EMF Compare FeatureNotFoundException [message #1248834] |
Mon, 17 February 2014 18:03 |
Pey Max Messages: 5 Registered: February 2014 |
Hi, I'm getting a
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.eclipse.emf.ecore.xmi.FeatureNotFoundException: Feature 'Model' not found.
when I try to compare 2 xmi files with Emf Compare.
I'm kind of a beginner with this but I'm having a lot of trouble trying to fix this issue. Here's the code :
public static void compare() {
EPackage.Registry.INSTANCE.put(UmlPackage.eINSTANCE.getNsURI(), UmlPackage.eINSTANCE);
// Load the two input models
ResourceSet resourceSet1 = new ResourceSetImpl();
ResourceSet resourceSet2 = new ResourceSetImpl();
URI uri = URI.createFileURI(new File("xmi/test1.xmi").getAbsolutePath());
URI uri2 = URI.createFileURI(new File("xmi/test2.xmi").getAbsolutePath());
resourceSet1.getPackageRegistry().put(UmlPackage.eINSTANCE.getNsURI(), UmlPackage.eINSTANCE);
resourceSet2.getPackageRegistry().put(UmlPackage.eINSTANCE.getNsURI(), UmlPackage.eINSTANCE);
resourceSet1.getResourceFactoryRegistry().getExtensionToFactoryMap().put("xmi", new XmiResourceFactoryImpl());
resourceSet2.getResourceFactoryRegistry().getExtensionToFactoryMap().put("xmi", new XmiResourceFactoryImpl());
resourceSet1.getResource(uri, true);
resourceSet2.getResource(uri, true);
// Configure EMF Compare
IEObjectMatcher matcher = DefaultMatchEngine.createDefaultEObjectMatcher(UseIdentifiers.NEVER);
IComparisonFactory comparisonFactory = new DefaultComparisonFactory(new DefaultEqualityHelperFactory());
IMatchEngine.Factory matchEngineFactory = new MatchEngineFactoryImpl(matcher, comparisonFactory);
matchEngineFactory.setRanking(20);
IMatchEngine.Factory.Registry matchEngineRegistry = new MatchEngineFactoryRegistryImpl();
matchEngineRegistry.add(matchEngineFactory);
EMFCompare comparator = EMFCompare.builder().setMatchEngineFactoryRegistry(matchEngineRegistry).build();
// Compare the two models
IComparisonScope scope = EMFCompare.createDefaultScope(resourceSet1, resourceSet2);
ICompareEditingDomain editingDomain = EMFCompareEditingDomain.create(resourceSet1, resourceSet2, null);
AdapterFactory adapterFactory = new ComposedAdapterFactory(ComposedAdapterFactory.Descriptor.Registry.INSTANCE);
@SuppressWarnings("restriction")
CompareEditorInput input = new ComparisonScopeEditorInput(new CompareConfiguration(),
editingDomain, adapterFactory, comparator, scope);
CompareUI.openCompareDialog(input);
and the exception :
Exception in thread "main" org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.eclipse.emf.ecore.xmi.FeatureNotFoundException: Feature 'Model' not found. (file:/C:/Users/Maxime/Documents/Documents/IUT/XMIGraph/xmi/test1.xmi, 6, 70)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDemandLoadException(ResourceSetImpl.java:319)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:278)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:406)
at compare.Compare.compare(Compare.java:90)
at compare.Compare.main(Compare.java:70)
Caused by: org.eclipse.emf.ecore.xmi.FeatureNotFoundException: Feature 'Model' not found. (file:/C:/Users/Maxime/Documents/Documents/IUT/XMIGraph/xmi/test1.xmi, 6, 70)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.reportUnknownFeature(XMLHandler.java:1998)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleUnknownFeature(XMLHandler.java:1962)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleFeature(XMLHandler.java:1906)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XMLHandler.java:1030)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:1008)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:719)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.startElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanStartElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl.parse(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:175)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:253)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1518)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1297)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:259)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274)
... 3 more
I'd appreciate some help Thanks !
Re: EMF Compare FeatureNotFoundException [message #1249263 is a reply to message #1248834] |
Tue, 18 February 2014 04:37 |
Ed Merks Messages: 33140 Registered: July 2009 |
Pey,
Comments below.
On 17/02/2014 10:02 PM, Pey Max wrote:
> Hi, I'm getting a
> not found.
EMF provides XMIResourceFactoryImpl so what is XmiResourceFactoryImpl?
> CompareConfiguration(), editingDomain, adapterFactory, comparator,
> scope);
> and the exception :
> not found.
> 6, 70)
> at
> at
> at
> 'Model' not found.
> 6, 70)
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> ... 3 more
It's impossible to comment on why your unknown-to-me serialization
doesn't conform to your unknown-to-me model. Can you read and write
instance of your model with the generated editor?
> I'd appreciate some help :) Thanks !
Ed Merks
Re: EMF Compare FeatureNotFoundException [message #1253334 is a reply to message #1253017] |
Sat, 22 February 2014 05:56 |
Pey,
Comments below.
On 21/02/2014 10:29 PM, Pey Max wrote:
> Well I actually don't know what is the package for the model I'm
> using. How do I found out ?
From the namespace. Top level element(s) in the XMI. There must be an
EPackage with an nsURI that corresponds and then the rest of the
serialization must conform the EClasses defined in that model.
> I used UmlPackage because I saw a lot of people using it on the web
> but since the serialization is based on a custom metamodel, I should
> probably use another ... But I got no idea how to find it.
Nor do I.
Ed Merks
FUDForum. Page generated in 0.04116 seconds
