Problems : Unable to read .../hudson/hudson_home/hudson-security.xml [message #1243876] |
Tue, 11 February 2014 15:17 |
Guillaume Helle Messages: 8 Registered: February 2014 |
i have some problems with Hudson 1.3.1 security and Role-based Authorization Strategy 1.1.3-h-2
When Tomcat start, i have the following exception but i see nothing wrong in my hudson-security.xml file :
INFO: Loading Security ..
févr. 11, 2014 2:58:27 PM hudson.util.RobustReflectionConverter doUnmarshal
WARNING: Skipping a non-existent type com.michelin.cio.hudson.plugins.rolestrategy.RoleBasedAuthorizationStrategy
févr. 11, 2014 2:58:27 PM org.eclipse.hudson.security.HudsonSecurityManager load
SEVERE: Failed to load /cip/hudson/hudson_home/hudson-security.xml
hudson.util.IOException2: Unable to read /cip/hudson/hudson_home/hudson-security.xml
at hudson.XmlFile.unmarshal(XmlFile.java:140)
at org.eclipse.hudson.security.HudsonSecurityManager.load(HudsonSecurityManager.java:368)
at org.eclipse.hudson.security.HudsonSecurityManager.<init>(HudsonSecurityManager.java:144)
at org.eclipse.hudson.HudsonServletContextListener.contextInitialized(HudsonServletContextListener.java:206)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4797)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5291)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:901)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:877)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:633)
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:977)
at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1655)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:471)
at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:334)
at java.util.concurrent.FutureTask.run(FutureTask.java:166)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:722)
Caused by: com.thoughtworks.xstream.converters.ConversionException: null : null
---- Debugging information ----
cause-exception : java.lang.NullPointerException
cause-message : null
class : org.eclipse.hudson.security.HudsonSecurityManager
required-type : org.eclipse.hudson.security.HudsonSecurityManager
converter-type : hudson.util.RobustReflectionConverter
path : /hudsonSecurityManager
line number : 94
version : null
at com.thoughtworks.xstream.core.TreeUnmarshaller.convert(TreeUnmarshaller.java:79)
at com.thoughtworks.xstream.core.AbstractReferenceUnmarshaller.convert(AbstractReferenceUnmarshaller.java:65)
at com.thoughtworks.xstream.core.TreeUnmarshaller.convertAnother(TreeUnmarshaller.java:66)
at com.thoughtworks.xstream.core.TreeUnmarshaller.convertAnother(TreeUnmarshaller.java:50)
at com.thoughtworks.xstream.core.TreeUnmarshaller.start(TreeUnmarshaller.java:134)
at com.thoughtworks.xstream.core.AbstractTreeMarshallingStrategy.unmarshal(AbstractTreeMarshallingStrategy.java:32)
at com.thoughtworks.xstream.XStream.unmarshal(XStream.java:1034)
at hudson.util.XStream2.unmarshal(XStream2.java:76)
at com.thoughtworks.xstream.XStream.unmarshal(XStream.java:1018)
at hudson.XmlFile.unmarshal(XmlFile.java:136)
... 17 more
at hudson.diagnosis.OldDataMonitor.report(OldDataMonitor.java:185)
at hudson.util.RobustReflectionConverter.doUnmarshal(RobustReflectionConverter.java:264)
at hudson.util.RobustReflectionConverter.unmarshal(RobustReflectionConverter.java:173)
at com.thoughtworks.xstream.core.TreeUnmarshaller.convert(TreeUnmarshaller.java:72)
... 26 more
févr. 11, 2014 2:58:32 PM hudson.util.CharacterEncodingFilter init
INFO: CharacterEncodingFilter initialized. DISABLE_FILTER: false FORCE_ENCODING: false
And when i try to assign roles i have this exception page :
message java.lang.RuntimeException: Failed to serialize org.eclipse.hudson.security.HudsonSecurityManager#authorizationStrategy for class org.eclipse.hudson.security.HudsonSecurityManager
description Le serveur a rencontré une erreur interne qui l''a empêché de satisfaire la requête.
