Home » Language IDEs » ServerTools (WTP) » Programmatically do XML Catalog contributions in WST
Programmatically do XML Catalog contributions in WST [message #204397] Wed, 14 November 2007 11:45 Go to next message
Anders Olsson is currently offline Anders OlssonFriend
Hello!
I have a need for adding DTDs to the XML Catalog in WST. I cannot use the
org.eclipse.est.xml.core.catalogContributions Extension Point, since the
location of the DTDs might be different every startup (or on different
machines).
I've been looking at the internal classes in
org.eclipse.wst.xml.core.internal and .catalog to little avail. I've
managed to do:
XMLCorePlugin xmlPlug =
org.eclipse.wst.xml.core.internal.XMLCorePlugin.getDefault() ;
Catalog defaultXMLCatalog = (Catalog) xmlPlug.getDefaultXMLCatalog();
What I then should do is a bit unclear. I want to do is add entries one by
one. So I think the class I should instance and insert is CatalogEntry.
Problem is only it has it's constructor set as protected.
What I would of course want is a public API for XML Catalog contributions.
But for now I'm content with using the internals. Could someone tell me if
my approach makes sense, and where I've diverted from the correct path. It
cannot be the case that this is currently impossible.
Thanks in advance for any replies.
Best Regards,
Anders Olsson
Re: Programmatically do XML Catalog contributions in WST [message #204473 is a reply to message #204397] Thu, 15 November 2007 20:00 Go to previous messageGo to next message
Lawrence Mandel is currently offline Lawrence MandelFriend
Hi Anders,
If your contributed DTDs don't need to be viewable in the XML catalog you
can create a custom URI resolver [1].
[1]
http://help.eclipse.org/help31/topic/org.eclipse.wst.doc.isv /reference/extension-points/common/org_eclipse_wst_common_ur iresolver_resolverExtensions.html
Lawrence
>Hello!
>machines).
>managed to do:
by
contributions.
if
It
>Best Regards,
>Anders Olsson
Re: Programmatically do XML Catalog contributions in WST [message #204685 is a reply to message #204473] Mon, 19 November 2007 08:32 Go to previous messageGo to next message
Thank you for your reply, Lawrence.
I've tried implementing this solution in my plug-in, but I've ran into
some problems.
What I've done is that I've added an extension:
<extension
point="org.eclipse.wst.common.uriresolver.resolverExtensions ">
<resolverExtension
class="schemaSetter.ResolverExtension1">
</resolverExtension>
</extension>
in my plug-in.
The schemaSetter.ResolverExtension1 class is very simple, and implements
org.eclipse.wst.common.uriresolver.internal.provisional.URIR esolver
in both the resolve and resolvePhysicalLocation methods I simply return a
URI string without checking the input arguments.
I would paste the code, but so far that's not where the problem lies. I
ran in debugging mode with break points in both the methods, and they were
never visited. What I tried to do is to validate an XML file, but all I
get is an error about <the original URI> not being found.
Is there something I've missed? Is there something more that needs to be
done to use this resource?
/Anders
lmandel@ca.ibm.com wrote:
> Hi Anders,
> [1]
> Lawrence
>>Hello!
>>machines).
>>managed to do:
> by
> contributions.
> if
> It
>>Best Regards,
>>Anders Olsson
Re: Programmatically do XML Catalog contributions in WST [message #204734 is a reply to message #204685] Tue, 20 November 2007 04:49 Go to previous messageGo to next message
Hi Anders,
Did you try to clear the configuration area when launching a runtime
workspace? I've found this is sometimes a problem. There's an option in
the launch configuration.
Lawrence
Re: Programmatically do XML Catalog contributions in WST [message #204740 is a reply to message #204734] Tue, 20 November 2007 08:24 Go to previous messageGo to next message
The problem was a ClassCastException. I had missed it before, due to my
own output scrolling past it. The problem seems to be that I had followed
the instructions and let my class implement
but in
org.eclipse.wst.common.uriresolver.internal.URIResolverExten sionDescriptor
the class gets cast to
org.eclipse.wst.common.uriresolver.internal.provisional.URIR esolverExtension
Changing Interface and adding appropriate methods did the trick, and now
the Resolver works as advertised.
I also checked the more current documentation at:
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. wst.doc.isv/reference/extension-points/common/org_eclipse_ws t_common_uriresolver_resolverExtensions.html
and the suggested interface to implement is still the same (wrong) one. Is
this base for filing a bug?
Many thanks to you Lawrence.
/Anders
> Hi Anders,
> Lawrence
Re: Programmatically do XML Catalog contributions in WST [message #204768 is a reply to message #204740] Wed, 21 November 2007 03:41 Go to previous message
>Is this base for filing a bug?
Absolutely. Bugs are not restricted to code problems. Bugs include
documentation, the Web site, and even WTP process.
Lawrence
Previous Topic:Deploying WST Plugin recursively
Next Topic:Help with WSDL Validation please, any rules listing?
Current Time: Wed Oct 05 13:07:20 GMT 2022
Powered by FUDForum. Page generated in 0.02447 seconds
