Home » Archived » Eclipse Process Manager (Stardust) » Stardust 1.1 logon error(HTTP Status 404 ...shell/desktop-index.html is not available)
Stardust 1.1 logon error [message #1250060] Tue, 18 February 2014 22:46 Go to next message
Gudrun Koko is currently offline Gudrun KokoFriend
The following error is displayed upon first logon to Stardust 1.1.0 portal.
"The requested resource (/ipp-portal-9.9.9-SNAPSHOT/shell/desktop-index.html) is not available." Checking source retrieved shows that directory ./ui.web/orion-client/resources/META-INF/webapp/shell contains no .html file only a nls directory.
Need help. Has anyone encountered this error ?
.war file generation was completed successfully before for Stardust 1.0.0. However for 1.1.0 it runs into the above logon error. Yet I used git clone commands from Eclipse site but followed up with a git checkout for -b v1.1.0.20131218-0839-R in order to zero in on a stable release. In addition once source was generated for archetype tc7-ipp-portal-war and a .war file packaged, mySQL config changes were made by un-jaring the .war file and making relevant changes. MySQL schema was created using sysconsole. Build used the sysconsole-client archetype. Stardust 1.1.0 war file was successfully deployed according to tomcat log. For now deployed to tomcat 6 however.
OS used RH 6.5.
[Updated on: Wed, 19 February 2014 16:20]
Report message to a moderator
Re: Stardust 1.1 logon error [message #1252178 is a reply to message #1250060] Fri, 21 February 2014 01:30 Go to previous message
Seems adding branch to git clone commands -b I_4_3 and then switch to -b v1.1.0.20131218-0839-R using git checkout commands solved the issue encountered.
Logon to stardust portal was successful again.
Catalina log reports however below error
7:22:24 ERROR [Catalina]]] ContextLoader - Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'bpmInteractionsService': Invocation of init method failed; nested exception is javax.xml.ws.WebServiceException: java.lang.RuntimeException: Invalid schema document passed to AbstractDataBinding.addSchemaDocument, not in W3C schema namespace: schema
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1482)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:521)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:458)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:295)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:223)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:292)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:194)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:628)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:932)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:479)
at org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:389)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:294)
at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:112)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:3972)
at org.apache.catalina.core.StandardContext.start(StandardContext.java:4467)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:791)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:771)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:526)
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:905)
at org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:740)
at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:500)
at org.apache.catalina.startup.HostConfig.check(HostConfig.java:1345)
at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:303)
at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(LifecycleSupport.java:119)
at org.apache.catalina.core.ContainerBase.backgroundProcess(ContainerBase.java:1337)
at org.apache.catalina.core.ContainerBase$ContainerBackgroundProcessor.processChildren(ContainerBase.java:1601)
at org.apache.catalina.core.ContainerBase$ContainerBackgroundProcessor.processChildren(ContainerBase.java:1610)
at org.apache.catalina.core.ContainerBase$ContainerBackgroundProcessor.run(ContainerBase.java:1590)
at java.lang.Thread.run(Thread.java:662)
Caused by: javax.xml.ws.WebServiceException: java.lang.RuntimeException: Invalid schema document passed to AbstractDataBinding.addSchemaDocument, not in W3C schema namespace: schema
at org.apache.cxf.jaxws.EndpointImpl.doPublish(EndpointImpl.java:357)
at org.apache.cxf.jaxws.EndpointImpl.publish(EndpointImpl.java:246)
at org.apache.cxf.jaxws.EndpointImpl.publish(EndpointImpl.java:525)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeCustomInitMethod(AbstractAutowireCapableBeanFactory.java:1608)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1549)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1479)
... 28 more
Caused by: java.lang.RuntimeException: Invalid schema document passed to AbstractDataBinding.addSchemaDocument, not in W3C schema namespace: schema
at org.apache.cxf.databinding.AbstractDataBinding.addSchemaDocument(AbstractDataBinding.java:109)
at org.apache.cxf.databinding.AbstractDataBinding.addSchemaDocument(AbstractDataBinding.java:95)
at org.apache.cxf.jaxb.JAXBDataBinding.initialize(JAXBDataBinding.java:380)
at org.apache.cxf.service.factory.AbstractServiceFactoryBean.initializeDataBindings(AbstractServiceFactoryBean.java:86)
at org.apache.cxf.service.factory.ReflectionServiceFactoryBean.buildServiceFromClass(ReflectionServiceFactoryBean.java:474)
at org.apache.cxf.jaxws.support.JaxWsServiceFactoryBean.buildServiceFromClass(JaxWsServiceFactoryBean.java:685)
at org.apache.cxf.service.factory.ReflectionServiceFactoryBean.initializeServiceModel(ReflectionServiceFactoryBean.java:536)
at org.apache.cxf.service.factory.ReflectionServiceFactoryBean.create(ReflectionServiceFactoryBean.java:248)
at org.apache.cxf.jaxws.support.JaxWsServiceFactoryBean.create(JaxWsServiceFactoryBean.java:205)
at org.apache.cxf.frontend.AbstractWSDLBasedEndpointFactory.createEndpoint(AbstractWSDLBasedEndpointFactory.java:101)
at org.apache.cxf.frontend.ServerFactoryBean.create(ServerFactoryBean.java:159)
at org.apache.cxf.jaxws.JaxWsServerFactoryBean.create(JaxWsServerFactoryBean.java:207)
at org.apache.cxf.jaxws.EndpointImpl.getServer(EndpointImpl.java:442)
at org.apache.cxf.jaxws.EndpointImpl.doPublish(EndpointImpl.java:329)
... 37 more
Previous Topic:Building Stardust
Next Topic:Load Testing of Business Process
Current Time: Wed Dec 02 10:33:53 GMT 2020
Powered by FUDForum. Page generated in 0.01782 seconds
