Home » Language IDEs » Java Development Tools (JDT) » Eclipse for WebLogic 10.3.6(Eclipse for WebLogic 10.3.6 failing at startup)
Eclipse for WebLogic 10.3.6 [message #1252958] Fri, 21 February 2014 19:55 Go to next message
Bryan Gentile is currently offline Bryan GentileFriend
I recently installed the Oracle WebLogic Portal 10.3.6 client. I am attempting to run the Eclipse for WebLogic 10.3.6 which is shipped with the product. However I am getting a Java error returning with exit code = 69 upon startup.
Has anyone had similar issues and if so, any ideas for resolution?
Re: Eclipse for WebLogic 10.3.6 [message #1253391 is a reply to message #1252958] Sat, 22 February 2014 07:27 Go to previous messageGo to next message
Maybe asking on the Web Tools forum is more likely to address people
doing web development.
> Thanks
Ed Merks
Re: Eclipse for WebLogic 10.3.6 [message #1367932 is a reply to message #1252958] Tue, 20 May 2014 00:52 Go to previous messageGo to next message
ciaran collins is currently offline ciaran collinsFriend
I have the same issue. I can't find anything on this error code. Can anyone help?
Re: Eclipse for WebLogic 10.3.6 [message #1470489 is a reply to message #1367932] Wed, 12 November 2014 11:27 Go to previous message
Hemang Shrimanker is currently offline Hemang ShrimankerFriend
Please change the eclipse.ini file at location C:\Oracle\Middleware\oepe_11gR1PS4
1. Change -Xms1024m to -Xms1792m
2. Change -Xmx2048m to Xmx1792m
And start the eclipse.exe.
If the eclipse still doesn't start, then try different combinations of multiples of 128 like 128*12=1592 or 128*13=1664 or 128*11=1408 etc as value for -Xms and -Xmx.
For me, the value 1792 worked.
Regards.
H
Previous Topic:Setting a body in an http POST using apache httpClient
Next Topic:Spell checking is not working
Current Time: Tue Apr 16 20:06:04 GMT 2024
Powered by FUDForum. Page generated in 0.36660 seconds
