnroa57VP8AkK3X/XC3/wDQp6T2BHC+E/8A kP8AiT/r6/8A
ZpK6yuT8J/8AIf8AEn/X1/7NJXWVz0vg+/8AM9PNf96fpH/0lBRRRWp54UUU UAFFFFABRRRQ
AUUUUAFFFFAGH4wvIbHwxdTXFoLuIvFG0BuRbh98ipzIQQo+bk+ncdRzz/HR 13Y0+2fbnG3U
H+bG/GM2vfauM/8APRc4+bbs+O38vwnK+/Ztu7Q7t23b/pMXOdyY+u5fqOte a/Yrr+1f7a+z
Tf2V/wAI/wCT9u8s+R5n9m+Vt8z7u7zPkxnO75evFdeGpQqJ83QxqycbWO0T 423ErukGlQzs
iu+2O+kJKoHYn/j06YQHJxgOucYbax/jo67safbPtzjbqD/NjfjGbXvtXGf+ ei5x823mxp+m
R6x4l+xabDY/2VLfWMfkySt5sbWl5y/mO3zDyVxt2j5myDxg8SabpFje6pId JhuZbaK5vTJc
XE7NM39ovbBXPmDKhCDkYYsoJYgkHo+rUr21/Az9pK3Q6R/jo67safbPtzjb qD/NjfjGbXvt
XGf+ei5x820f46Ou7Gn2z7c426g/zY34xm177Vxn/noucfNt5/XtLh0nw5qO k2Vm+omFshJn
kkeGKK41CMzgIw2hRszxsy+SMtUepeGfD8N5FBbadeYSWVbSSWMxR6kFhkaM KxmYzb3SIBol
jBEnYumBYej5/gHtJ+R083xtuIEV30qHbIrPE326QCVQZFyubQZBMeM+rDOM NtWL4gyeOruP
Qk0q1nZ33Kn9tSW4bG8ZyLdSw4B28nDqcfK23zXxpFNAnh+O40v+y5Rpp3We 2RfL/wBJn7SE
tz15Pf0xWn8H32/EK1G/bujYY3Y3cg4xuGemcYbpnHG5SeEpqm5psI1ZOSTP Rv8AhE7j/oXN
P/8ACqn/APjNV3nPgzU9Pmk8PWqSahOtgrxa7LclBIyqW2tCBgZU9QT+dL4n 8ZajoutWllp/
hnVNTgDBryeC1kKqhHAjOMM3IJ5xxtzkkrQ+I92Bb+HLyIOB/aEMqh0KN99C MqQCD7EAivOu
dB6BXJ2H/JStU/69V/lHXR2E7XNnHK3VhmucsP8AkpWqf9eq/wAo6wqbx9T0 sB8Nb/A/zidZ
RRRWp54UUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAU
UUUAfO9//wAhG5/66v8AzNFF/wD8hG5/66v/ADNFaEH1Lpn+tm/65xf+g1pV m6Z/rZv+ucX/
AKDWlSWwMKKKKYHL+LNDvNe228GmaU+ImWDVLiYi5sJG4MkKiI/MuFYESISV HIwDWfrenX+n
6PfaOLfz9A1KW4+03UCyS3dslwzvKBAiHzPmdlVwfl8xSyMI2LbmteIpNGv7 K0XRNSvjev5c
Mlq0AUybHcofMlUghY2bOMdBnPFaEerabNqk2lxahaPqEKb5bRZlMqLxyyZy B8y8kdx60AZf
hyy1jS3u7O8trH7C13d3MNxDdO0jebcPKqtGYwFwHIJDnke/GfZeHtYaNtLv ksY9MXVZNSWe
C4d5pf8AS2uY0KGNVT5iu47n4UgD5gy7H/CWeG/7O/tH/hINK+w+b5H2n7bH 5fmY3bN2cbsc
464rQtb+zvvP+x3cFx5ErQTeTIH8uRfvI2OjDIyDyKAOH0P4eta2f2G/OI7f TzYQXkepXE8x
5jImjST93bMDEjhUD4YLhgE+aS68Gag6abf5juNURLhr5Y9TuLFZJZ2jZmWa JS5RPKWNEYfc
CZPyDPeUUAcHpng/VfDmoi/0xNNuTGht4rZ5pLdPKNvZx7t22VgQ1ocKd2Q4 JfIwaeg+FtYt
EutA8qD+zLbUNPk/tCV3SSX7Nb2Z+SHYVKs0G3d5nBLcHbg+kUUAcHZeCtSt tOsrd57QvBZa
