Home » Eclipse Projects » Remote Application Platform (RAP) » RCP to RAP : No context available outside of the request processing
RCP to RAP : No context available outside of the request processing [message #1243718] |
Tue, 11 February 2014 10:52 |
Clément Chausson Messages: 16 Registered: November 2013 |
I tried to convert a big RCP application to RAP but I have some troubles
I have not errors anymore but when I launch my RAP configuration I got this error :
Quote:java.lang.IllegalStateException: No context available outside of the request processing.
at org.eclipse.rap.rwt.internal.service.ContextProvider.getContext(ContextProvider.java:95)
at org.eclipse.rap.rwt.internal.service.ContextProvider.getUISession(ContextProvider.java:183)
at org.eclipse.rap.rwt.SingletonUtil.getSessionInstance(SingletonUtil.java:54)
at org.eclipse.ui.internal.Workbench.getInstance(Workbench.java:652)
at org.eclipse.ui.PlatformUI.getWorkbench(PlatformUI.java:94)
at thales.themis.em.gene.plugins.main.MainActivator.<init>(MainActivator.java:56)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:57)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.lang.reflect.Constructor.newInstance(Constructor.java:525)
at java.lang.Class.newInstance0(Class.java:374)
at java.lang.Class.newInstance(Class.java:327)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadBundleActivator(AbstractBundle.java:167)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:679)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:390)
at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1176)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:559)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:544)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:457)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:243)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:438)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
The code which cause the trouble is the following :
public MainActivator() {
// Initialize the GENE-EM view and editor manager.
GeneEMViewAndEditorManager
.initializeInstanceForPerspective(PerspectiveFactory.PERSPECTIVE_ID);
// Subscribe to perspective notifier for open and close event
GeneEMPerspectiveNotifier.subscribe(this);
// Add a listener to workbench events (closing workbench)
try {
[color=red]PlatformUI.getWorkbench()[/color].addWorkbenchListener(
GeneEMViewAndEditorManager.getInstance());
} catch (final GeneralApplicationException gae) {
// Log error
ExceptionDisplayer.getInstance().logGeneEMException(gae,
MsgLevel.WARN);
I have already read many forums (included here) and the RAP FAQ about "IllegalStateException: No context available outside of the request service lifecycle " and I have already test it with no success but I don't know if it is the same problem.
If someone could tell me if i don't see the solution or if i'm wrong when i thinking that the FAQ section about IllegalStateException can solved my problem.
I would be very grateful for any help you could might be able to give me on my problem.
[Updated on: Tue, 11 February 2014 10:53] Report message to a moderator
Re: RCP to RAP : No context available outside of the request processing [message #1244451 is a reply to message #1244363] |
Wed, 12 February 2014 11:09 |
Yury Mising name Messages: 95 Registered: May 2010 Location: Russia |
Member |
Seems to me the org.eclipse.debug.ui is a RCP plugin (I do not see it in the RAP) and it can not be started in RAP environment. Try to exclude the org.eclipse.debug.* plugins from your launch configuration and additionally check your Target Platform.
Also the org.eclipse.ui.application.WorkbenchAdvisor.preShutdown() and org.eclipse.ui.application.WorkbenchAdvisor.postShutdown() methods are another place to call your listener without attaching it to the workbench.
Yury.
[Updated on: Wed, 12 February 2014 11:14] Report message to a moderator
Re: RCP to RAP : No context available outside of the request processing [message #1244548 is a reply to message #1244451] |
Wed, 12 February 2014 13:54 |
Thanks for your help Yuri
I unchecked the appropriated bundles in the run configuration and theses errors disappeared.
