Invalid transformation Problem [message #1251680] |
Thu, 20 February 2014 13:31  |
ModelGeek Mising name Messages: 550 Registered: June 2011 |
I am trying simple HelloWorld QVTO example given at http://www.levysiqueira.com.br/2011/01/eclipse-qvto-hello-world/
When i run transformation. i get the following exception. Any idea why it is so?
Caused by: java.lang.IllegalArgumentException: Invalid transformation HelloWorldTransformation
at org.eclipse.m2m.internal.qvt.oml.runtime.launch.InMemoryQvtLaunchConfigurationDelegate.launch(InMemoryQvtLaunchConfigurationDelegate.java:58)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:884)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:739)
at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(DebugUIPlugin.java:1039)
at org.eclipse.debug.internal.ui.DebugUIPlugin$7.run(DebugUIPlugin.java:1129)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:122)
Root exception:
same is the case when i run the default qvt example project Simpleuml To Rdb
Caused by: java.lang.IllegalArgumentException: Invalid transformation Simpleuml_To_Rdb
Root exception:
i am uing Eclipse Version: Luna M5 Release
Build id: 20140130-1145
[Updated on: Thu, 20 February 2014 13:40] Report message to a moderator
Re: Invalid transformation Problem [message #1252820 is a reply to message #1251813] |
Fri, 21 February 2014 16:39   |
I have tried the simpleUMLTORDB example but i get the same exception.
The other problem i have noticed that when i run the transformation and in the run transformation dialog... it keep showing the warning at top "Destination 'platform:/resource/SimpleUML to RDB/Simpleuml_To_Rdb123.rdb' already exists". Although there is no such file exists..
I also wanted to attach the screen shot for the error message but some how the option to attach files is not available on the web interface for forum......
My eclipse is :
eclipse.buildId=4.4.0.I20131030-2000
java.version=1.7.0_03
Root exception:
[Updated on: Fri, 21 February 2014 16:41] Report message to a moderator
Re: Invalid transformation Problem [message #1262114 is a reply to message #1254672] |
Mon, 03 March 2014 09:23   |
I am going to describe in detail.
I am using example project "SimpleUML to RDB". It contains "Simpleuml_To_Rdb.qvto". I select this qvto file in Package Explorer and I go to run menu and select "Transformation" menu option. It brings dialog where i again select "Simpleuml_To_Rdb.qvto" and press "next". It finally brings tranformation dialog.
I have following setting on the dialog :
IN uml: UML(http://www.eclispe.org/qvt/1.0.0/Operational/examples/simpleuml)
Model URI : platform:/resource/SimpleUML to RDB/pim.simpleuml
OUT $1 : RDB(http://www.eclispe.org/qvt/1.0.0/Operational/examples/rdb)
Model URI : platform:/resource/SimpleUML to RDB/Simpleuml_To_Rdb.rdb
so when i press "finish" i get the following exception :
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:422)
at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(ProgressMonitorDialog.java:513)
at org.eclipse.ui.internal.progress.ProgressMonitorJobsDialog.run(ProgressMonitorJobsDialog.java:275)
at org.eclipse.ui.internal.progress.ProgressManager$3.run(ProgressManager.java:961)
at org.eclipse.ui.internal.progress.ProgressManager.busyCursorWhile(ProgressManager.java:996)
at org.eclipse.ui.internal.progress.ProgressManager.busyCursorWhile(ProgressManager.java:971)
at org.eclipse.debug.internal.ui.DebugUIPlugin.launchInForeground(DebugUIPlugin.java:1137)
at org.eclipse.debug.ui.DebugUITools.launch(DebugUITools.java:768)
at org.eclipse.m2m.internal.qvt.oml.runtime.ui.wizards.RunInterpretedTransformationWizard.performFinishBody(RunInterpretedTransformationWizard.java:136)
at org.eclipse.m2m.internal.qvt.oml.common.ui.wizards.PersistedValuesWizard.performFinish(PersistedValuesWizard.java:65)
at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:851)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:437)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:633)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:248)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4353)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1061)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4172)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3761)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:827)
at org.eclipse.jface.window.Window.open(Window.java:803)
at org.eclipse.m2m.internal.qvt.oml.runtime.ui.actions.RunInterpretedTransformationAction.invokeWizard(RunInterpretedTransformationAction.java:57)
at org.eclipse.m2m.internal.qvt.oml.runtime.ui.actions.RunInterpretedTransformationAction.runImpl(RunInterpretedTransformationAction.java:42)
at org.eclipse.m2m.internal.qvt.oml.common.ui.action.WindowActionDelegate.run(WindowActionDelegate.java:50)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginAction.java:251)
at org.eclipse.ui.internal.WWinPluginAction.runWithEvent(WWinPluginAction.java:229)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:588)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:505)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:415)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1122)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1006)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:146)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:615)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:566)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:125)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:109)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:80)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:372)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:226)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
Am i doing anything wrong here?
I have been trying to attach project and screen shots but attachment seems to be disabled....
cheers,
[Updated on: Mon, 03 March 2014 09:28] Report message to a moderator
Re: Invalid transformation Problem [message #1262226 is a reply to message #1262174] |
Mon, 03 March 2014 11:49   |
I have tried the Alt + Shift + F2 and it says
The active contribution item identifier:
org.eclipse.m2m.internal.qvt.oml.runtime.ui.wizards.RunInterpretedTransformationActionId
The active action set identifier:
org.eclipse.m2m.qvt.oml.runtime.actions
Eclipse Standard/SDK
For me i have main menu option Run->Transformation. To activate this, i have to select qvto file in package expolrer. It brings a dialog where it asks to select the qvto file again and then comes main transformation dialog where i have to give IN and OUT parameters.
[Updated on: Mon, 03 March 2014 11:51] Report message to a moderator
FUDForum. Page generated in 0.02129 seconds