JbsQ7YLWdw0spHy9CpwvqeuOtU9N+Ht9Z21jbkwbtO+yRRXEmpXNwZo4rmCV yI3+S3ytuPkU
MMlRuUL83pFFAHJxeHdSs/Gdxr0BtJknuJFMLyshWGSK0RnyFOXVrU4TgEOP mXGK6yiigAoo
ooAKKKKACiiigArntU/5Ct1/1wt//Qp66Gue1T/kK3X/AFwt/wD0Kek9gRwv hP8A5D/iT/r6
/wDZpK6yuT8J/wDIf8Sf9fX/ALNJXWVz0vg+/wDM9PNf96fpH/0lBRRRWp54 UUUUAFFFFABR
RRQAUUUUAFFFFAGP4lhS50y2gk37JdTsEbY5RsG7iBwwIIPuDkVctvBvgC+0 y61F9Ctbe1hl
uYppJmMYTypJY5GyGwq53kHjACdNq7a+vf8AHrY/9hXT/wD0rhq+mga8dMu9 LeHTVgTU31K1
nW7ctKwvftSRunlAICPlLBnx1Ct0q4SaWhEkmULjQPhTFZw3lx/YEVreeZ5E zXqokuCwfY2/
BwZCOOny9Nq4sXvhH4aWmox6de2uj219df6q2kuRHJJvLqNi7geS7AY7hcfc XF/SPDupQ+LH
1++NpG9wlyZreCVpBGzraIgVyq7httSxJC4LgAHGa5e30PWdBt9M8Mx2kd6b i40u7uLiMThY
fs4tkkAbyjERi1LfNIjHdgKTt3Xzy7isjZTwj8NLuW7iitdHkkglEFwkVyMw yOzoqMA3yMWd
lA4OQoHKLi5F8O/A17brcQaLYywTpvSSFiVdWDEFSDjGJCQR/s4+6uMK1+Gt wunW2n3UVpNF
aJbWwe4v7m6FzClxBJJ+6k/dwBlg/wBWocElRuUL83plHPLuFkco/wAM/Bj7 s+H7Ubs527h1
35xg8ffbGOmFx9xcEng7SNDjk1Dw9o9pBqYZfKJkeNGJcnDYz8vznjGOF6bV 29XUNz/ql/66
J/6EKTlJrVgkjgPJ8W/88tB/8DG/wrifiPHq6WmkHVF05R9vi8sWkzOT865z kYA6d/8A63pl
effFX/j10X/r/j/9DSs1uWzstH/5BcH+6KwrD/kpWqf9eq/yjrd0f/kFwf7o rCsP+Slap/16
r/KOsam8fU9HL/hrf4H+cTrKKKK1PPCiiigAooooAKKKKACiiigAooooAKKK KACiiigAoooo
AKKKKACiiigAooooAKKKKACiiigD53v/APkI3P8A11f+Zoov/wDkI3P/AF1f +ZorQg+pdM/1
s3/XOL/0GtKs3TP9bN/1zi/9BrSpLYGFFFFMDL1XTZr7UdDuImjCWF61xKGJ yVNvNFheOu6R
TzjgH6Hl4fBOoQapcSwXEcJFxeXdpfte3Exiln83BWzJEKlPOI3ZbcFPyguS vSal4ks9L/tf
z452/srT11CfYoO6M+bgLkjLfuW4OByOeuI9Z8U6bpVlrDRXVpdahpdlLeS6 etyol2om75l5
Kg5Xkj+IUAc3pPg3VoPFVvq9ykEEMUsLGI6tcX7kJDeISHmQEc3KYXp8rHqc HY8J+G7zQfs/
2qSB/L0TT9PPlMT+8g87eeQPlPmLg9eDkCpNd8a6VoPh+71O5ubSOWJLr7Pa zXcaNcvAWUoh
BOSWUDAyRuAIByKual4o0fTItU8y+gmutMtHvLmyhlRp1jVdxOzORkEYzgfM OeaANiisdPFO
iPBNdDVLH7BFFHK179riMOHd4x8wbj5kIyQATwCSGAkfxLoMdxaW763pqz3q I9rG10gadXOE
KDOWDHgEZz2oA1KKKKACiiigAooooAKKKKACiiigAooooAK57VP+Qrdf9cLf /wBCnroa57VP
+Qrdf9cLf/0Kek9gRwvhP/kP+JP+vr/2aSusrk/Cf/If8Sf9fX/s0ldZXPS+ D7/zPTzX/en6
R/8ASUFFFFannhRRRQAUUUUAFFFFABRRRQAUUUUAZevf8etj/wBhXT//AErh rbtPENxB4YuN
