Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [EMFStore] Basic EMFStore Example doesn't work
Re: [EMFStore] Basic EMFStore Example doesn't work [message #1249464 is a reply to message #1248761] |
Tue, 18 February 2014 09:20 |
Edgar Mueller Messages: 89 Registered: March 2011 |
Member |
Hi Marina,
you need to change the port of your server reference that is returned by
createAndStartLocalServer(). Otherwise the default port 8080 will be
used. After you started the server with
final ESServer localServer = ESServer.FACTORY.createAndStartLocalServer();
call setPort(PORT) on your localServer instance:
localServer.setPort(443);
This will make the client use port 443 to communicate with the server.
Note that by default Skype blocks 443.
Hope this helps.
Edgar
Am 17.02.2014 17:35, schrieb Marina Knieling:
> Solved. Stupid me. The server wasn't running because I had a JIRA
> instance running on port 8080. Stopped the JIRA service and now it works.
> BUT: when I change the port in the es.properties file to 443, it doesn't
> work. I don't want to shut down my JIRA server each time I test the
> Local EMFStore. Any hints on that?
> New Exception is the following:
> Connection to Server
> failed!org.eclipse.emf.emfstore.internal.server.exceptions.ConnectionException:
> Server could not be reached.
> Failed to read server's response: Connection refused: connect
> at
> org.eclipse.emf.emfstore.internal.client.model.connectionmanager.xmlrpc.XmlRpcClientManager.executeCall(XmlRpcClientManager.java:169)
> at
> org.eclipse.emf.emfstore.internal.client.model.connectionmanager.xmlrpc.XmlRpcClientManager.callWithResult(XmlRpcClientManager.java:115)
> at
> org.eclipse.emf.emfstore.internal.client.model.connectionmanager.xmlrpc.XmlRpcConnectionManager.logIn(XmlRpcConnectionManager.java:61)
> at
> org.eclipse.emf.emfstore.internal.client.model.impl.UsersessionImpl.logIn(UsersessionImpl.java:605)
> at
> org.eclipse.emf.emfstore.internal.client.model.impl.api.ESServerImpl$5.doRun(ESServerImpl.java:225)
> at
> org.eclipse.emf.emfstore.internal.client.model.util.EMFStoreCommand.commandBody(EMFStoreCommand.java:51)
> at
> org.eclipse.emf.emfstore.internal.client.model.util.AbstractEMFStoreCommand.execute(AbstractEMFStoreCommand.java:64)
> at
> org.eclipse.emf.common.command.BasicCommandStack.execute(BasicCommandStack.java:78)
> at
> org.eclipse.emf.emfstore.internal.client.model.changeTracking.commands.EMFStoreBasicCommandStack.execute(EMFStoreBasicCommandStack.java:72)
> at
> org.eclipse.emf.emfstore.internal.client.model.util.AbstractEMFStoreCommand.aRun(AbstractEMFStoreCommand.java:108)
> at
> org.eclipse.emf.emfstore.internal.client.model.util.EMFStoreCommand.run(EMFStoreCommand.java:60)
> at
> org.eclipse.emf.emfstore.internal.client.model.impl.api.ESServerImpl.login(ESServerImpl.java:234)
> at
> org.eclipse.emf.emfstore.example.helloworld.Application.runClient(Application.java:109)
> at
> org.eclipse.emf.emfstore.example.helloworld.Application.start(Application.java:49)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
> at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
> at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
> Caused by: org.apache.xmlrpc.XmlRpcException: Failed to read server's
> at
> org.apache.xmlrpc.client.XmlRpcStreamTransport.sendRequest(XmlRpcStreamTransport.java:161)
> at
> org.apache.xmlrpc.client.XmlRpcHttpTransport.sendRequest(XmlRpcHttpTransport.java:143)
> at
> org.apache.xmlrpc.client.XmlRpcSunHttpTransport.sendRequest(XmlRpcSunHttpTransport.java:69)
> at
> org.apache.xmlrpc.client.XmlRpcClientWorker.execute(XmlRpcClientWorker.java:56)
> at org.apache.xmlrpc.client.XmlRpcClient.execute(XmlRpcClient.java:167)
> at org.apache.xmlrpc.client.XmlRpcClient.execute(XmlRpcClient.java:137)
> at org.apache.xmlrpc.client.XmlRpcClient.execute(XmlRpcClient.java:126)
> at
> org.eclipse.emf.emfstore.internal.client.model.connectionmanager.xmlrpc.XmlRpcClientManager.executeCall(XmlRpcClientManager.java:159)
> ... 26 more
> Caused by: java.net.ConnectException: Connection refused: connect
> at java.net.DualStackPlainSocketImpl.waitForConnect(Native Method)
> at java.net.DualStackPlainSocketImpl.socketConnect(Unknown Source)
> at java.net.AbstractPlainSocketImpl.doConnect(Unknown Source)
> at java.net.AbstractPlainSocketImpl.connectToAddress(Unknown Source)
> at java.net.AbstractPlainSocketImpl.connect(Unknown Source)
> at java.net.PlainSocketImpl.connect(Unknown Source)
> at java.net.SocksSocketImpl.connect(Unknown Source)
> at java.net.Socket.connect(Unknown Source)