Unfortunately, I have error now when i try to access to my application by browser :
Quote:java.lang.NoSuchMethodException: org.eclipse.e4.ui.css.swt.internal.theme.BootstrapTheme3x.<init>(org.eclipse.swt.widgets.Display)
at java.lang.Class.getConstructor0(Class.java:2730)
at java.lang.Class.getConstructor(Class.java:1676)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2568)
at org.eclipse.ui.internal.Workbench.access$5(Workbench.java:2530)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:701)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:684)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:157)
at thales.themis.em.cpiomcf.product.CpiomcfEmRAP.createUI(CpiomcfEmRAP.java:12)
at org.eclipse.rap.rwt.internal.lifecycle.RWTLifeCycle.createUI(RWTLifeCycle.java:186)
at org.eclipse.rap.rwt.internal.lifecycle.RWTLifeCycle$UIThreadController.run(RWTLifeCycle.java:298)
at java.lang.Thread.run(Thread.java:722)
at org.eclipse.rap.rwt.internal.lifecycle.UIThread.run(UIThread.java:104)
and
Quote:org.eclipse.core.runtime.CoreException: Plug-in "org.eclipse.ui" was unable to instantiate class "org.eclipse.ui.internal.handlers.SaveAsHandler".
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:194)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:186)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.ui.internal.Workbench.initializeDefaultServices(Workbench.java:1895)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:1593)
at org.eclipse.ui.internal.handlers.DirtyStateTracker.<init>(DirtyStateTracker.java:37)
at org.eclipse.ui.internal.handlers.AbstractSaveHandler.<init>(AbstractSaveHandler.java:38)
at org.eclipse.ui.internal.handlers.SaveAsHandler.<init>(SaveAsHandler.java:32)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:184)
... 38 more
and a lot of others which begin by
Quote:java.lang.IllegalStateException: Workbench has not been created yet.
or
Quote:java.lang.NoClassDefFoundError: Could not initialize class org.eclipse.ui.internal.themes.LightColorFactory
I try to remove all bundle like eclipse.ui.* in the Run configuration but i don't know if i'm on the right way
It's really hard to find all the causes of theses errors...
Thanking you in advance for your help.
[Updated on: Wed, 12 February 2014 13:55] Report message to a moderator
Re: RCP to RAP : No context available outside of the request processing [message #1245038 is a reply to message #1244919] |
Thu, 13 February 2014 07:49 |
Hi Yuri,
The result of ss command is :
Quote:osgi> ss
"Framework is launched."
id State Bundle
0 ACTIVE org.eclipse.osgi_3.9.1.v20130814-1242
1 ACTIVE org.eclipse.equinox.simpleconfigurator_1.0.300.v20110815-1744
2 ACTIVE CpiomcfEm_BusinessModel_1.0.0
3 RESOLVED CpiomcfEm_Common_1.0.0
Master=21
4 RESOLVED CpiomcfEm_GEM_1.0.0
Master=311
9 RESOLVED CpiomcfEm_PRM_1.0.0
Master=30
10 ACTIVE CpiomcfEm_Product_1.0.0
11 RESOLVED CpiomcfEm_SDM_1.0.0
Master=24
17 ACTIVE GENE_EM_BusinessMetaModel_4.0.0