QuV+1XH9q3FjCpIQEm+e3hDEDhRlAWwTgE4Y8HE17/j1sf8AsK6f/wClcNbc Gj+FWXUZIbzz
IZbt4blBqsrxRXTyhyFTzNsU3mspG0KwYjGCaqOxLK6+LNYuNYGi22i2LanF 5/2pZdRdIU8t
bdxscQlnyt1H1RcEMOeCY4vHc1/bwajpulRyaW1xZW80lzdGKdGuRAylY1Rl YBbiPOXHIYdg
T0Fh4e0zTbiO5toJPtEaSJ58s8ksjCQxlt7uxLn91GAWJICADAGKw7jwDatq Ommzn+xaZZfZ
mNpC04aVoCpjLHzfLbiOJSXjZtqY3DClaEdhRRVewvrfU9Otr+zk8y1uokmh faRuRgCpweRk
EdaALFQ3P+qX/ron/oQqaq97IkVsZJHVER0ZmY4AAYZJNAHMV598Vf8Aj10X /r/j/wDQ0rt/
7TsP+f22/wC/q/41wfxPuYLi10byJ45dt/FnY4bHzr6VC3KZ2+j/APILg/3R WFYf8lK1T/r1
X+Udbuj/APILg/3RWFYf8lK1T/r1X+UdY1N4+p6OX/DW/wAD/OJ1lFFFannh RRRQAUUUUAFF
FFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQB873 /wDyEbn/AK6v
/M0UX/8AyEbn/rq/8zRWhB9S6Z/rZv8ArnF/6DWlWbpn+tm/65xf+g1pUlsD CiiimBz+v+G/
7a1bR7wSbFtJf3w3YJjEkc428H5vNt4BzxsMnfaRy/iXwPr+uXNyPPgkV/tm y5m1KcDbLbTx
Rp9lCGJNnmopdTuIQseXIrsNS8SWel/2v58c7f2Vp66hPsUHdGfNwFyRlv3L cHA5HPXElz4h
02xvb23vrmO0Szt4Lia4uHWOILK8iINxPXdGRzjquM54AOPvPBuvRad4gt7A abO+t291auZ7
l4hbq9xdSo4xG287brBX5cFOC2cg17wNrOvajIlxdx/Z5Hu83jX87FY5beaJ FWzx5SlPNUbg
wLBCTguRXSDxjo48QrpMuoWMXn2ltc2UrXaD7X5zyKFjH8X+rU5BOd4/HU1L VtN0a3W41TUL
SxgZwiyXUyxKWwTgFiBnAJx7GgDl7nQNeuvEEPiJodNS8t0tylmLtzG7ILyN gZfKBA23SsDs
PKlcAfNVdPBWpDSfE8DT2nn6zpkkCAO22KaSa8lYE7clFN0qhsZO0naOldZ/ buj/ANsf2R/a
tj/af/Pl9oTzvu7vuZ3fd56dOapw+KdNu/FSaDZXVpdzrbzy3Pk3Ku1u0TxJ sdRkgkyHrjGw
8HsAblFc3f8AjXTdOsri4lgu2e3e6E1uiKZY1t0Z2dl3cIyhCpPXz4em8VTv /iPo+n2tjPJb
Xz/arSe6eONEL2vlRPI0cw3fJIfKlUL/AHonHG04AOwooooAKKKKACiiigAo oooAKKKKACue
1T/kK3X/AFwt/wD0KeuhrntU/wCQrdf9cLf/ANCnpPYEcL4T/wCQ/wCJP+vr /wBmkrrK5Pwn
/wAh/wASf9fX/s0ldZXPS+D7/wAz081/3p+kf/SUFFFFannhRRRQAUUUUAFF FFABRRRQAUUU
UAZevf8AHrY/9hXT/wD0rhrOk0nUtOihe30+7eLVPEebqGOFiY2j1QzR3BAH CNCGDSHOQsAH
AJrR17/j1sf+wrp//pXDVvVPHF5BFr/2K30oSaXaXU5gub8/ax5SttdrYJ/q 2YKQfMGUdW4J
xVR2JZhpH4hms7GK1m8QQXzparrcrCY7Lo3VtuaHzQY9gX7UT5QMW3G4Fdta jaNfN4jkhMuu
fYZNVSzYi/uQos109XBDB/l/0hADICGLFlLHcwPSDxdo5t3lMl2jo6p9mksZ 0uGLAkbYCgkY
EK5yqkYRz/A2Kep+PNGstOvZraf7VeW+ny362gR0cogkzuyv7vDROjbh8jYV gGZQaEcmL7xR
