Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » Issue with the definition of gmf.nodes
Issue with the definition of gmf.nodes [message #1252824] |
Fri, 21 February 2014 16:42 |
Jonh Cost Messages: 3 Registered: February 2014 |
Hello! First of all I would like to apologize if this is not the appropriate place, but the section seems to be a little death.
I have the following metamodel and its notation GMF:
@gmf(foo="bar")
@namespace(uri="casemodel", prefix="casemodel")
package caseModel;
@gmf.diagram(foo="bar")
class CaseModel {
val Root[1] root;
abstract class CaseNode {
id attr String[1] name;
@gmf.link
val Member[*] members;
@gmf.node(label="name", figure="rectangle", border.width="2", border.style="solid", label.placement="internal", size="50,50")
class Root extends CaseNode {
class Act extends CaseNode, Member {
attr int[1] cardinality;
abstract class Member {
class ActOne extends Act {
class ActTwo extends Act {
I want to create three nodes: Root, Arcone and ArcTwo. The Root node must have a connection to Arcone and another for ArcTwo, but the problem is that the definition of the GMF notation in EMF file is not allowing me to do what I want, because I can not select the nodes Arcone and ArcTwo in the pallete.
How can I solve the problem? I know that is the incorrect definition of the GMF notation, but I can not solve it. Thank you!
Re: Issue with the definition of gmf.nodes [message #1252843 is a reply to message #1252824] |
Fri, 21 February 2014 17:01 |
Ed Merks Messages: 33140 Registered: July 2009 |
Jonh,
I think this is a question about using Epsilon, right? Better you post
to the eclipse.epsilon forum in that case.
> @gmf(foo="bar")
> package caseModel;
> class CaseModel {
> val Root[1] root;
> @gmf.link
Ed Merks
Current Time: Thu Apr 25 05:03:31 GMT 2024
Powered by FUDForum. Page generated in 0.03102 seconds