18 ACTIVE GENE_EM_CMM_4.0.0
21 ACTIVE GENE_EM_Common_4.1.0
Fragments=3
24 ACTIVE GENE_EM_GDM_4.0.0
Fragments=11
26 ACTIVE GENE_EM_Help_3.1.0
30 ACTIVE GENE_EM_PRM_4.0.0
Fragments=9
32 ACTIVE ch.qos.logback.classic_1.0.0.v20111214-2030
33 ACTIVE ch.qos.logback.core_1.0.0.v20111214-2030
34 RESOLVED ch.qos.logback.slf4j_1.0.0.v20120123-1500
Master=271
35 ACTIVE com.google.guava_15.0.0
36 ACTIVE com.ibm.icu_4.4.2.v20110823
37 ACTIVE com.ibm.icu.base_50.1.1.v201304230130
38 ACTIVE javax.annotation_1.0.0.v20101115-0725
39 ACTIVE javax.inject_1.0.0.v20091030
40 ACTIVE javax.servlet_3.0.0.v201112011016
41 ACTIVE javax.xml_1.3.4.v201005080400
42 ACTIVE lpg.runtime.java_2.0.17.v201004271640
43 ACTIVE org.apache.ant_1.8.3.v20120321-1730
Fragments=226
44 ACTIVE org.apache.batik.css_1.6.0.v201011041432
45 ACTIVE org.apache.batik.util_1.6.0.v201011041432
46 ACTIVE org.apache.batik.util.gui_1.6.0.v201011041432
47 ACTIVE org.apache.commons.fileupload_1.3.0
48 ACTIVE org.apache.commons.io_2.4.0
55 ACTIVE org.apache.log4j_1.2.15.v201012070815
Fragments=258
56 ACTIVE org.apache.lucene_2.9.1.v201101211721
57 ACTIVE org.apache.lucene.analysis_2.9.1.v201101211721
58 ACTIVE org.apache.lucene.core_2.9.1.v201101211721
59 ACTIVE org.easymock_2.4.0.v20090202-0900
60 ACTIVE org.eclipse.ant.core_3.2.400.v20120523-1752
64 ACTIVE org.eclipse.compare.core_3.5.300.v20130514-1224
66 ACTIVE org.eclipse.core.commands_3.6.100.v20130515-1857
69 ACTIVE org.eclipse.core.databinding_1.4.1.v20130515-1857
73 ACTIVE org.eclipse.core.databinding.observable_1.4.1.v20130515-1857
75 ACTIVE org.eclipse.core.databinding.property_1.4.200.v20130515-1857
77 ACTIVE org.eclipse.core.externaltools_1.0.100.v20120521-2012
78 ACTIVE org.eclipse.core.filebuffers_3.5.200.v20120523-1310
79 ACTIVE org.eclipse.core.filesystem_1.3.200.v20120522-2012
Fragments=80
80 RESOLVED org.eclipse.core.filesystem.win32.x86_1.1.300.v20120522-1137
Master=79
82 ACTIVE org.eclipse.core.resources_3.8.0.v20120522-2034
Fragments=83
83 RESOLVED org.eclipse.core.resources.win32.x86_3.5.100.v20120522-1137
Master=82
84 ACTIVE org.eclipse.core.runtime_3.9.0.v20130326-1255
85 ACTIVE org.eclipse.core.runtime.compatibility_3.2.200.v20120521-2346
86 ACTIVE org.eclipse.core.runtime.compatibility.auth_3.2.300.v20120523-2004
87 RESOLVED org.eclipse.core.runtime.compatibility.registry_3.5.100.v20120521-2346
Master=281
88 ACTIVE org.eclipse.core.variables_3.2.600.v20120521-2012
89 ACTIVE org.eclipse.debug.core_3.7.100.v20120521-2012
91 ACTIVE org.eclipse.e4.core.commands_0.10.1.v20120523-1955
92 ACTIVE org.eclipse.e4.core.contexts_1.1.0.v20120523-2004
93 ACTIVE org.eclipse.e4.core.di_1.1.0.v20120521-2346
94 ACTIVE org.eclipse.e4.core.di.extensions_0.11.0.v20120523-2004
95 ACTIVE org.eclipse.e4.core.services_1.0.0.v20120521-2346
96 ACTIVE org.eclipse.e4.ui.bindings_0.10.1.v20120523-1955
97 ACTIVE org.eclipse.e4.ui.css.core_0.10.1.v20120523-1955
98 ACTIVE org.eclipse.e4.ui.css.swt_0.10.1.v20120523-1955