PceHbu5XUrfUNmnJNEtldutwjmP7RI+xhbwkb5lKyRlh5e4EZTb3HguCa18C +Hre4ikhni0y
2SSORSrIwiUEEHkEHjFaljexahZx3UKTpG+cCeB4XGCRyjgMOncc9elWKACq eqW1vd6bLBdw
RzwvgNFIgdW5GOD15x/iOtXKhuf9Uv8A10T/ANCFAHMnwvoXP/FPWX/gAvv/ ALI/p1HTjZyP
xG07QdK8Mr5emWdreT3lstuyWgRyROhbBCjHyhsnpyB3AWHxP4u1zQNatLG0 8KvqUN6wjtp4
rvbufGSrDYdhABOScbQTnhsZfxPMradoJnREmN7EXVHLKrbkyASBkZ74H0FS hnbaP/yC4P8A
dFYVh/yUrVP+vVf5R1u6P/yC4P8AdFYVh/yUrVP+vVf5R1hU3j6npZf8Nb/A /wA4nWUUUVqe
eFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQA UUUUAFFFFAHz
vf8A/IRuf+ur/wAzRRf/APIRuf8Arq/8zRWhB9S6Z/rZv+ucX/oNaVZumf62 b/rnF/6DWlSW
wMKKKKYHP6/4b/trVtHvBJsW0l/fDdgmMSRzjbwfm823gHPGwyd9pHPp8P57 TQLW1t5vNntN
QFykYvZbYSxpbm0iXzol3xt5IjZiAQXDAYVuOo1LxJZ6X/a/nxzt/ZWnrqE+ xQd0Z83AXJGW
/ctwcDkc9cSXPiHTbG9vbe+uY7RLO3guJri4dY4gsryIg3E9d0ZHOOq4zngA 48+CtZhtdT0+
1h01LTV9M+xXMjXs7vbM0ty7uu9WM5/0nOWdNxU8IDgdJ4n0vU9S+ymxfzIY 9/m2v9ozWO9j
ja/nQgv8oDDZja2/J5QUDxjo48QrpMuoWMXn2ltc2UrXaD7X5zyKFjH8X+rU 5BOd4/G5qutD
Tbi3tIbC71C8uEeRLa1MYby0Kh3JkdFwC6DGc/MMAgEgA5fRfBWpab4VGlzT 2jTi90u43I7F
dtslmsg5XOSbZ8cd1zjJxc8O+HtY0zUdGS8Sx+w6PpUmmwzQ3DtJcZMG12Qx gR8QEkBmwWxk
4zXQJrVh9stbC4uoLXU7mISpp808fn4wSflDHONrZK5Hynk4qS11bTb51S01 C0uHdN6rDMrk
rtRsjB6bZIzn0dT/ABDIBy+t+F9a1Oy1doru0F5qlvc2M6uSIhbbJhbBcLuD qzqWJyP3s3UC
MLH4q8Bf2pZXa6SYIri7luJZDOdqr5lnPAFXapIXzJjIR/eklbq2D0DeKdEi tZLu51SxtrNZ
UiS5mu4hHKWiWVdrbu6tkA4JAyBtIJuR6tps2qTaXFqFo+oQpvltFmUyovHL JnIHzLyR3HrQ
AabJqUtuzapaWltPvIVLW5adSuByWaNCDnPGOw554uVT03VtN1m3a40vULS+ gVyjSWsyyqGw
DglSRnBBx7irlABRRRQAUUUUAFFFFABRRRQAVz2qf8hW6/64W/8A6FPXQ1z2 qf8AIVuv+uFv
/wChT0nsCOF8J/8AIf8AEn/X1/7NJXWVyfhP/kP+JP8Ar6/9mkrrK56Xwff+ Z6ea/wC9P0j/
AOkoKKKK1PPCiiigAooooAKKKKACiiigAooooAyfETFNOt5hFNIsOoWUzrDE 0j7EuYmYhVBJ
woJ4B6VneJda07Xre5t9X1q5gsylwLQReGb6N42khkhBdmyHASVuAEyQDkDI PT1FPbRXK7ZU
DD0NNOwmjntU8VeF7zxB/blprlzBeRJALcS6HdyRq0YuVJcBVLArdOAAVwVB yRkVXtda8Fx2
us291reoSprFk1rcmLR7pCrPLcyyOmY2wC10wVTnaFGS3Wt/+x7H/n3T8qP7 Hsf+fdPyp8wr
Etj8T/DsdnGt/qk090M75INEvIkbk4wpViOMfxH146VY/wCFpeEf+f29/wDB Xdf/ABqqX9j2
