Create a Birt report with Jubula [message #1252737] |
Fri, 21 February 2014 14:54 |
I have a little problem to generate a BIRT report with Jubula.
When I'm on the "Functional Test Reporting" Perspective, I select the arrow next to the 'Create ITE BIRT Report'. I select the type of report and a window is created (BIRT Report Viewer). But in this window, I have nothing as is shown by the attachment.
So, my question is how can I create a BIRT report ? Have I missed something in the configuration ?
I work with the Jubula Standalone 7.1.0.
Thanks for any quick help,
Elise
Elise Ruelle
ALL4TEC
[Updated on: Fri, 21 February 2014 14:54] Report message to a moderator
Re: Create a Birt report with Jubula [message #1256209 is a reply to message #1256198] |
Tue, 25 February 2014 07:50 |
Hello Ajantha,
I want to generate the "Test History" Report proposed by Jubula in the "Functional Test Reporting". I just would like to have a report with the Test Suites result (OK/Failed) for a day. For that I would like to use the functionality proposed by Jubula to generate a report. But when I use it I always have an empty window.
Do I need to add something to Jubula to use this feature ?
I use Jubula 7.1 on a Windows 7.
I've tried with the version 7.2 of Jubula standalone but I have the same issue.
Thanks per advance for your help or any idea
Elise
Elise Ruelle
ALL4TEC
[Updated on: Wed, 26 February 2014 16:56] Report message to a moderator
Re: Create a Birt report with Jubula [message #1257665 is a reply to message #1257640] |
Wed, 26 February 2014 17:26 |
Thanks for your reply.
I don't use any browser because I use this feature from Jubula. Jubula opens a window (for me it's empty like the screenshot from my first post) and it supposed to allow me to select my preferences for the generation of a report. But if I try to save the source code of this window and execute it on chrome I can see the window to select the properties for the generation of the report as you can see in the screenshot of my browser but I can't do anything from this.
I don't have any log in jubula.
Thanks for the link to the bug entry but the bug entry refers to an opening problem but for me it's a more a generation problem.
To generate some BIRT reports from Jubula, need I to add some elements to the jubula's installation ?
Have you any idea to help me ? Because I don't understand why with a clean installation I can't use this feature.
Thanks for any help,
Elise Ruelle
ALL4TEC
FUDForum. Page generated in 0.03093 seconds