99 ACTIVE org.eclipse.e4.ui.css.swt.theme_0.9.2.v20120523-1955
100 ACTIVE org.eclipse.e4.ui.di_0.10.1.v20120523-1955
101 ACTIVE org.eclipse.e4.ui.model.workbench_0.10.1.v20120523-1955
102 ACTIVE org.eclipse.e4.ui.services_0.10.1.v20120523-1955
103 ACTIVE org.eclipse.e4.ui.widgets_0.12.0.v20120523-1955
104 ACTIVE org.eclipse.e4.ui.workbench_0.10.2.v20120531-1742
105 ACTIVE org.eclipse.e4.ui.workbench.renderers.swt_0.10.1.v20120523-1955
106 ACTIVE org.eclipse.e4.ui.workbench.swt_0.10.1.v20120525-2014
107 ACTIVE org.eclipse.e4.ui.workbench3_0.12.0.v20120521-2329
108 ACTIVE org.eclipse.emf_2.6.0.v20120608-0554
109 ACTIVE org.eclipse.emf.common_2.9.0.v20130528-0742
110 ACTIVE org.eclipse.emf.ecore_2.9.0.v20130528-0742
111 ACTIVE org.eclipse.emf.ecore.change_2.8.0.v20120606-0717
112 ACTIVE org.eclipse.emf.ecore.xmi_2.8.0.v20120606-0717
113 ACTIVE org.eclipse.emf.edit_2.8.0.v20120608-0554
114 ACTIVE org.eclipse.emf.ocl_1.4.300.201007052143
115 ACTIVE org.eclipse.emf.query_1.2.100.v200903190031
117 ACTIVE org.eclipse.equinox.bidi_0.10.0.v20130327-1442
122 ACTIVE org.eclipse.equinox.ds_1.4.101.v20130813-1853
124 ACTIVE org.eclipse.equinox.event_1.3.0.v20130327-1442
125 ACTIVE org.eclipse.equinox.frameworkadmin_2.0.100.v20120606-175127
126 ACTIVE org.eclipse.equinox.frameworkadmin.equinox_1.0.400.v20120428-0117
128 ACTIVE org.eclipse.equinox.http.jetty_3.0.100.v20130327-1442
130 ACTIVE org.eclipse.equinox.http.servlet_1.1.400.v20130418-1354
133 ACTIVE org.eclipse.equinox.launcher_1.3.0.v20120522-1813
Fragments=134
134 RESOLVED org.eclipse.equinox.launcher.win32.win32.x86_1.1.200.v20120522-1813
Master=133
135 ACTIVE org.eclipse.equinox.p2.artifact.repository_1.1.200.v20120430-1959
136 ACTIVE org.eclipse.equinox.p2.core_2.2.0.v20120430-0525
137 ACTIVE org.eclipse.equinox.p2.director_2.2.0.v20120524-0542
138 ACTIVE org.eclipse.equinox.p2.director.app_1.0.300.v20120428-0517
139 ACTIVE org.eclipse.equinox.p2.engine_2.2.0.v20120501-1502
140 ACTIVE org.eclipse.equinox.p2.garbagecollector_1.0.200.v20110808-1657
141 ACTIVE org.eclipse.equinox.p2.jarprocessor_1.0.200.v20110808-1657
142 ACTIVE org.eclipse.equinox.p2.metadata_2.1.0.v20120430-2001
143 ACTIVE org.eclipse.equinox.p2.metadata.repository_1.2.100.v20120524-1717
144 ACTIVE org.eclipse.equinox.p2.operations_2.2.0.v20120524-0542
145 ACTIVE org.eclipse.equinox.p2.publisher_1.2.0.v20120428-0117
146 ACTIVE org.eclipse.equinox.p2.publisher.eclipse_1.1.0.v20120511-1931
147 ACTIVE org.eclipse.equinox.p2.repository_2.2.0.v20120524-1945
148 ACTIVE org.eclipse.equinox.p2.repository.tools_2.0.100.v20120501-1314
149 ACTIVE org.eclipse.equinox.p2.touchpoint.eclipse_2.1.100.v20120428-0117
151 ACTIVE org.eclipse.equinox.p2.updatesite_1.0.400.v20120412-1615
152 ACTIVE org.eclipse.equinox.preferences_3.5.100.v20130422-1538
154 ACTIVE org.eclipse.equinox.security_1.1.100.v20120522-1841
Fragments=156
156 RESOLVED org.eclipse.equinox.security.win32.x86_1.0.300.v20120522-2049
Master=154