P/Pun5Uf2PY/8+6flRzBYu/8LS8I/wDP7e/+Cu6/+NVT1T4reGYtPkktW1C7 nQqyQJptwhch
hxlowB/nr0pP7Hsf+fdPyo/sex/590/KjmCxxv8AwtWD/oA6p/34f/4muc8V +Kx4pGmQQaVq
EDQ3kbkyQPjG9c87RjGK9V/sex/590/Kl/sex/590/KldDDR/wDkFwf7orBs P+Slap/16r/K
OuqSNY0CqMAdBXK2H/JStU/69V/lHWNTePqejgPhrf4H+cTrKKKK1PPCiiig AooooAKKKKAC
iiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigD53v/wDk I3P/AF1f+Zoo
v/8AkI3P/XV/5mitCD6l0z/Wzf8AXOL/ANBrSrN0z/Wzf9c4v/Qa0qS2BhRR RTA5/X/Df9ta
to94JNi2kv74bsExiSOcbeD83m28A542GTvtI59Ph/PaaBa2tvN5s9pqAuUj F7LbCWNLc2kS
+dEu+NvJEbMQCC4YDCtx1GqeJLPSZbuK5jnMlvaLdRoqjN1linlwgkb5N2xd vrLGOrCq9l4s
gu7pkk06+tbT7XJZR30/leTJMkrRbRtcsuXUhS6qCcDO5lBAObPgrWYbXU9P tYdNS01fTPsV
zI17O72zNLcu7rvVjOf9JzlnTcVPCA4HUeJdPm1O3gt10HRtYgDl3j1SYoqM BhSo8mQE4LDP
GPfPFyLXdHm+3eVqtjJ/Z+ftu24Q/ZsZz5nPyY2t1x90+lZ8PjHR5bq9b+0L EaZbWkFz/aP2
tPJbzZZo9u77ow0OM55LY4xyAc/Z+Ar611OFri5/tGMy2lxPeT6hcxkyQRwp k2yt5cjMYA29
3yC/IYIA1yHwVNbeCtC0m0njsdQ0+3S3kuLNzFlXUJclWC5yctIvAzKkbN0r ch8UaPPrkekR
30BuprSK8tv3qYuY38zBi5y+BEScDABU5542KAOLi8L6lo/iK41fR7fTZELy RQWTzNbokLwW
ifeWNsFWtMBQuCHByMYNM+ApmvL1Li2gvLR5b24TztVulEpuBLmPyB+7h4nZ TIu84BO0M+V9
AooAx/Ddlqljp0keq3XnSNKWhj83zvs8WAFj80ojS9CdzLu+bBLEbjsUUUAF FFFABRRRQAUU
UUAFFFFABXPap/yFbr/rhb/+hT10Nc9qn/IVuv8Arhb/APoU9J7Aji7rwNpl 3dzXMk92Hmka
RgrrgEnJx8tQ/wDCvtJ/5+L3/vtP/ia6yiuf2UOx6SzXGRVlUZyf/CvtJ/5+ L3/vtP8A4mj/
AIV9pP8Az8Xv/faf/E11lFHsYdiv7Wxv/PxnJ/8ACvtJ/wCfi9/77T/4mj/h X2k/8/F7/wB9
p/8AE11lFHsYdg/tbG/8/Gcn/wAK+0n/AJ+L3/vtP/iaP+FfaT/z8Xv/AH2n /wATXWUUexh2
D+1sb/z8Zyf/AAr7Sf8An4vf++0/+Jo/4V9pP/Pxe/8Afaf/ABNdZRR7GHYP 7Wxv/PxnJ/8A
CvtJ/wCfi9/77T/4mj/hX2k/8/F7/wB9p/8AE11lFHsYdg/tbG/8/Gcn/wAK +0n/AJ+L3/vt
P/iaP+FfaT/z8Xv/AH2n/wATXWUUexh2D+1sb/z8Zyf/AAr7Sf8An4vf++0/ +Jo/4V9pP/Px
e/8Afaf/ABNdZRR7GHYP7Wxv/PxnJ/8ACvtJ/wCfi9/77T/4mj/hX2k/8/F7 /wB9p/8AE11l
FHsYdg/tbG/8/Gcn/wAK+0n/AJ+L3/vtP/iaP+FfaT/z8Xv/AH2n/wATXWUU exh2D+1sb/z8
Zyf/AAr7Sf8An4vf++0/+Jo/4V9pP/Pxe/8Afaf/ABNdZRR7GHYP7Wxv/Pxn J/8ACvtJ/wCf
i9/77T/4mj/hX2k/8/F7/wB9p/8AE11lFHsYdg/tbG/8/Gcn/wAK+0n/AJ+L 3/vtP/ia0dH8
