Home » Modeling » QVT-OML » Error with abstract mapping with lastest version of QVTo
Error with abstract mapping with lastest version of QVTo [message #1245207] Thu, 13 February 2014 13:13 Go to next message
Thibault Le Ouay is currently offline Thibault Le OuayFriend
Hey,
I had a transformartion which ran great on Eclipse Luna M4 but since i have upgraded to the M5 and the lastest version of QVTo i cant run this transformation anymore.
I have a AbstractTransfo.qvto with mostly abstract mapping which looked like that :
abstract mapping Node::toOwnNode() : Nodeinherits View::toView;
it worked great on the last version but with the latest one i have that kind of error :
Multiple markers at this line - Unsupported inherited mapping 'View::toView' on blackbox mapping
'Node::toOwnNode' - No blackbox implementation found for operation 'Node::toOwnNode'. Make sure
that an implementation is available when running the transformation.
I have to add a blank implementation to make it works
Is it a bug ?
Best,
Thibault
Re: Error with abstract mapping with lastest version of QVTo [message #1245240 is a reply to message #1245207] Thu, 13 February 2014 14:01 Go to previous messageGo to next message
Adolfo Sanchez-Barbudo Herrera is currently offline Adolfo Sanchez-Barbudo HerreraFriend
Hi Thibault,
Feel free to join the discussion at:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=428028
Adolfo.
On 13/02/2014 13:33, Thibault Le Ouay wrote:
> Hey,
> like that :
> kind of error :
> 'View::toView' on blackbox mapping 'Node::toOwnNode' - No blackbox
> implementation found for operation 'Node::toOwnNode'. Make sure that an
> Is it a bug ?
> Best,
> Thibault
Re: Error with abstract mapping with lastest version of QVTo [message #1298726 is a reply to message #1245207] Wed, 16 April 2014 13:04 Go to previous messageGo to next message
Vincent DUGRAS is currently offline Vincent DUGRASFriend
Hi Thibault
Can you help me please ?
Re: Error with abstract mapping with lastest version of QVTo [message #1301542 is a reply to message #1245240] Fri, 18 April 2014 06:43 Go to previous message
Sergey Boyko is currently offline Sergey BoykoFriend
Adolfo Sanchez-Barbudo Herrera wrote on Thu, 13 February 2014 09:01
Hi Thibault,
Adolfo.
> Hey,
> like that :
> kind of error :
> Is it a bug ?
> Best,
> Thibault
Consequently you should switch to M6 build. Mentioned regression was fixed there.
Sergey.
Previous Topic:I want to give you a QVTo test coverage plugin
Next Topic:Use of Libraries in different Projects
Current Time: Mon Jan 18 00:14:08 GMT 2021
Powered by FUDForum. Page generated in 0.01681 seconds