158 ACTIVE org.eclipse.equinox.simpleconfigurator.manipulator_2.0.0.v20110808-1657
160 ACTIVE org.eclipse.equinox.util_1.0.500.v20130404-1337
162 ACTIVE org.eclipse.help.base_3.6.100.v201206081400
164 RESOLVED org.eclipse.jdt.compiler.apt_1.0.500.v20120522-1651
Master=166
165 RESOLVED org.eclipse.jdt.compiler.tool_1.0.101.v20120522-1651
Master=166
166 ACTIVE org.eclipse.jdt.core_3.8.1.v20120531-0637
Fragments=164, 165
167 ACTIVE org.eclipse.jdt.core.manipulation_1.5.0.v20120523-1543
175 ACTIVE org.eclipse.jetty.continuation_8.1.10.v20130312
177 ACTIVE org.eclipse.jetty.http_8.1.10.v20130312
180 ACTIVE org.eclipse.jetty.io_8.1.10.v20130312
182 ACTIVE org.eclipse.jetty.security_8.1.10.v20130312
184 ACTIVE org.eclipse.jetty.server_8.1.10.v20130312
185 ACTIVE org.eclipse.jetty.servlet_8.1.10.v20130312
187 ACTIVE org.eclipse.jetty.util_8.1.10.v20130312
189 ACTIVE org.eclipse.jface_3.9.0.v20130521-1714
190 ACTIVE org.eclipse.jface.databinding_1.6.0.v20120521-2329
191 ACTIVE org.eclipse.jface.text_3.8.100.v20130515-1957
192 ACTIVE org.eclipse.ltk.core.refactoring_3.6.0.v20120523-1543
194 ACTIVE org.eclipse.ocl_3.2.0.v20120611-1210
195 ACTIVE org.eclipse.ocl.common_1.0.0.v20120516-1543
196 ACTIVE org.eclipse.ocl.ecore_3.2.0.v20130125-1817
197 ACTIVE org.eclipse.osgi.services_3.3.100.v20130513-1956
199 ACTIVE org.eclipse.pde.build_3.8.0.v20120523-1555
209 ACTIVE org.eclipse.rap.jface_2.2.0.20131017-1149
210 ACTIVE org.eclipse.rap.jface.databinding_2.2.0.20130702-1310
213 ACTIVE org.eclipse.rap.rwt_2.2.0.20131204-0942
214 ACTIVE org.eclipse.rap.rwt.osgi_2.2.0.20131126-1551
215 ACTIVE org.eclipse.rap.rwt.supplemental.filedialog_2.0.0.20130302-1418
216 ACTIVE org.eclipse.rap.rwt.supplemental.fileupload_2.0.0.20130226-1002
218 ACTIVE org.eclipse.rap.ui_2.2.0.20130702-1310
220 ACTIVE org.eclipse.rap.ui.forms_2.2.0.20130930-1222
222 ACTIVE org.eclipse.rap.ui.workbench_2.2.0.20131121-1623
224 ACTIVE org.eclipse.swt_3.102.0.v20130605-1539
Fragments=225
225 RESOLVED org.eclipse.swt.win32.win32.x86_3.100.0.v4233d
Master=224
226 RESOLVED org.eclipse.swtbot.ant.optional.junit4_2.0.5.20120718_0854-997a76f-dev-e37
Master=43
227 ACTIVE org.eclipse.swtbot.eclipse.core_2.0.5.20120718_0854-997a76f-dev-e37
228 ACTIVE org.eclipse.swtbot.eclipse.finder_2.0.5.20120718_0854-997a76f-dev-e37
230 ACTIVE org.eclipse.swtbot.eclipse.spy_2.0.5.20120718_0854-997a76f-dev-e37
232 ACTIVE org.eclipse.swtbot.forms.finder_2.0.5.20120718_0854-997a76f-dev-e37
234 ACTIVE org.eclipse.swtbot.junit4_x_2.0.5.20120718_0854-997a76f-dev-e37
235 ACTIVE org.eclipse.swtbot.swt.finder_2.0.5.20120718_0854-997a76f-dev-e37
236 ACTIVE org.eclipse.team.core_3.6.100.v20120524-0627
238 ACTIVE org.eclipse.text_3.5.300.v20130515-1451
254 ACTIVE org.eclipse.ui.workbench_3.103.0.v20120530-1824
256 ACTIVE org.eclipse.uml2.common_1.7.0.v20120604-0919
257 ACTIVE org.eclipse.update.configurator_3.3.200.v20120523-1752
258 RESOLVED org.eclipse.xtext.logging_1.2.15.v201208210947