LWOiXb3NtLcO7RmMiRlIwSD2A9K26KapQTukZ1MyxdSDhOo2mFFFFaHEFFFF ABRRRQAUUUUA
FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAHzvf/8A IRuf+ur/AMzR
Rf8A/IRuf+ur/wAzRWhB9S6Z/rZv+ucX/oNaVZumf62b/rnF/wCg1pUlsDCi iimBz+uaTqmo
3n2m1uYImsYhNpit0+1kSKxm+U5j2EJ8vOJJD94Iy59l4e1ho20u+Sxj0xdV k1JZ4Lh3ml/0
trmNChjVU+YruO5+FIA+YMvYUUAefp4L1h7HSraV7FP7CtIrayZZnb7Z5c1t KGkGweTn7Iow
PMx5hPO3DSav4T1nWtUTWLiO0huI0tiLS31KeIM0f2tCPtCIroNtyrZCnJVl Iwd1d5RQByfh
3w3e6BqSzxx2hgurcR3SfaZWaBllnmBVpAzTFmuCGZin3dwHzbF6yiigAooo oAKKKKACiiig
AooooAKKKKACiiigArntU/5Ct1/1wt//AEKeuhrntU/5Ct1/1wt//Qp6T2BF GiiioLCiiigA
ooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACi iigAooooAKKK
KACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoooo A+d7/wD5CNz/
ANdX/maKL/8A5CNz/wBdX/maK0IPqXTP9bN/1zi/9BrSrN0z/Wzf9c4v/Qa0 qS2BhRRRTAKK
KKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK57VP+Qrdf9cLf /wBCnroa57VP
+Qrdf9cLf/0Kek9gRRoooqCwooooAKKKKACiiigAooooAKKKKACiiigAoooo AKKKKACiiigA
KACiiigAooooAKKKKAPne/8A+Qjc/wDXV/5mii//AOQjc/8AXV/5mitCD6l0 z/Wzf9c4v/Qa
0qzdM/1s3/XOL/0GtKktgYUUUUwCiiigAooooAKKKKACiiigAooooAKKKKAC iiigAooooAKK
KKACue1T/kK3X/XC3/8AQp66Gue1T/kK3X/XC3/9CnpPYEUaKKKgsKKKKACi iigAooooAKKK
KACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoooo AKKKKACiiigA
ooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigD53v/APkI3P8A 11f+Zoov/wDk
I3P/AF1f+ZorQg+pdM/1s3/XOL/0GtKs3TP9bN/1zi/9BrSpLYGFFFFMAooo oAKKKKACiiig
AooooAKKKKACiiigAooooAKKKKACiiigArntU/5Ct1/1wt//AEKeuhrntU/5 Ct1/1wt//Qp6
T2BFGiiioLCiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACi iigAooooAKKK
ooooA+d7/wD5CNz/ANdX/maKL/8A5CNz/wBdX/maK0IPqXTP9bN/1zi/9BrS rN0z/Wzf9c4v
/Qa0qS2BhRRRTAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooo oAK57VP+Qrdf
9cLf/wBCnroa57VP+Qrdf9cLf/0Kek9gRRoooqCwooooAKKKKACiiigAoooo AKKKKACiiigA
KACiiigAooooAKKKKACiiigAooooAKKKKAPne/8A+Qjc/wDXV/5mii//AOQj c/8AXV/5mitC
D6l0z/Wzf9c4v/Qa0qzdM/1s3/XOL/0GtKktgYUUUUwCiiigAooooAKKKKAC iiigAooooAKK
KKACiiigAooooAKKKKACue1T/kK3X/XC3/8AQp66Gue1T/kK3X/XC3/9CnpP YEUaKKKgsKKK
