CVS: cannot see all branches [message #203708] |
Fri, 06 April 2007 15:54 |
Originally posted by: lists.dwsasia.com
When I try to checkout a branch in CVS in Eclipse it does not show all
branches that exists in the respository. When I use command line I see all
branches as normal. Is there anyway that I need to setup Eclipse CVS to do
deep search or anything?
/Peter
Re: CVS: cannot see all branches [message #203761 is a reply to message #203708] |
Fri, 06 April 2007 16:33 |
Originally posted by: irbull.cs.uvic.ca
Peter,
When I right click on the branches in the CVS view, and select select
"Refresh Branches", I get a list of projects. Then when I select a
project and hit finish, a dialog appears asking if I would like to
search deeply or not.
Does this work for you?
cheers,
ian
Eclipse wrote:
> /Peter
Re: CVS: cannot see all branches [message #203774 is a reply to message #203761] |
Fri, 06 April 2007 18:03 |
"Ian Bull" <irbull@cs.uvic.ca> wrote in message
news:ev5spl$62s$1@build.eclipse.org...
> Peter,
> "Refresh Branches", I get a list of projects. Then when I select a project
> and hit finish, a dialog appears asking if I would like to search deeply
> or not.
> cheers,
> ian
Hi Ian,
I don't get that option. And it does not refresh anything :( Stuck :(
Peter
Re: CVS: cannot see all branches [message #203789 is a reply to message #203774] |
Fri, 06 April 2007 17:12 |
Hum...
I'm using Eclipse 3.3 M6, although I know they had some way of searching
deeply in older versions of eclipse too. To be honest, I have never had
much luck with CVS branches in Eclipse either. I did a quick search and
it seems that issues around cvs branches have come up a lot on the
platform newsgroup. You can try the newsgroup search, and see if any of
these results help.
http://www.eclipse.org/search/search.cgi?q=cvs+branches+& ;cmd=Search%21&form=extended&wf=574a74&ps=10& ;m=all&t=5&ul=%2Fnewslists%2Fnews.eclipse.platform&a mp;wm=wrd&t=News&t=Mail
Good luck,
ian
>> Peter,
>> or not.
>> cheers,
>> ian
> Hi Ian,
> Cheers,
> Peter
FUDForum. Page generated in 0.02854 seconds