Master=55
259 ACTIVE org.hamcrest_1.1.0.v20090501071000
260 ACTIVE org.hamcrest.core_1.3.0.v201303031735
262 ACTIVE org.hamcrest.integration_1.1.0.v20090501071000
263 ACTIVE org.hamcrest.library_1.1.0.v20090501071000
264 ACTIVE org.hamcrest.text_1.1.0.v20090501071000
267 ACTIVE org.junit_4.11.0.v201303080030
268 ACTIVE org.junit4_4.8.1.v20120523-1257
269 ACTIVE org.sat4j.core_2.3.0.v20110329
270 ACTIVE org.sat4j.pb_2.3.0.v20110329
271 ACTIVE org.slf4j.api_1.6.4.v20120130-2120
Fragments=34
272 ACTIVE org.w3c.css.sac_1.3.1.v200903091627
273 ACTIVE org.w3c.dom.smil_1.0.0.v200806040011
274 ACTIVE org.w3c.dom.svg_1.1.0.v201011041433
275 ACTIVE org.eclipse.core.contenttype_3.4.200.v20130326-1255
276 ACTIVE org.eclipse.core.expressions_3.4.500.v20130515-1343
277 ACTIVE org.eclipse.core.jobs_3.5.300.v20130429-1813
278 ACTIVE org.eclipse.equinox.app_1.3.100.v20130327-1442
279 ACTIVE org.eclipse.equinox.common_3.6.200.v20130402-1505
280 ACTIVE org.eclipse.equinox.http.registry_1.1.300.v20130402-1529
281 ACTIVE org.eclipse.equinox.registry_3.5.301.v20130717-1549
Fragments=87
282 ACTIVE org.eclipse.help_3.6.0.v20130326-1254
283 ACTIVE org.eclipse.jdt.junit.runtime_3.4.400.v20130514-0733
291 ACTIVE org.apache.felix.gogo.command_0.10.0.v201209301215
292 ACTIVE org.apache.felix.gogo.runtime_0.10.0.v201209301036
293 ACTIVE org.apache.felix.gogo.shell_0.10.0.v201212101605
294 ACTIVE org.eclipse.equinox.console_1.0.100.v20130429-0953
295 ACTIVE org.eclipse.rap.jface_2.1.1.20130902-1345
296 ACTIVE org.eclipse.rap.rwt_2.1.1.20130902-1345
297 ACTIVE org.eclipse.e4.ui.workbench.addons.swt_0.10.1.v20120523-1955
300 INSTALLED CpiomcfEm_IE_1.0.0
301 RESOLVED CpiomcfEm_Main_1.0.0
Master=312
302 ACTIVE GENE-EM_EME_1.1.0
303 ACTIVE GENE-EM_Editor_1.0.0.qualifier
306 ACTIVE GENE_EM_1.0.0
309 ACTIVE GENE_EM_Compare_3.1.0
310 ACTIVE GENE_EM_ELM_4.1.0
311 ACTIVE GENE_EM_GEM_4.1.0
Fragments=4
312 ACTIVE GENE_EM_Main_1.0.0
Fragments=301
314 ACTIVE GENE_EM_PDF_4.1.0
315 ACTIVE TOOLS_Common_3.1.0
317 ACTIVE org.eclipse.compare_3.5.300.v20120522-1148
319 ACTIVE org.eclipse.equinox.p2.ui_2.2.0.v20120524-0542
320 ACTIVE org.eclipse.equinox.security.ui_1.1.100.v20120522-2049
325 ACTIVE org.eclipse.ltk.ui.refactoring_3.7.0.v20120523-1543
327 ACTIVE org.eclipse.search_3.8.0.v20120523-1540
328 ACTIVE org.eclipse.team.ui_3.6.200.v20120522-1148
329 ACTIVE org.eclipse.ui_3.103.0.v20120521-2329
330 ACTIVE org.eclipse.ui.cheatsheets_3.4.200.v20120521-2344
331 ACTIVE org.eclipse.ui.console_3.5.100.v20120521-2012
332 ACTIVE org.eclipse.ui.editors_3.8.0.v20120523-1540
334 ACTIVE org.eclipse.ui.forms_3.5.200.v20120521-2329
335 ACTIVE org.eclipse.ui.ide_3.8.0.v20120521-2329
Fragments=343
336 ACTIVE org.eclipse.ui.intro_3.4.200.v20120521-2344
337 ACTIVE org.eclipse.ui.navigator_3.5.200.v20120523-1955
338 ACTIVE org.eclipse.ui.navigator.resources_3.4.400.v20120523-1955
339 ACTIVE org.eclipse.ui.trace_1.0.0.v20120523-2012
340 ACTIVE org.eclipse.ui.views_3.6.100.v20120521-2329
