Home » Language IDEs » ServerTools (WTP) » There are no projects that can be added or removed from the server issue
There are no projects that can be added or removed from the server issue [message #203946] Wed, 07 November 2007 15:33 Go to next message
Originally posted by: ka_one45.hotmail.com
I am still trying to upgrade to eclipse 3.3 from eclipse 3.1. I am able to
get the project running using an existing server that I imported from
eclipse 3.1 but if i remove that server and try to add the project back to
the server I get the following msg "There are no projects that can be added
or removed from the server"
For some reson eclipse still think my projects are deployed. How do I
remove them manually so I can add this project to a new server I create?
Re: There are no projects that can be added or removed from the server issue [message #204039 is a reply to message #203946] Fri, 09 November 2007 08:06 Go to previous message
Karim wrote:
This usually means that the server doesn't meet the requirements of the
module found in any of your projects. For example, if you had created
Tomcat 5.5 server and a Dynamic Web Project that specified the Dynamic
Web Module facet version 2.5 (i.e. it requires Servlet 2.5), you would
not be able to add that project to the Tomcat 5.5 server because it only
supports up to Servlet 2.4. It's hard to speculate any further about
the cause of the behavior you are seeing because there is no information
to work with beyond that you are using Eclipse 3.3 and migrated from
Eclipse 3.1.
Larry
Previous Topic:Method references in JSP files
Next Topic:StructuredTextEditor consumes huge amount of memory
Current Time: Sun Nov 02 01:14:27 EDT 2025
Powered by FUDForum. Page generated in 0.05183 seconds