ooqwrmK0RlVMs7AlkDdAvqPegCvRU32mT+7F/wB+l/wo+0yf3Yv+/S/4UAQ0 VN9pk/uxf9+l
/wAKPtMn92L/AL9L/hQBDRU32mT+7F/36X/Cj7TJ/di/79L/AIUAQ0VN9pk/ uxf9+l/wqC01
WG/tUurOe0ubd87JYVjdGwcHBAweQR+FAhaKfNfi3gknne3ihjUu8jxoqqoG SSSOABT/ALTJ
/di/79L/AIUAQ0Vm+KtRubbwtqMsDpFKISFdI1DLnjIOODz1FbNudqzNhSVT I3KDj5gO9AEF
FTfaZP7sX/fpf8KPtMn92L/v0v8AhQMhoqb7TJ/di/79L/hR9pk/uxf9+l/w oAhoqb7TJ/di
/wC/S/4UyG/FxBHPA9vLDIodJEjRlZSMgggcgigQyipvtMn92L/v0v8AhR9p k/uxf9+l/wAK
BkNFNvr2aHT7mWMRB0iZlPkpwQDjtVHQpHm8PaZLK7PI9pEzOxyWJQZJPc0C PB7/AP5CNz/1
1f8AmaKL/wD5CNz/ANdX/maK0JPqXTP9bN/1zi/9BrSrN0z/AFs3/XOL/wBB rSpLYGFFFFMA
ooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigArntU/wCQrdf9 cLf/ANCnroa5
7VP+Qrdf9cLf/wBCnpPYEUaKKKgsKKKKACiiigAooooAKKKKACiiigAooooA KKKKACiiigAo
oooAKKKKACiiigAooooAKKKKACiiigAqZv8Ajzi/66P/ACWoaqalr2laVDBD fX8MErM7hGb5
tvyjOPTg/kfSgRxOh2v2fWor57Czs4X1a/DalE2ZbkmeVFgm+UbVLMCpLMCY kHDMoqHT/Eev
T2F1PPrGkQym2WSdJ7sD7DIXQFGIgAgbDSALKZDuVfvBXz1f/CY+Hv8AoKwf r/hR/wAJj4e/
6CsH6/4UwOXt9Tulu7rVbe8vmupNH3WVteJBu1GSNro4xGv7wAFGHlEZV1JJ 3CrS6vf3Gq2m
n6V4i+22U9zGh1ERwynJhuWkiBRQm5RFEw4JBcFtykLW9/wmPh7/AKCsH6/4 Uf8ACY+Hv+gr
B+v+FAGPpes6vc+LpLae9sxF9pniew87dLHEhcRyeUItybtsZ3vIVIfgZdAK V9/Zn9r+KfI+
x/8ACU/aV/s3bt+1b/ssOzb/ABbN2d2fk2793y7q6X/hMfD3/QVg/X/Csy71 Lwle3T3Eut3S
u+MiHUrmJOBjhUcKOnYUAYGuazq9zb+Irae9sxF9mv4nsPO3SxxJHII5PKEW 5N22M73kKkPw
MugGp4u1y/8ADlqiQ6tie0tnuTJqE8MIvTkkRqohPmMNuCqGM4dPmy2Rtw+L PDkEEcKatGVj
UKC7s7EAY5Y5JPuTk0//AITHw9/0FYP1/wAKAOU8UeIpG8OXumS38P8AaDya nFcWpKCUW6w3
TREp1C4WEhscjByd3Mwv5dJ0rUAuvQ2so1a4Nxb3FxBDJbxtNO6iLemN8g2s BLkMucFR
Re: How to start jboss4.2.2GA in eclipse [message #207452 is a reply to message #207447] |
Fri, 25 January 2008 09:19 |
Hi Kiril,
well, at least I was consistently wrong ;-). That's better than being right
once, and being wrong the next time.
Wolfgang
kiril mitov schrieb:
> Hi Wolfgang,
> no offense but actually "Hello" is asking the question :)
> Best Regards,
> Kiril
FUDForum. Page generated in 0.03437 seconds
