Error obtaining the Transaction Manager [message #1254997] |
Mon, 24 February 2014 02:10 |
David Libke Messages: 1 Registered: February 2014 Location: Atlanta GA |
Junior Member |
Using Eclipse 4.3.1, EclipseLink 2.5.0, Glassfish 4.0, and PostgreSQL 9.3.2. The error occurs from JPA Tools->Generate tables from Entities...
persistence.xml:
<persistence version="2.1" ...
persistence/persistence_2_1.xsd">
<persistence-unit name="libkedesign" transaction-type="JTA">
<provider>org.eclipse.persistence.jpa.PersistenceProvider</provider>
<jta-data-source>jdbc/libkedesignDS</jta-data-source>
<properties>
<property name="javax.persistence.schema-generation.database.action"
value="create" />
<property name="javax.persistence.schema-generation.scripts.action"
value="drop-and-create" />
<property name="javax.persistence.schema-generation.scripts.drop-target"
value="/src/main/resouece/ld-db-drop.ddl" />
<property name="javax.persistence.schema-generation.scripts.create-target"
value="/src/main/resouece/ld-db-create.ddl" />
<property name="eclipselink.deploy-on-startup" value="true" />
<property name="eclipselink.target-server" value="Glassfish" />
<property name="eclipselink.logging.level" value="FINEST" />
<property name="eclipselink.ddl-generation" value="drop-and-create-tables" />
<property name="eclipselink.application-location"
value="/Users/dlibke/Workspaces/MyEclipse Pro 2014/libkedesign/enterprise/domain/src/main/resources" />
<property name="eclipselink.create-ddl-jdbc-file-name"
value="ld-db-createDDL.sql" />
<property name="eclipselink.drop-ddl-jdbc-file-name" value="ld-db-dropDDL.sql" />
</properties>
</persistence-unit>
</persistence>
Stack Trace:
Local Exception Stack:
Exception [EclipseLink-23004] (Eclipse Persistence Services - 2.5.0.v20130507-3faac2b): org.eclipse.persistence.exceptions.TransactionException
Exception Description: Error obtaining the Transaction Manager
Internal Exception: Exception [EclipseLink-23001] (Eclipse Persistence Services - 2.5.0.v20130507-3faac2b): org.eclipse.persistence.exceptions.TransactionException
Exception Description: Error looking up external Transaction resource under JNDI name [java:appserver/TransactionManager]
Internal Exception: javax.naming.NamingException: Lookup failed for 'java:appserver/TransactionManager' in SerialContext[myEnv={java.naming.factory.initial=com.sun.enterprise.naming.impl.SerialInitContextFactory, java.naming.factory.url.pkgs=com.sun.enterprise.naming, java.naming.factory.state=com.sun.corba.ee.impl.presentation.rmi.JNDIStateFactoryImpl} [Root exception is javax.naming.NameNotFoundException: No object bound for java:appserver/TransactionManager [Root exception is java.lang.NullPointerException]]
at org.eclipse.persistence.exceptions.TransactionException.errorObtainingTransactionManager(TransactionException.java:125)
at org.eclipse.persistence.transaction.JTATransactionController.<init>(JTATransactionController.java:69)
at org.eclipse.persistence.transaction.glassfish.GlassfishTransactionController.<init>(GlassfishTransactionController.java:36)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:57)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.lang.reflect.Constructor.newInstance(Constructor.java:526)
at java.lang.Class.newInstance(Class.java:374)
at org.eclipse.persistence.internal.security.PrivilegedAccessHelper.newInstanceFromClass(PrivilegedAccessHelper.java:417)
at org.eclipse.persistence.platform.server.ServerPlatformBase.initializeExternalTransactionController(ServerPlatformBase.java:295)
at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.preConnectDatasource(DatabaseSessionImpl.java:775)
at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.loginAndDetectDatasource(DatabaseSessionImpl.java:733)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryProvider.login(EntityManagerFactoryProvider.java:239)
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.deploy(EntityManagerSetupImpl.java:681)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryDelegate.getAbstractSession(EntityManagerFactoryDelegate.java:204)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryDelegate.getDatabaseSession(EntityManagerFactoryDelegate.java:182)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.getDatabaseSession(EntityManagerFactoryImpl.java:527)
at org.eclipse.persistence.jpa.PersistenceProvider.createEntityManagerFactoryImpl(PersistenceProvider.java:140)
at org.eclipse.persistence.jpa.PersistenceProvider.createEntityManagerFactory(PersistenceProvider.java:177)
at javax.persistence.Persistence.createEntityManagerFactory(Persistence.java:79)
at org.eclipse.jpt.jpa.eclipselink.core.ddlgen.Main.buildEntityManagerFactory(Main.java:94)
at org.eclipse.jpt.jpa.eclipselink.core.ddlgen.Main.execute(Main.java:80)
at org.eclipse.jpt.jpa.eclipselink.core.ddlgen.Main.main(Main.java:68)
Caused by: Exception [EclipseLink-23001] (Eclipse Persistence Services - 2.5.0.v20130507-3faac2b): org.eclipse.persistence.exceptions.TransactionException
at org.eclipse.persistence.exceptions.TransactionException.jndiLookupException(TransactionException.java:47)
at org.eclipse.persistence.transaction.AbstractTransactionController.jndiLookup(AbstractTransactionController.java:454)
at org.eclipse.persistence.transaction.glassfish.GlassfishTransactionController.acquireTransactionManager(GlassfishTransactionController.java:44)
at org.eclipse.persistence.transaction.JTATransactionController.<init>(JTATransactionController.java:67)
... 21 more
Caused by: javax.naming.NamingException: Lookup failed for 'java:appserver/TransactionManager' in SerialContext[myEnv={java.naming.factory.initial=com.sun.enterprise.naming.impl.SerialInitContextFactory, java.naming.factory.url.pkgs=com.sun.enterprise.naming, java.naming.factory.state=com.sun.corba.ee.impl.presentation.rmi.JNDIStateFactoryImpl} [Root exception is javax.naming.NameNotFoundException: No object bound for java:appserver/TransactionManager [Root exception is java.lang.NullPointerException]]
at com.sun.enterprise.naming.impl.SerialContext.lookup(SerialContext.java:491)
at com.sun.enterprise.naming.impl.SerialContext.lookup(SerialContext.java:438)
at javax.naming.InitialContext.lookup(InitialContext.java:411)
at org.eclipse.persistence.transaction.AbstractTransactionController.jndiLookup(AbstractTransactionController.java:452)
... 23 more
Caused by: javax.naming.NameNotFoundException: No object bound for java:appserver/TransactionManager [Root exception is java.lang.NullPointerException]
at com.sun.enterprise.naming.impl.JavaURLContext.lookup(JavaURLContext.java:229)
at com.sun.enterprise.naming.impl.SerialContext.lookup(SerialContext.java:471)
... 26 more
Caused by: java.lang.NullPointerException
at com.sun.enterprise.naming.impl.JavaURLContext.lookup(JavaURLContext.java:167)
... 27 more
Exception in thread "main" javax.persistence.PersistenceException: Exception [EclipseLink-23004] (Eclipse Persistence Services - 2.5.0.v20130507-3faac2b): org.eclipse.persistence.exceptions.TransactionException
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.deploy(EntityManagerSetupImpl.java:762)
Caused by: Exception [EclipseLink-23004] (Eclipse Persistence Services - 2.5.0.v20130507-3faac2b): org.eclipse.persistence.exceptions.TransactionException
... 9 more
... 21 more
... 23 more
... 26 more
... 27 more
What am I missing or have incorrect
Dave
FUDForum. Page generated in 0.02814 seconds
