XSD editor: nillable property? [message #204023] |
Fri, 09 November 2007 09:54 |
Originally posted by: mauro.molinari.cardinis.com
Hi there!
Before submitting an enhancement request... anyone knows if there's an
hidden option in Preferences view to set the "nillable" property of an
XSD element??? I hardly believe it is not present...
Mauro.
Re: XSD editor: nillable property? [message #204056 is a reply to message #204023] |
Fri, 09 November 2007 16:42 |
Originally posted by: dcarver.starstandard.org
Mauro Molinari wrote:
> Hi there!
Mauro, you are correct it is not there. All other options are available
through the Advanced tab of the Properties View, but nillable is not one
of them.
You can add it in the source view, via content assist (CTRL+SPACE) when
in the xsd element.
I've opened the following bug for this enhancement:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=209356
Please feel free to add your comments to that as well.
Re: XSD editor: nillable property? [message #204179 is a reply to message #204100] |
Sun, 11 November 2007 05:17 |
Keith Chong wrote:
> Thanks David for opening the bug.
I've created an initial patch for this bug, may do a bit of tweaking
with it to make sure it's only enabled when it can be used, and that
initial values are being set correctly.
Dave
Re: XSD editor: nillable property? [message #204228 is a reply to message #204093] |
Mon, 12 November 2007 09:07 |
Keith Chong ha scritto:
> Hi Mauro, do you mean in the properties view for an element? Or do you
> want an option in the preferences so that any newly created element has
> nillable set to true or false? Either way, please open an enhancement
> bug for what you want.
> Thanks.
Hi Keith,
I meant a field in the properties view.
Thanks David for the patch!
Mauro.
FUDForum. Page generated in 0.03694 seconds