> at sun.security.ssl.SSLSocketImpl.connect(Unknown Source)
> at sun.net.NetworkClient.doConnect(Unknown Source)
> at sun.net.www.http.HttpClient.openServer(Unknown Source)
> at sun.net.www.protocol.https.HttpsClient.<init>(Unknown Source)
> at sun.net.www.protocol.https.HttpsClient.New(Unknown Source)
> at
> sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.getNewHttpClient(Unknown
> Source)
> at sun.net.www.protocol.http.HttpURLConnection.plainConnect(Unknown
> Source)
> at
> sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(Unknown
> Source)
> at
> sun.net.www.protocol.http.HttpURLConnection.getOutputStream(Unknown Source)
> at
> sun.net.www.protocol.https.HttpsURLConnectionImpl.getOutputStream(Unknown Source)
> at
> org.apache.xmlrpc.client.XmlRpcSunHttpTransport.writeRequest(XmlRpcSunHttpTransport.java:104)
> at
> org.apache.xmlrpc.client.XmlRpcStreamTransport.sendRequest(XmlRpcStreamTransport.java:151)
> ... 33 more
> Am 17.02.2014 17:13, schrieb Marina Knieling:
>> Hey guys,
>> I just tried to get the Basic EMFStore Example to work, but it crashes
>> with the following exception:
>> Connection to Server failed!
>> Failed to read server's response: Unrecognized SSL message, plaintext
>> connection?
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> response: Unrecognized SSL message, plaintext connection?
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 26 more
>> Caused by: javax.net.ssl.SSLException: Unrecognized SSL message,
>> at sun.security.ssl.InputRecord.handleUnknownRecord(Unknown Source)
>> at sun.security.ssl.InputRecord.read(Unknown Source)
>> at sun.security.ssl.SSLSocketImpl.readRecord(Unknown Source)
>> at sun.security.ssl.SSLSocketImpl.performInitialHandshake(Unknown
>> Source)
>> at sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source)
>> at sun.net.www.protocol.https.HttpsClient.afterConnect(Unknown
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> at
>> ... 33 more
>> Seems like the call to
>> ESUsersession usersession = server.login("super", "super");
>> is the cause. Do I have to do anything else in order to make this work?
>> Some SSL settings in the eclipse IDE or anywhere else?
>> Regards
>> Marina
Edgar Mueller
Get Professional Eclipse Support: http://eclipsesource.com/munich
Re: [EMFStore] Basic EMFStore Example doesn't work [message #1250771 is a reply to message #1249464] |
Wed, 19 February 2014 15:30 |
Marina Knieling Messages: 83 Registered: February 2013 |
Member |
Hi Edgar,
thanks for your help. Works like a charm now.
Do you know of any way to set the port dynamically by finding out which
ports are used locally and then choose one that is free?
Although I think that there might be a problem with setting the port in
the es.properties file. Or can the port be set via eclipse Preferences
maybe? Any idea?
Marina
Am 18.02.2014 10:20, schrieb Edgar Mueller:
> Hi Marina,
> Hope this helps.
> Cheers,
> Edgar
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 26 more
>> at
>> Source)
>> Source)
>> at
>> Source)
>> at
>> at
>> at
>> at
>> ... 33 more
>>> Hey guys,
>>> connection?
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 26 more
>>> Source)
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> at
>>> ... 33 more
>>> Regards
>>> Marina
Re: [EMFStore] Basic EMFStore Example doesn't work [message #1251574 is a reply to message #1250771] |
Thu, 20 February 2014 11:11 |
Member |
Hi Marina,
I'm not sure if I understand you correctly. Would you like to set the
port of the server dynamically at startup, e.g. by starting the server
programatically and specifying the port as a parameter (instead of
declaring it in the es.properties file)? Unfortunately that is currently
not possible with EMFStore, although it would be feasible of course.
If this requirement is crucial for you, please open up a feature
request. Contributions are also welcome :)
Edgar
Am 19.02.2014 16:30, schrieb Marina Knieling:
> Hi Edgar,
> maybe? Any idea?
> Marina
>> Hi Marina,
>> Hope this helps.
>> Cheers,
>> Edgar
>>> works.
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 26 more
>>> Source)
>>> at
>>> Source)
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> at
>>> ... 33 more
>>>> Hey guys,
>>>> connection?
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Source)
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> ... 26 more
>>>> Source)
>>>> Source)
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> at
>>>> ... 33 more
>>>> Regards
>>>> Marina
Edgar Mueller
Current Time: Thu Apr 25 13:25:24 GMT 2024
Powered by FUDForum. Page generated in 0.03525 seconds