exception
javax.servlet.ServletException: java.lang.RuntimeException: Failed to serialize org.eclipse.hudson.security.HudsonSecurityManager#authorizationStrategy for class org.eclipse.hudson.security.HudsonSecurityManager
org.kohsuke.stapler.Stapler.tryInvoke(Stapler.java:607)
org.kohsuke.stapler.Stapler.invoke(Stapler.java:650)
org.kohsuke.stapler.MetaClass$12.dispatch(MetaClass.java:365)
org.kohsuke.stapler.Stapler.tryInvoke(Stapler.java:565)
org.kohsuke.stapler.Stapler.invoke(Stapler.java:481)
org.kohsuke.stapler.Stapler.service(Stapler.java:152)
javax.servlet.http.HttpServlet.service(HttpServlet.java:728)
hudson.util.PluginServletFilter$1.doFilter(PluginServletFilter.java:86)
org.hudsonci.servlets.internal.ServletRegistrationFilterAdapter.doFilter(ServletRegistrationFilterAdapter.java:162)
org.hudsonci.servlets.internal.ServletRegistrationFilterAdapter.doFilter(ServletRegistrationFilterAdapter.java:134)
hudson.util.PluginServletFilter$1.doFilter(PluginServletFilter.java:89)
hudson.plugins.greenballs.GreenBallFilter.doFilter(GreenBallFilter.java:58)
hudson.util.PluginServletFilter.doFilter(PluginServletFilter.java:78)
hudson.security.ChainedServletFilter$1.doFilter(ChainedServletFilter.java:81)
hudson.security.UnwrapSecurityExceptionFilter.doFilter(UnwrapSecurityExceptionFilter.java:45)
hudson.security.ChainedServletFilter$1.doFilter(ChainedServletFilter.java:84)
org.springframework.security.ui.ExceptionTranslationFilter.doFilterHttp(ExceptionTranslationFilter.java:101)
org.springframework.security.ui.SpringSecurityFilter.doFilter(SpringSecurityFilter.java:53)
org.springframework.security.providers.anonymous.AnonymousProcessingFilter.doFilterHttp(AnonymousProcessingFilter.java:105)
org.springframework.security.ui.rememberme.RememberMeProcessingFilter.doFilterHttp(RememberMeProcessingFilter.java:116)
org.springframework.security.ui.AbstractProcessingFilter.doFilterHttp(AbstractProcessingFilter.java:278)
org.springframework.security.ui.basicauth.BasicProcessingFilter.doFilterHttp(BasicProcessingFilter.java:174)
org.springframework.security.context.HttpSessionContextIntegrationFilter.doFilterHttp(HttpSessionContextIntegrationFilter.java:235)
hudson.security.ChainedServletFilter.doFilter(ChainedServletFilter.java:73)
hudson.security.HudsonFilter.doFilter(HudsonFilter.java:157)
hudson.util.CharacterEncodingFilter.doFilter(CharacterEncodingFilter.java:70)
cause mère
hudson.util.RobustReflectionConverter$2.writeField(RobustReflectionConverter.java:161)
hudson.util.RobustReflectionConverter$2.visit(RobustReflectionConverter.java:129)
com.thoughtworks.xstream.converters.reflection.PureJavaReflectionProvider.visitSerializableFields(PureJavaReflectionProvider.java:135)
hudson.util.RobustReflectionConverter.doMarshal(RobustReflectionConverter.java:114)
hudson.util.RobustReflectionConverter.marshal(RobustReflectionConverter.java:84)
com.thoughtworks.xstream.core.AbstractReferenceMarshaller.convert(AbstractReferenceMarshaller.java:69)
com.thoughtworks.xstream.core.TreeMarshaller.convertAnother(TreeMarshaller.java:59)
com.thoughtworks.xstream.core.TreeMarshaller.convertAnother(TreeMarshaller.java:44)
com.thoughtworks.xstream.core.TreeMarshaller.start(TreeMarshaller.java:79)
com.thoughtworks.xstream.core.AbstractTreeMarshallingStrategy.marshal(AbstractTreeMarshallingStrategy.java:37)
com.thoughtworks.xstream.XStream.marshal(XStream.java:876)
com.thoughtworks.xstream.XStream.marshal(XStream.java:865)
com.thoughtworks.xstream.XStream.toXML(XStream.java:838)
hudson.XmlFile.write(XmlFile.java:153)
org.eclipse.hudson.security.HudsonSecurityManager.save(HudsonSecurityManager.java:355)
com.michelin.cio.hudson.plugins.rolestrategy.RoleBasedAuthorizationStrategy$DescriptorImpl.doAssignSubmit(RoleBasedAuthorizationStrategy.java:368)
com.michelin.cio.hudson.plugins.rolestrategy.RoleStrategyConfig.doAssignSubmit(RoleStrategyConfig.java:134)
sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
java.lang.reflect.Method.invoke(Method.java:601)
org.kohsuke.stapler.Function$InstanceFunction.invoke(Function.java:274)
org.kohsuke.stapler.Function.bindAndInvoke(Function.java:141)
org.kohsuke.stapler.Function.bindAndInvokeAndServeResponse(Function.java:80)
org.kohsuke.stapler.MetaClass$1.doDispatch(MetaClass.java:95)
org.kohsuke.stapler.NameBasedDispatcher.dispatch(NameBasedDispatcher.java:45)
cause mère
com.michelin.cio.hudson.plugins.rolestrategy.RoleBasedAuthorizationStrategy$ConverterImpl.marshal(RoleBasedAuthorizationStrategy.java:239)
hudson.util.XStream2$AssociatedConverterImpl.marshal(XStream2.java:229)
com.thoughtworks.xstream.core.AbstractReferenceMarshaller$1.convertAnother(AbstractReferenceMarshaller.java:88)
hudson.util.RobustReflectionConverter.marshallField(RobustReflectionConverter.java:168)
hudson.util.RobustReflectionConverter$2.writeField(RobustReflectionConverter.java:157)
note La trace complète de la cause mère de cette erreur est disponible dans les fichiers journaux de Apache Tomcat/7.0.35.
Note : Manage Roles work fine...
Any ideas?
Thanks for you help!
Guillaume
[Updated on: Tue, 11 February 2014 15:21] Report message to a moderator
FUDForum. Page generated in 0.03011 seconds