341 ACTIVE org.eclipse.ui.views.log_1.0.300.v20120530-1435
342 ACTIVE org.eclipse.ui.views.properties.tabbed_3.5.300.v20120523-1955
343 RESOLVED org.eclipse.ui.win32_3.2.300.v20120523-1955
Master=335
344 ACTIVE org.eclipse.ui.workbench.texteditor_3.8.0.v20120523-1310
353 INSTALLED GENE-EM_IE_1.0.0
354 INSTALLED GENE_EM_Check_4.0.0
355 INSTALLED GENE_EM_CommandLine_4.1.0
356 INSTALLED GENE_EM_OCL_1.0.0
357 INSTALLED CpiomcfEm_Help_1.0.0
360 RESOLVED org.eclipse.help.ui_3.5.200.v20120521-2344
My MANIFEST.MF :
Quote:Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: CpiomcfEm_Product
Bundle-SymbolicName: CpiomcfEm_Product;singleton:=true
Bundle-Version: 1.0.0
Bundle-Activator: thales.themis.em.cpiomcf.product.plugin.Activator
Bundle-RequiredExecutionEnvironment: JavaSE-1.7
Require-Bundle: org.eclipse.core.runtime,
org.eclipse.e4.ui.model.workbench;bundle-version="0.10.1",
org.eclipse.e4.ui.workbench;bundle-version="0.10.2",
org.eclipse.e4.core.contexts;bundle-version="1.1.0",
org.eclipse.e4.ui.css.swt.theme;bundle-version="0.9.2",
org.eclipse.e4.ui.css.core;bundle-version="0.10.1",
org.eclipse.e4.ui.css.swt;bundle-version="0.10.1",
com.google.guava;bundle-version="10.0.1",
GENE_EM_Common;bundle-version="4.1.0",
GENE_EM_GEM;bundle-version="4.1.0",
org.eclipse.rap.ui;bundle-version="2.2.0"
Import-Package: org.eclipse.e4.ui.workbench.modeling
Bundle-ActivationPolicy: lazy
And my .launch file :
Quote:<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<launchConfiguration type="org.eclipse.rap.ui.launch.RAPLauncher">
<booleanAttribute key="append.args" value="true"/>
<booleanAttribute key="askclear" value="false"/>
<booleanAttribute key="automaticAdd" value="true"/>
<booleanAttribute key="automaticValidate" value="false"/>
<stringAttribute key="bootstrap" value=""/>
<stringAttribute key="checked" value="[NONE]"/>
<booleanAttribute key="clearConfig" value="false"/>
<booleanAttribute key="clearws" value="false"/>
<stringAttribute key="configLocation" value="${workspace_loc}/.metadata/.plugins/org.eclipse.pde.core/CPIOMCF-EM_RAP"/>
<booleanAttribute key="default" value="true"/>
<booleanAttribute key="default_auto_start" value="true"/>
<intAttribute key="default_start_level" value="4"/>
<stringAttribute key="deselected_workspace_plugins" value="CpiomcfEm_GuiTests,GENE-EM_GuiTests"/>
<booleanAttribute key="includeOptional" value="true"/>
<stringAttribute key="org.eclipse.debug.ui.ATTR_CAPTURE_IN_FILE" value="D:\Documents and Settings\T0133893\Bureau\log.txt"/>
<stringAttribute key="org.eclipse.jdt.launching.PROGRAM_ARGUMENTS" value="-os ${target.os} -ws ${target.ws} -arch ${target.arch} -nl ${target.nl} -consoleLog -console"/>
<stringAttribute key="org.eclipse.jdt.launching.SOURCE_PATH_PROVIDER" value="org.eclipse.pde.ui.workbenchClasspathProvider"/>
<stringAttribute key="org.eclipse.jdt.launching.VM_ARGUMENTS" value="-Declipse.ignoreApp=true -Dosgi.noShutdown=true
