Home » Language IDEs » ServerTools (WTP) » Importing a schema into another schema: "invalid schema file"?
Importing a schema into another schema: "invalid schema file"? [message #203757] Tue, 06 November 2007 10:29 Go to next message
Originally posted by: mauro.molinari.cardinis.com
Hello all!
I'm editing the inline schema of a WSDL and I tried to add an import
directive to import another schema I defined on a stand-alone XSD file.
This file is well-formed and valid (no validation errors given by
Eclipse), but in the import wizard dialog, when I try to select it from
the workspace (step named "Select XML schema file"), as soon as I click
on it an error hint is given: "filename.xsd is an invalid XML schema
file". The "Finish" button is grayed out and I cannot import it...
I'm quite new to WSDL and XSD, I'm learning now... anyone could help me
to determine the source of the problem?
The XSD I'm trying to import is the following:
<schema
targetNamespace="http://webservice.cardinis.com/AccessServices/xsd"
elementFormDefault="qualified"
xmlns="http://www.w3.org/2001/XMLSchema"
xmlns:tns="http://webservice.cardinis.com/AccessServices/xsd">
<annotation>
<documentation>
Schema per la definizione dei tipi usati dal webservice di
autenticazione.
</documentation>
</annotation>
<element name="Login_Username" type="string">
<annotation>
<documentation>
Parametro d'ingresso relativo al nome utente nell'operazione di
login.
</documentation>
</annotation>
</element>
<element name="Login_Password" type="string">
<annotation>
<documentation>
Parametro d'ingresso relativo alla password nell'operazione di
login.
</documentation>
</annotation>
</element>
<element name="Login_Ticket" type="string">
<annotation>
<documentation>
Parametro di uscita relativo al ticket assegnato all'utente
dall'operazione di login.
</documentation>
</annotation>
</element>
</schema>
Thanks in advance.
Mauro.
Re: Importing a schema into another schema: "invalid schema file"? [message #203837 is a reply to message #203757] Tue, 06 November 2007 22:17 Go to previous messageGo to next message
Keith Chong is currently offline Keith ChongFriend
Member
Hi, what version of WTP are you using? I used WTP 2.0.2 and 3.0
and I can successfully import this schema from an inline schema of a
WSDL.
Can you please attach your wsdl file too?
Re: Importing a schema into another schema: "invalid schema file"? [message #203875 is a reply to message #203837] Wed, 07 November 2007 11:00 Go to previous messageGo to next message
> WSDL.
Hi Keith,
thanks for your help.
I'm using WTP 2.0.1.
The WSDL I'm editing is the following: please note that it is
"work-in-progress", so it may contain some validation errors.
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<wsdl:definitions name="AccessService"
targetNamespace="http://webservice.cardinis.com/AccessService/wsdl"
xmlns:soap="http://schemas.xmlsoap.org/wsdl/soap/"
xmlns:tns="http://webservice.cardinis.com/AccessService/wsdl"
xmlns:wsdl="http://schemas.xmlsoap.org/wsdl/"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xmlns:tsns="http://webservice.cardinis.com/AccessService/xsd">
<wsdl:documentation>
Servizio di accesso ai servizi della &lt;em&gt;Suite
Cardinis&lt;/em&gt;
</wsdl:documentation>
<wsdl:types>
<xsd:schema xmlns:xsd="http://www.w3.org/2001/XMLSchema"
targetNamespace="http://webservice.cardinis.com/AccessService/wsdl">
</xsd:schema>
</wsdl:types>
<wsdl:message name="LoginRequest">
Messaggio corrispondente alla richiesta per l'operazione di login.
<wsdl:part name="Username" element="tsns:Login_Username">
<wsdl:documentation>Nome utente</wsdl:documentation>
</wsdl:part>
<wsdl:part name="Password" element="tsns:Login_Password">
<wsdl:documentation>Password.</wsdl:documentation>
</wsdl:part>
</wsdl:message>
<wsdl:message name="LoginResponse">
<wsdl:documentation></wsdl:documentation>
<wsdl:part name="Ticket" element="tsns:Login_Ticket">
Ticket restituito a seguito dell'operazione di login
</wsdl:part>
</wsdl:message>
<wsdl:message name="LogoutRequest">
Richiesta per effettuare il logout
<wsdl:part name="void" type="tsns:Empty"></wsdl:part>
</wsdl:message>
<wsdl:portType name="AccessService">
<wsdl:operation name="Login">
Effettua l'operazione di login nei webservice della
&lt;em&gt;Suite Cardinis&lt;/em&gt;
<wsdl:input message="tns:LoginRequest" name="LoginRequest">
</wsdl:input>
<wsdl:output message="tns:LoginResponse" name="LoginResponse" />
</wsdl:operation>
<wsdl:operation name="Logout">
<wsdl:input message="tns:LogoutRequest"
name="LogoutRequest"></wsdl:input>
</wsdl:operation>
</wsdl:portType>
<wsdl:binding name="AccessServiceSOAP" type="tns:AccessService">
<wsdl:documentation>Binding mediante SOAP.</wsdl:documentation>
<soap:binding style="document"
transport="http://schemas.xmlsoap.org/soap/http" />
<soap:operation
soapAction="http://webservice.cardinis.com/AccessService/wsdl/Login" />
<wsdl:input name="LoginRequest">
<soap:body use="literal" />
</wsdl:input>
<wsdl:output name="LoginResponse">
</wsdl:output>
</wsdl:operation>
<soap:operation
soapAction="http://webservice.cardinis.com/AccessService/wsdl/Logout" />
<wsdl:input name="LogoutRequest">
</wsdl:input>
</wsdl:operation>
</wsdl:binding>
<wsdl:service name="AccessService">
<wsdl:port binding="tns:AccessServiceSOAP"
name="AccessServiceSOAP">
<soap:address location="http://www.example.org/" />
</wsdl:port>
</wsdl:service>
</wsdl:definitions>
Mauro.
Re: Importing a schema into another schema: "invalid schema file"? [message #203900 is a reply to message #203875] Wed, 07 November 2007 13:33 Go to previous messageGo to next message
Originally posted by: dcarver.starstandard.org
Mauro,
You need to specify the WSDL to import in the wsdl:types, something like
the following:
Mauro Molinari wrote:
> <wsdl:types>
<xsd:include schemaLocation="filexsd.xsd"/>
> </xsd:schema>
> </wsdl:types>
Where the schemaLocation points to the file you want to include.
Dave
Re: Importing a schema into another schema: "invalid schema file"? [message #203987 is a reply to message #203900] Thu, 08 November 2007 08:28 Go to previous message
David Carver ha scritto:
> Mauro,
> the following:
>> <wsdl:types>
>> </xsd:schema>
>> </wsdl:types>
> Dave
Hi Dave,
yes, I know, but I tried to use the wizard instead of editing manually
the code and the wizard says the XSD is invalid as soon as I select it
in the dialog named "Select XML schema file" opened by clicking on "..."
beside the "location" attribute of the newly created import element
(Properties view).
I searched here for a confirmation of this IMHO strange behaviour,
before filing a new bug...
Mauro.
Previous Topic:Extending the WSDL Editor
Next Topic:Unsupported Content Type
Current Time: Tue Apr 16 19:48:51 GMT 2024
Powered by FUDForum. Page generated in 0.67616 seconds