-Dorg.eclipse.equinox.http.jetty.log.stderr.threshold=info"/>
<stringAttribute key="org.eclipse.rap.launch.browserMode" value="EXTERNAL"/>
<stringAttribute key="org.eclipse.rap.launch.contextpath" value="/"/>
<stringAttribute key="org.eclipse.rap.launch.dataLocation" value="${workspace_loc}/.metadata/.plugins/org.eclipse.rap.tools.launch/CPIOMCF-EM_RAP"/>
<booleanAttribute key="org.eclipse.rap.launch.developmentMode" value="true"/>
<booleanAttribute key="org.eclipse.rap.launch.openBrowser" value="true"/>
<intAttribute key="org.eclipse.rap.launch.port" value="10080"/>
<stringAttribute key="org.eclipse.rap.launch.servletPath" value="/rap"/>
<intAttribute key="org.eclipse.rap.launch.sessionTimeout" value="0"/>
<booleanAttribute key="org.eclipse.rap.launch.useDefaultDataLocation" value="true"/>
<booleanAttribute key="org.eclipse.rap.launch.useManualContextPath" value="false"/>
<booleanAttribute key="org.eclipse.rap.launch.useManualPort" value="true"/>
<booleanAttribute key="org.eclipse.rap.launch.useSessionTimeout" value="false"/>
<stringAttribute key="pde.version" value="3.3"/>
<booleanAttribute key="show_selected_only" value="false"/>
<stringAttribute key="target_bundles" value="ch.qos.logback.classic@default:default,ch.qos.logback.core@default:default,
... (too long)
ch.qos.logback.slf4j@default:false,com.google.guava*15.0.0@default:default/>
<booleanAttribute key="tracing" value="false"/>
<booleanAttribute key="useCustomFeatures" value="false"/>
<booleanAttribute key="useDefaultConfigArea" value="true"/>
<stringAttribute key="workspace_bundles" value="CpiomcfEm_BusinessModel@default:default,CpiomcfEm_Common@default:false,
CpiomcfEm_GEM@default:false,CpiomcfEm_Help@default:default,
CpiomcfEm_IE@default:false,CpiomcfEm_Main@default:false,
CpiomcfEm_PRM@default:false,CpiomcfEm_Product@default:default,
CpiomcfEm_SDM@default:false,GENE-EM_EME@default:default,GENE-EM_Editor@default:default,GENE-EM_IE@default:default,GENE_EM@default:default,
GENE_EM_BusinessMetaModel@default:default,GENE_EM_CMM@default:default,
GENE_EM_Check@default:default,GENE_EM_CommandLine@default:default,
GENE_EM_Common@default:default,GENE_EM_Compare@default:default,
GENE_EM_ELM@default:default,GENE_EM_GDM@default:default,GENE_EM_GEM@default:default,
GENE_EM_Help@default:default,GENE_EM_Main@default:default,
GENE_EM_OCL@default:default,GENE_EM_PDF@default:default,GENE_EM_PRM@default:default,
TOOLS_Common@default:default"/>
</launchConfiguration>
If you see what's wrong.
I tried to resolved some problems like
Quote:The bundle "XYZ" could not be resolved. Reason: Missing Constraint: Require-Bundle: ABC; bundle-version="1.0.0"
All ABC bundles are in XYZ with correct version so i tried to remove et re-add it but with no success. I make them "Optional" and the error disappeared, is it good solution ?
[Updated on: Thu, 13 February 2014 08:49] Report message to a moderator
Current Time: Thu Apr 25 10:06:14 GMT 2024
Powered by FUDForum. Page generated in 0.03778 seconds
